NEW Mini Super Cub - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
NEW Mini Super Cub
Old 01-10-2009, 05:23 PM
Mr. Baggins
Goofball
Mr. Baggins's Avatar
Hey sparx,
Where you guys fly in Tucson? I'm in town and loking for anything happening in the next week.
Bill
Mr. Baggins is offline
Old 01-15-2009, 04:54 PM
Gohmer
Banned
Smile Brushless Conversion
I converted mine to 2.4 and brushless. Never liked that wierd throttle on the TX, or having to extend the antenna and keep from bending it. I'm flying it now with my Vapor tx.
Blackdogrc.com C20 motor, Castle 9a esc, ar6100 rx, Blackdogrc 8g servo's, stock battery. End pin connector rx would work better than the side pin one I used.
For a motor mount I cut a 1 3/4" circle out of 1/2" plywood with a hole saw. Screwed that to the firewall with the stock gear box screws then mounted the C20 motor to the plywood. You need to make the hole for the prop shaft in the cowl bigger.
Mine was very tail heavy stock, and also after the conversion. CG of 1.25" behind the le works best for me.
Gohmer is offline
Old 01-15-2009, 05:01 PM
sparx
Beginner
Originally Posted by Mr. Baggins View Post
Hey sparx,
Bill
I just fly up near Oracle where land has been cleared to build new homes, which are not being built.
Ten minutes from home.
sparx
sparx is offline
Old 01-15-2009, 06:36 PM
fishingdan
Gohmer, what kind of range are you getting out of the vapor tx in that situation?
fishingdan is offline
Old 01-15-2009, 06:59 PM
Gohmer
Banned
Smile Range
I haven't tested it for maximum range. 75 yards is about as far away as I let it get. No problems at that distance.
Gohmer is offline
Old 01-15-2009, 08:08 PM
ministeve2003
Class Clown
ministeve2003's Avatar
well, I got my parts, but I haven't had time to put it togeather... anyone have a picture of where the servo's go... I think I'll have to glue them in....
SK
ministeve2003 is offline
Old 01-15-2009, 08:46 PM
Gohmer
Banned
Smile Servo's
SK
I hot glued mine in. Forward one is the elevator. I mounted my esc on the firewall extension below the motor.
ID:	90538   Click image for larger version
ID:	90540   Click image for larger version
Gohmer is offline
pacgod
11-02-2008 05:45 AM
ralph99
10-20-2008 05:40 PM
shawnkilpatrick
12-07-2007 10:22 PM
GreenAce92
ParkFlyers
11
12-05-2007 10:47 PM
stanlazi
ParkFlyers
06-14-2007 12:35 PM
Quick Reply: NEW Mini Super Cub
Page generated in 0.06050 seconds with 17 queries
