Avistar Glow to Electric conversion Help - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-16-2013, 04:48 AM
Achmed
Achmed's Avatar
Ok, i am trying the advanced posting option.
These pictures show the esc and the receiver secured to a plate which will be mounted to the side of the fuselage. I did it that way for easy disassembly as a unit.
Achmed is offline
Old 04-16-2013, 04:50 AM
Achmed
Achmed's Avatar
1/4" plywood epoxied in for the hold down bolts
Achmed is offline
Old 04-16-2013, 04:52 AM
Achmed
Achmed's Avatar
filled in the cutaways that were in the fuselage for the idle mixture screw and the exhaust. It just makes it look a little better.
Achmed is offline
Old 04-16-2013, 04:58 AM
Achmed
Achmed's Avatar
If someone is planning or doing this conversion don't be afraid to add any weight to the nose of this plane because the previous one i did was tail heavy with the battery all the way forward. I think the electric motor and battery is lighter than the glow engine and fuel tank.
Achmed is offline
Old 04-16-2013, 05:24 AM
The motor plus battery about equal the weight of the glow...
But the battery is a large part of the weight and is behind the firewall instead of in front of it.
Chop the original firewall out, move it forward so the motor does not need standoffs.
Then you can place the battery far enough forward that you can balance the plane without "dead lead"
Might need to go up on battery capacity... but that's useful weight and total weight will be less than leaving the firewall in the original location and having to bolt lead to the front of the firewall.
Old 04-16-2013, 09:37 PM
CNY_Dave
And don't forget the fuel CG is often a bit further back than optimal.
CNY_Dave is offline
tenacious101010
14
08-19-2016 08:36 PM
tenacious101010
Warbird Electrics
13
06-23-2011 12:03 AM
Saddlebum
Pattern aircraft
19
05-01-2011 01:55 PM
racerxwest
02-24-2011 09:04 PM
hybrid
01-23-2011 09:43 PM
Quick Reply: Avistar Glow to Electric conversion Help
Page generated in 0.06929 seconds with 14 queries
