Air Hogs Titan Conversion Aileron Questions - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-31-2011, 01:51 AM
colby45
Default Air Hogs Titan Conversion Aileron Questions
Hi all,
I just finished my first conversion of an air hogs titan to and EDF style foamy. I'm fairly new to RC, I've been flying for a couple years now. My conversion is Throttle/Elevator/Aileron and I'm seeing that my ailerons don't give me enough control. They're located on the inner wing, and I would like to either extend them, or put another small set of ailerons on the outside of the wing. How can I do this without putting servos further out on my wings? Should I get some long pushrods, or try and extend the current ailerons? Any help or suggestions would be appreciated. Thanks so much!
-Colby
ID:	151380   Click image for larger version
ID:	151381   Click image for larger version
colby45 is offline
Old 07-31-2011, 02:14 AM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
I'd do one of a few things...
Remove the current ailerons, extend the cut to the ends of the wings, and replace with a firmer material, like balsa, or coroplast.
You could use foam, but I'd use a dowel at the leading edge of the aileron, so that it doesn't twist on you.
You could use the control rods to extend down the length of the wing to have more authority on the ailerons.
FlyingMonkey is offline
Old 07-31-2011, 02:18 AM
colby45
Okay thanks for the advice. I think I'll probably stick to foam, because I have it in abundance around the house. Would a wooden dowel do or should I switch to carbon fiber or something of that sort?
colby45 is offline
Old 07-31-2011, 04:01 AM
FlyingMonkey
Flite Test Fan
I've just used wood in the past. Usually just a square dowel from home depot or lowes, about the same thickness of the foam I was using.
Old 07-31-2011, 07:59 PM
norcalwelder
Cutting 5-6" off each wing tip will help a lot, and it doesn't take away very much of the gliding capability. Also, removing some of the dihedral will increase the roll rate.
norcalwelder is offline
Old 07-31-2011, 08:49 PM
tampaflyer
to the skies of tampa
tampaflyer's Avatar
same here... son saw it friday and did some minor re-engineering last night...
this is its final right know, like a trainer or cargo plane.
55mm brushed edf froma diablo.
1250-1600mah 3 cell
nose is magneticall held on. fins are the rudder cut in half.
Name:	ah close.JPG
ID:	151401   Click image for larger version
Name:	ah head on.JPG
ID:	151402   Click image for larger version
ID:	151403   Click image for larger version
ID:	151404   Click image for larger version
tampaflyer is offline
Old 07-31-2011, 09:50 PM
tampaflyer
tampaflyer's Avatar
do you vae a computer radio?
do your elev as elevons(delta) then mix the ail back in.. you would have 4 surfaces tring to roll the plane.
Old 08-01-2011, 12:46 AM
colby45
I've been trying to get creative with the mixing actually, I've got a DX6i. I haven't quite got it perfected but I'm close, and I think that would solve my problem without any need for reconstruction. Thanks for the suggestion!
colby45 is offline
SirSudiSavage
Foamies
108
08-20-2014 07:49 PM
Special Interest Aircraft
01-25-2011 03:05 AM
high flyer1223
01-16-2011 11:42 PM
Giga Shadow
01-04-2011 10:46 AM
Quick Reply: Air Hogs Titan Conversion Aileron Questions
Page generated in 0.06477 seconds with 22 queries
