Trainer cord not working anymore - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-30-2008, 03:48 AM
7car7
7car7's Avatar
Default Trainer cord not working anymore
I have a JR XF421 transmiter and a JR Quattro that I use as a trainer.
I have used this set up in the past, about a half year ago was the last time.
I tried to use it yesterday, but the second radio would NOT control the plane. When hit the spring loaded switch, it says TRN, or something like that, so it's recognizing that there's a radio and cord hooked up, but no plane movement.
Any ideas where to start to look for this issue? Batteries are brand new in the slave radio, but I'm not sure if that even maters.
7car7 is offline
Old 11-30-2008, 03:57 AM
Twmaster
Registered User
Twmaster's Avatar
Check the cord first.
Twmaster is offline
Old 11-30-2008, 04:30 AM
7car7
7car7's Avatar
Well, I figured the cord must be good, because my main radio says nothing when hitting the switch if the slave is not plugged in to the cord. But as soon as the slave is plugged in, the master acknowledges it.
7car7 is offline
Old 11-30-2008, 04:35 AM
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
the plug is what does that, not the cord...
do you have an electric meter?
do an ohm test from one end to the other.
FlyingMonkey is offline
Old 11-30-2008, 04:36 AM
FlyingMonkey
Flite Test Fan
I um, guess I should have read that more closely...
I am out of great ideas...
Old 11-30-2008, 04:40 AM
Twmaster
Registered User
Twmaster's Avatar
Plug just the cord in and see what happens.
I still think it's the cord.
Twmaster is offline
Old 11-30-2008, 04:47 AM
7car7
7car7's Avatar
Well, I should have done this first - I switched the crystal from my main radio into the slave, and it does NOT work. I obviously have an issue with the slave radio itself. This was my first radio, and I've never had an issue. Wierd.
SO, I guess I've got a different issue.
7car7 is offline
Old 11-30-2008, 04:50 AM
Twmaster
Registered User
Twmaster's Avatar
Indeed. Odd.
Twmaster is offline
Old 11-30-2008, 11:50 AM
FlyingMonkey
Flite Test Fan
I know with the DX7, I have to go into the menu and tell it to go to trainer mode...
Old 11-30-2008, 05:10 PM
Twmaster
Registered User
Twmaster's Avatar
I didn't on my DX7. Although there are two trainer modes to pick from on the DX7. One where all it does is transmit stick positions and the other where all mixes and switch positions get sent to the master TX.
Twmaster is offline
Old 12-01-2008, 01:07 AM
Dorsal
If it Flies, I love it!
Dorsal's Avatar
I think maybe you have drained all the electrons out of your trainer cord and just need to buy a new one. Or maybe they all leaked out from the metal ends that were exposed to the light of the full moon.
(That's why I always wear my aluminum foil hat when I'm flying at night, y'know.)
Dorsal is offline
Old 12-01-2008, 06:06 AM
Rabbitcreekok
Rabbitcreekok's Avatar
I know you said the batteries were brand new, buy check them anyway. JR slave radios must have working batteries to work as a trainer box. They don't have to be turned on, just have charged batteries.
Rabbitcreekok is offline
Old 12-01-2008, 07:18 PM
7car7
7car7's Avatar
Batteries checked out great, brand new power. I litterally checked each one (they're AA's) on a meter. The light meter on the radio says full charge.
This is no longer a trainer cord issue. The old radio does NOT control the plane at all - no twitch, no nothing. It's like the sticks are not sending any signal at all.
I kinda wonder if a plug came loose inside, but I'm not sure that's even possible without prior damage - wich it does not have.
7car7 is offline
Lump
08-04-2008 04:47 AM
goofeyfoot
04-08-2008 10:19 PM
Jetnfast
02-26-2008 02:52 AM
EpoweredRc
8
12-04-2007 04:23 AM
Solid Hit
06-27-2007 07:22 PM
Quick Reply: Trainer cord not working anymore
Page generated in 0.07237 seconds with 13 queries
