SOLVED: CellPro charger won't charge - CELLS NO ADD UP error
Old 03-16-2018, 09:25 PM
Default SOLVED: CellPro charger won't charge - CELLS NO ADD UP error
This problem is SOLVED. I'm posting it here for the benefit of others searching for a solution to the same problem.
I've been using a CellPro Multi4 as my primary LiPo charger for years and it worked great. However, a while ago, I started having problems with one particular battery - a 2200mAh 3-cell. During charge, I would regularly get the message: CELLS NO ADD UP.
I figured that particular battery was going bad, so I took it out of rotation. But then I started to have the same problem with another battery. And then another. And another.
At first it was just my larger batteries - 2200's and up. But eventually it started showing up on smaller batteries (eg 850mAh) as well.
Sometimes, I wouldn't get an error. Sometimes, I'd only get it once and, once I'd reset, the battery would charge. Sometimes, I got the error every minute or so.
Errors seemed less frequent if I charged at a really low rate. (such as charging my 2800's at <1Amp)
All of these batteries still charged without incident on my crappy old Passport LiPo charger.
I contacted Revolectrix and related my problem. This is the response I got:
Try cleaning the header pins on the charger and on the adapter. You can buff all the exposed pins with an emory board until you see a shine followed by some contact cleaner. This normally fixes this issue 95% of the time.
I'm happy to report that this worked great - although I did have to destroy one of my wife's emery boards by cutting it into strips tiny enough to fit into the socket and buff the pins.
Old 03-17-2018, 02:31 AM
Guess it's time to clean mine up too.
Don Sims is online now
Old 03-17-2018, 04:26 AM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Hmmmm.... I wonder if that's what's wrong with my old CellPro 10S. It always reports the IR on cell 3 as being extremely high. The first time it happened I condemned that pack, cut the leads off it and tossed it out on the driveway in case it cooked off. After charging a few more packs and getting the same result I saw how stupid I was to render what was likely a perfectly good pack useless since I cut the leads off so short. Hopefully will get some time this weekend to drag the beast out and clean up all the terminals.
Thanks for the post! Good info!
Joe
Turbojoe is offline
Old 03-17-2018, 04:54 AM
Best of luck. Fortunately for me, I'd only marked a couple of LiPos with "No Fly," but kept them around for quick servo testing, etc. So I was able to put them back in rotation once I figured out where the problem lay.
I would occasionally get other errors - e.g. CELL OVERVOLT. So far, I haven't had a single problem since cleaning the contacts.
ripacheco
08-13-2016 11:35 AM
soarrich
11
02-28-2014 01:55 AM
14
10-29-2012 03:20 PM
Howard Matos
FMA Direct
10-25-2011 07:03 AM
Howard Matos
FMA Direct
07-28-2011 02:04 PM
Quick Reply: SOLVED: CellPro charger won't charge - CELLS NO ADD UP error
Page generated in 0.06496 seconds with 13 queries
