H-King High Performance Paramotor - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-30-2019, 07:22 AM
GBLynden
Default H-King High Performance Paramotor
I am not sure where to post this, so I will try in here. Here is footage of the new H-King Paramotor in action. It is my maiden flight video!
This is my Unboxing:
This is my Maiden Flight:
This is my Second Flight with amazing scenery!
The HobbyKing™ Paramotor is extremely easy to fly due to its very gentle and stable flight characteristics yet once you are used to it, it will perform loops and rolls with ease. Due to the design the huge high performance 2400mm sail opens quickly for easy launching and it will retain its shape even in turbulence. The single skin durable sail is made from 100% ripstop fabric and comes pre-rigged with tough polyethylene lines and ready to attach to the durable aluminum gondola. It does require a computer radio with mixing and servo control curves, to see what is involved in the radio set up please watch the attached video and also the one for the setting up of the parafoil itself.
There is a high level of prefabrication so assembly time is minimal and it is Plug-N-Fly so all you require is your own transmitter, receiver, and battery. The Paramotor is fitted with a powerful 3530-1400KV brushless motor swinging a 10 x 4.7 propeller, it also has a 50 amp electronic speed controller with 5 amp BEC and 2 powerful 15kg high torque metal geared servos. A 3S lipo battery is recommended and it can vary in capacity to suit different flying conditions. The recommended flying weight is 1.6~2.0kg, in light wind conditions it is best to put a lighter battery in to keep near the 1.6kg weight. In windy conditions, it is better to put a heavier battery in to fly around the 2kg mark. The undercarriage is easily removed for hand launching and catching and also for slope soaring.
If you fancy trying something a little different then the HobbyKing™ Paramotor is for you. Great fun to fly without being too challenging and it looks great in the air. Pre-assembled and Plug N Fly also means you can be airborne very quickly after taking delivery.
Features:
• High performance powered parafoil
• Plug and Fly format ( you only require a Tx, Rx and battery)
• High level of prefabrication for quick assembly
• Gentle flight characteristics, however, it can perform loops and rolls
• Removable undercarriage for slope soaring etc
• Durable aluminum airframe
• Wide flying weight range (1.6~2kg)
Specs:
Type: Plug-N-Fly Paramotor
Parasail Span: 2400mm
Motor: 3530-1400KV brushless
Propeller: 10x4.7
ESC: 50amp
BEC: 5amp
Servos: 2 x 15kg high torque metal geared
Flying Weight: 1.6~2kg
Recommended Battery: 3S lipoly (not supplied)
Required:
1 x 3ch or more computer transmitter with mixing and servo control curves
1 x 3ch or more receiver
1 x 3S (11.1v) lipoly battery and charger
GBLynden is offline
ditchit
Foamies
03-30-2017 02:26 PM
Ebay for sale
10-28-2011 04:55 AM
Quick Reply: H-King High Performance Paramotor
Page generated in 0.10569 seconds with 10 queries
