A "Screamin Demon" build electric from the ground up - Page 3 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-26-2013, 03:43 AM
Mustang
Mustang's Avatar
Thanks!
Well first the fins and wingtip will be covered with carbon fiber veil. Then the rest of the plane will have tissue applied. Then a dope finish applied so I can keep the airframe as lightweight as possible.
If I were going to do a "woody" the workmanship would have to be better than the paint grade work I did on this one.
Mustang is offline
Old 01-29-2013, 08:02 PM
Mustang
Mustang's Avatar
Now the fin is starting to look like it is part of the wingtip once I got it covered with the carbon fiber. I'll let the VOC's mellow before I go back in to do the other one. I am curious as to the effect of adding the carbon after just the dope had stiffened up the fin quite a bit.
Mustang is offline
Old 02-01-2013, 10:14 PM
Mustang
Mustang's Avatar
Four layer of carbon fiber and we have winglets. I am fairly sure they are more than stiff enough at this point. The second layer probably would have been enough, but just to be sure I did a couple more layers.
Mustang is offline
Old 02-20-2013, 11:58 PM
Mustang
Mustang's Avatar
After many coats of clear with sanding in between, I just got the first coat with pigmented dope done, the finished shape is now a lot easier to picture.
Name:	first coat color.jpg
Mustang is offline
Old 03-04-2013, 07:23 PM
mred
mred's Avatar
That's looking better every time I look at it. I especially like those tip rudders and the way you blended them into the wing. This should look great after you get it finished. Your even getting me wanting to see this thing fly.
Ed
mred is offline
Old 03-04-2013, 11:19 PM
Mustang
Mustang's Avatar
Ed thanks so much for you kind words.
I am very curious as to how it will perform in the air.
I had hoped to be a bit further along but hit a bit of a speed bump with some premixed hobby filler that I used failing under tension. After the butyrate dope shrunk up even though it had several coat of nitrate applied beforehand the filler didn't hold up.
So I am essentially back to the same point I was at in the last picture just as of today.
Mustang is offline
Old 06-11-2013, 10:15 PM
Mustang
Mustang's Avatar
Had to switch to an enamel paint, even traces of the crap filler was causing issues. Got the motor mounted just to check the balance (yes I still have to finish the elevons) but here is how it looks.
Mustang is offline
Old 06-23-2013, 11:27 PM
Mustang
Mustang's Avatar
I have finished shaping the elevons and honed the carbon fiber trailing edges so they are nice and sharp. (too bad I couldn't get the camera to focus better on the TE.)
ID:	169551   Click image for larger version
Mustang is offline
01-09-2017 02:23 AM
hillbillynamedpossum
107
08-26-2013 11:23 PM
marksherlock
Vintage and old timer models
24
02-14-2012 12:11 PM
DrDave
09-27-2011 10:20 PM
Doclove524
09-03-2011 03:04 AM
Quick Reply: A "Screamin Demon" build electric from the ground up
Page generated in 0.06543 seconds with 19 queries
