Why cant I just use this brushless kit with the 4#3b? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Micro Sized Electric Helicopters Discuss micro and mini sized electric rc helis in here
Old 01-13-2009, 03:34 AM
cardriverx
Default Why cant I just use this brushless kit with the 4#3b?
***.rc-fever.com/walkera-43b-brushless-upgrade-accessory-11000kv-brushless-motor-10a-esc-p-5702.html
(replace stars with www)
Why do I need to get the kit with the new receiver and tail motor if my old one is fine?
cardriverx is offline
Old 01-13-2009, 08:15 AM
Twmaster
Registered User
Twmaster's Avatar
Because your original setup is not brushless compatible.
Twmaster is offline
Old 01-13-2009, 07:04 PM
cardriverx
but the reciever that comes with the kit is the same reciever thats on the heli already?
Old 01-13-2009, 07:05 PM
cardriverx
oh wait is the regular one the 2406 and the brushless the 2406a?
Old 01-13-2009, 07:06 PM
cardriverx
IDEA: What if I just get the kit linked (much cheaper than the 4#3 spec kit), and one of these http://wowhobbies.com/thesteveblsing...converter.aspx
That way I dont need the expensive walkera kit with the receiver.
Old 01-14-2009, 02:57 PM
bassplayinDude
Yes, the new Rx is the 2406a.
bassplayinDude is offline
Old 01-14-2009, 05:03 PM
cardriverx
What about my idea above? use the cheap kit with just the esc and motor, and get one of the steve low speed converter?
Also, on my origional link, it says:
Can I upgrade my current 4#3B by using this motor and ESC only?
Yes, you can do that, however, you need to modify your motor mount (in the main frame), to cut about 1 mm in order to fit the motor
Do I need to order the RX to use this helicopter?
Optional. It is optional parts for you, as you can use your current 4CH 2.4GHz TX to control the new RX.
How come this contradicts what twmaster says?
ehirobo.com
01-12-2009 08:45 AM
cityflyer
Foamies
11-27-2008 04:20 AM
oct2633
Brushless Motor Construction
11
08-05-2008 03:45 AM
oct2633
05-01-2008 05:54 PM
Spaceclam
08-10-2005 06:48 AM
Quick Reply: Why cant I just use this brushless kit with the 4#3b?
Page generated in 0.05871 seconds with 11 queries
