Watt's an example of a plane needing 12 channels? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-18-2009, 02:07 AM
Question Watt's an example of a plane needing 12 channels?
I am lucky to use four:o
Old 01-18-2009, 02:21 AM
Twmaster
Registered User
Twmaster's Avatar
Thing big competition airplanes with separate servos on each elevator half, each aileron and flap, throttle, choke, rudder, landing gear, smoke.....
There's 12.
Twmaster is offline
Old 01-18-2009, 02:22 AM
Rick Rotorhead
Hmmm, twin Ail servos (mixed, not a Y lead) ,Elv ,Rudd, throt, retracts, camera actuator, toffee bomb bay, airbrakes, needle valve adjust if Nitro powered, tow hitch release (for glider tug work), separate inboard flaps = 12
There ya go. I bet you could add some more with a bit of thinking.
Rick Rotorhead is offline
Old 01-18-2009, 05:04 AM
gyrocptr
Many of the large planes may use/gang 2 (or more) servos on each aileron, each elevator half, and the rudder. So... 2 x 5, plus throttle, plus retracts (or smoke, or flaps) => 12. Using separate channels, allow matching of center and endpoints for each of the ganged servos. Otherwise, you need a separate set of electronics (e.g. "ServoEqualizer") to synchronize the ganged servos.
gyrocptr is offline
Old 01-18-2009, 05:10 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Actually some of the larger scale models use two receivers to be able to handle all the needs. Think four motors like on the B-29 that Mac Hodges flew. And the two receivers provides some protection in case one side fails, the other receiver can still fly the airplane.
Rabbitcreekok is offline
Old 01-18-2009, 05:24 AM
jooNorway
One of my sailplanes:
- Left aileron
- Left flaps
- Left airbrake
- Right aileron
- Right flaps
- Right airbrake
- Elevator
- Rudder
- Retract
- Wheel brake
- Tow release
- Vario
Lucky it don`t have double ailerons (like Ventus), water ballast etc... Thus it all can be programmed using my radio, don`t have to parallell anything or rely on servo-programmers!
jooNorway is offline
Old 01-18-2009, 01:35 PM
Jim, actually the Hodges B-29 uses 7 JR 945 PCM Dual Conversion receivers, 20 Futaba 5301 Servos and 16 separate battery packs. I'd love to see a schematic of it to see how it is all wired up. I do know what each wing is independent and requires no wiring connection to the fuse when attached. So in reality there are three complete separate systems controlling the plane
http://hodgeshobbies.com/index.php?o...7&limitstart=2
Old 01-18-2009, 01:41 PM
Man, That's serious!
Old 01-18-2009, 01:46 PM
ain't it though?! It is awesome to see it fly for sure!
Old 01-22-2009, 02:39 AM
IFlyTailies
aka Schleppmeister
IFlyTailies's Avatar
it was awesome!
[media]http://www.metacafe.com/watch/1012046/giant_b_29_rc_warbird_with_bell_x_1_rocket/[/media]
http://iflytailies.jimdo.com/
IFlyTailies is offline
Old 01-22-2009, 05:00 AM
Xpress..
Team Hitec, CSR
Xpress..'s Avatar
Hummm...
Primary 4 functions
Flaps
Retracts
Bomb Drop
Wing folding
Ignition switch
Smoke system
Canopy operaton
Ejector seat
Xpress.. is offline
Old 01-23-2009, 10:18 AM
My planes range from 2 channel to 7 channels in use today, but I have one that could go further. I have a Ventus 2C scale glider that is set-up for aerotow.
Today:
Ailerons - 2
Elevator -1
Rudder - 1
Flaps - 2
Tow release - 1
Yet to be connected:
Spoilers - 2
Future?
Landing Gear - 1
That would take me to 10.
Then I could add a scale canopy that would open and close from a switch - cool factor.
Then I could add some kind of drop - streamers, or a parachute guy or a smoke generator - Crowd Pleaser.
That would be 12.
But I only have a 9 channel radio so I am not in a rush to get beyond 9.
AEAJR is offline
cougar33
Batteries & Chargers
14
11-20-2008 08:15 PM
Damp Rabbit
ParkFlyers
14
09-26-2008 11:05 PM
bigdumbdane
06-19-2007 02:04 AM
neu
07-28-2006 01:24 PM
cigarslicer
12-21-2005 06:53 AM
Quick Reply: Watt's an example of a plane needing 12 channels?
Page generated in 0.11232 seconds with 13 queries
