Klimaxx 3D Foamy - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Klimaxx 3D Foamy
Old 01-31-2009, 08:57 PM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Default Klimaxx 3D Foamy
Here's my newest 3D foamie. EPS foam core milled and cored with 2mm sheeting and some carbon tube reinforcements. There is no twist at all in the tailfeather area. That's one of the tests in this model-see how stiff I can make it. Something about a flexy foamie that drives me nuts. My flying needs all the help it can get and I don't need to watch the tail surfaces flex, especially in a hover. Need to finish off the paint job with some more red and black on the fuse. Also milling out a battery recess. The ESC is hidden behind the firewall. Nothing like a bunch of unsightly wires and junk hanging off the fuse. Keeps most of it tucked away from sight. More later....
Specs:
40" WS
18oz. AUW
MicroDan 2510-3D/ GWS 11 x 7 DD prop
Fusion-Pack 11.1v 1300mah 25c
4 x Futaba 3114's
Jason
Name:	Klimaxx 3D mockup.JPG
ID:	92215   Click image for larger version
Name:	Klimaxx 3D mockup 2.JPG
ID:	92216   Click image for larger version
Name:	Klimaxx 3D mockup 4.JPG
ID:	92217   Click image for larger version
Name:	Klimaxx 3D underside.JPG
ID:	92218   Click image for larger version
Name:	Klimaxx 3D paint progress.JPG
Name:	Klimaxx 3D paint progress 2JPG.jpg
EDFrules is offline
Old 01-31-2009, 11:50 PM
son of alpea42
3D Crazy
son of alpea42's Avatar
cool Jason
son of alpea42 is offline
Old 02-01-2009, 12:30 AM
EDFrules
EDFrules's Avatar
Thanks Son of Alpea. Got some more paint to add to the fuse, red on top and some black on bottom. Then sharpie details. More pics later. Got to get some more done before the big game tommorrow...
EDIT: Here's a pic of the stab reinforcements I promised. Maybe overkill but it ain't gonna flex too much! Highly recommended for 40"+ sized foamies. Doesn't add that much weight and it beats watching your stab flex in the propwash. Only added about 3-4grams with tube and rod stock/glue. Some balsa triangle stock is a good idea for the TE of fixed stab and rudder too. Small dia. rods slotted into both sides. Also recommend micro pin hinges as well for 6mm+ depron foamies. Good luck and keep 'em flyin'!
Name:	Klimaxx 3D stab carbon reinforcements.jpg
EDFrules is offline
Old 02-05-2009, 01:31 AM
EDFrules
EDFrules's Avatar
Default Klimaxx 3D paint job
All painted up, now time for equipment.
Name:	Klimaxx 3D paint job.JPG
ID:	92616   Click image for larger version
Name:	Klimaxx 3D paint job 1JPG.jpg
ID:	92617   Click image for larger version
Name:	Kilmaxx 3D paint job 2.JPG
EDFrules is offline
Old 02-09-2009, 08:23 PM
EDFrules
EDFrules's Avatar
Default Klimaxx 3D finished!
Got equipment installed and went for a test flight. That almost turned out bad. ESC couldn't handle 4 servos at once and lost RX for a few seconds. Fortunately got back power and landed real quick. Doooh! Ordered a UBEC to power servos so will have to wait for it to show up to do some flight testing. Also ordered some Rhino 1350 3s 25c packs to try out. Great price so I won't be too sad when they finally go flat and have to chuck them. More later...
Name:	Klimaxx 3D finished 1.JPG
ID:	93111   Click image for larger version
Name:	Klimaxx 3D finished 5.JPG
ID:	93112   Click image for larger version
Name:	Klimaxx 3D finished 6JPG.jpg
ID:	93113   Click image for larger version
Name:	Klimaxx 3D finished 7JPG.jpg
EDFrules is offline
Old 02-22-2009, 01:12 AM
griffindor
Lt. Allen Zheng
griffindor's Avatar
that looks awesome!
griffindor is offline
Old 02-22-2009, 01:13 AM
griffindor
Lt. Allen Zheng
griffindor's Avatar
You built it?
Old 02-22-2009, 01:36 AM
EDFrules
EDFrules's Avatar
Thanks for the kind words, Griffindor. Hard to believe I know, but yes I built it! It's 5/8" EPS foam core milled and holed for some weight savings skinned with 2mm depron. Might have to shift the motor mount aft and maybe loose some area in the fuse or wings after testing. Still waiting on HC to send my packs and UBEC(where are they dangit? Been long enough...)Should have the rest of my equipment next week so I'll be able to do some flight testing. Got a quickie in before the ESC cut out-won't take the servo load. Oh well, I like a little more voltage to my servos for faster response anyway. Been shooting 6v to the last Clik and Bipe-X and it makes them that much more responsive. Worth the few extra grams over regular 4.8v power.
EDFrules is offline
GreenAce92
3D Flying
25
08-19-2008 11:59 PM
Chad
17
04-04-2008 06:50 PM
Flytoolow
General RC E-Heli Talk
10
05-11-2006 01:14 AM
SkyPilot
Foamies
04-01-2006 09:24 PM
steph280
Events, Shows and Fun Fly's - Electric Airplanes
08-03-2005 07:14 PM
Quick Reply: Klimaxx 3D Foamy
Page generated in 0.06862 seconds with 27 queries
