80'' CL-415 CANADAIR prop problems - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-11-2009, 09:36 AM
pappy_69
Default 80'' CL-415 CANADAIR prop problems
Hi everybody !!
I need the electrics guru's advice!
I am building a CL-415 Canadair (waterbomber) and i decided to go Electric.
To power up the system i got 2 Dymond 4260 (600kVa) and the Dymond 60 Plus ESC's.Because of the scale look i would like to use 4 blade props so i got 2 10 x 6 x 4blades.
I installed on one motor and did a test with an analyzer (watt's up from lindinger.au).
(Every reading supposed to be multiplied by 2 since its a 2 engine model).
To my surprise the analyzer showed me only 29Amps and 620Watts.
The final models weight will be 7,5kgr or 16,5lb.
I know a rule of thumps that says that to fly scale and safe in the same time you need something like
200 to 240Watts/kgr or 90W/lb.
The Batteries are 2x3 cell in series of 5000mAh each.
I have a question:
Does anybody knows if 11x6 will do the work based on real experience and NOT a power calculator program?
Calculator showed me 38amps but the real readings are obviously far out!!
pappy_69 is offline
Old 01-11-2009, 09:51 AM
stinkweed007
stinkweed007's Avatar
Wow, that sounds like a cool plane!! definately an eyefull of numbers (well out of my league) but Im sure then the US wakes up this morning, you will get all the help you need. SInce this is a waterbomber, do you plan on carying any payload? I guess the overall weight might play a part in a prop/powerplant recomendation. also what are your projected dimensions?
I want to see this thing when you get it together!
Welcome to WattFlyer!
stinkweed007 is offline
Old 01-11-2009, 10:33 AM
pappy_69
Thank you very much!!
It realy worries me the prop issue!!!
pappy_69 is offline
pappy_69
I know i can put some 2 blades on but it will look realy silly!!!
pappy_69 is offline
Old 01-11-2009, 10:34 AM
pappy_69
You can see the project on
http://www.aeromodelismos.gr/index.p...ic,1925.0.html
Its also in english(up to apoint!!) so you can follow
pappy_69 is offline
Old 02-14-2009, 11:20 AM
ENUT
ENUT's Avatar
I suspect you need more voltage.This airplane is a twin so each motor should produce about 850 watts.What is the motors max working amp's?You will most likely need to go 4s or 5s packs. Good luck,
ENUT
ENUT is offline
meatbomber
12-23-2009 02:26 AM
millet_flyer
Electric Ducted Fan Jets
08-29-2008 05:35 AM
donjiskra
Seaplanes E-Powered
08-06-2008 02:01 PM
Sparky Paul
Seaplanes E-Powered
10-30-2007 04:34 PM
ebreeden
06-27-2006 01:22 AM
Quick Reply: 80'' CL-415 CANADAIR prop problems
Page generated in 0.08637 seconds with 12 queries
