Alleycat- 64mm EDF trainer & fun airplane - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-07-2015, 07:04 PM
pcm10xmode
Default Alleycat- 64mm EDF trainer & fun airplane
"Alleycat" is really an all around plane to fly. What makes it a versatile is the 64 mm EDF and it's lightness. My EDF cost $10.
It will take off verticle(used a stick to hold it up), off a 45 degree table, will takeoff and land twice (due to the twin booms) on a grass runway and best of all, ends up a jet trainer in which I let club members fly it to get the "feel" of a EDF. It has excellent stability, hard to stall out,and lands gentle.
Main point, is that it is capable of teaching "taking off and landing" from a ground surface since there isn't a prop, hence no damage!!!!! It is my "goto" airplane when I want to relax, regardless of the wind speed.
Most EDF's get usually a 2-4 min flight. With proper throttle management, my longest flight has been over 9 min with a 1300 mah battery. Will actually fly on less than 1/3 throttle. Does a nice "high alpha"
The reason the alleycat's (offshoot of the bobcat) superb performance is the design and my angle for the EDF jet. Mine is set at 3 degrees up and 1 degree to the right!!
If you look at it from a vector diagram, there is always an EDF force component acting up and to the right which in flight gives this plane tremendous stability.
Will post video after just joining.
Name:	alleycat EDF 001.JPG
pcm10xmode is offline
Old 01-07-2015, 07:08 PM
pcm10xmode
Default Videos of "alleycat"
https://www.youtube.com/watch?v=spb3RAY-U8k
Notice, it has excellent thrust/weight, it can slow fly, turn on a dime and not stall out. None of my alleycat models has rudder.
Old 01-07-2015, 07:29 PM
pcm10xmode
Default More Videos
https://www.youtube.com/watch?v=JXAqLPW2y-E
I always do a couple of runs to show that I can duplicate the exercise including figure 8's and deadstick.
https://www.youtube.com/watch?v=4Ujhan2XIs4
Takeoff at 1/2 power, goes fast/slow, lands beautiful, what more do you want from an EDF?
I have also designed a number of planes using 64 mm EDF's from flying indoors to dropping a shuttle. Let me know if you would like to see them.
Old 01-07-2015, 07:50 PM
Yes the Alley Cat are a blast to fly here is my scratch built alley cats
http://www.wattflyer.com/forums/show...+build+chellie
Old 01-07-2015, 07:54 PM
https://www.youtube.com/watch?v=mwBEuxIkZY4
jobu
Electric Ducted Fan Jets
12-23-2014 04:16 AM
Joe 1320
06-03-2013 02:53 PM
Joe 1320
15
07-31-2012 07:04 PM
KenSue
12-07-2011 09:17 PM
Opuske
Video Parking lot
09-15-2011 08:58 PM
Quick Reply: Alleycat- 64mm EDF trainer & fun airplane
Page generated in 0.08683 seconds with 14 queries
