Servo stuff - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Servo stuff
Old 07-11-2011, 08:16 AM
jap71173
BigWatts.shutterfly.com
jap71173's Avatar
Default Servo stuff
Didn't see a lot of threads on servos so I'm starting this one with my new question.
What application would a "round" servo arm be most useful?
I noticed a round servo arm in the packet on my last order of servos. It's obvious how to use them but not so obvious on why, at least for a newb like myself. Someone please fill me in... thanks!
-John
jap71173 is offline
Old 07-11-2011, 08:32 AM
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
They just show them in the package to make you ask questions. There is no real use for them
I would like to know as well
HeliScRapYard is offline
Old 07-11-2011, 09:00 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
They are useful anywhere a straight arm will work
It gives you more options on what angle to set the connection point at - for offset throws for example or differential or if the splines and/or holes dont line up just perfectly.
But they come in real handy if you need two (or more) linkages connected on one servo with a built-in offset. That way you can use a single servo to drive two ailerons and still have differential. They also come in handy for mechanical retracts, driving nose gear steering and rudder off one servo etc.
The larger ones with no or only a few holes allow you to drill your own holes for 100% custom pivot locations.
Larry3215 is offline
Old 07-11-2011, 04:13 PM
Rodneh
Well said Larry. There are many uses for them, limited only by your own ingenuity.
Rodneh is offline
Old 07-11-2011, 05:58 PM
jap71173
jap71173's Avatar
Yes, thanks Larry... that was a great explanation even i can understand
jap71173 is offline
Old 07-11-2011, 10:28 PM
-John
And, once you've got the proper holes drilled in your "round" servo arm, if it gets in the way, you can always cut off the un-needed parts of the round servo arm. Be sure to saw the parts off, don't use a pair of wire cutters. That can put stress cracks into some of those servo arms.
CrimzonRider
ParkFlyers
04-05-2011 06:30 AM
RCFlyer44
22
03-29-2011 04:55 AM
terrynshed
02-04-2011 08:33 AM
Quick Reply: Servo stuff
Page generated in 0.09468 seconds with 13 queries
