Maxford Nieuport 28 ARF - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-10-2010, 06:06 AM
  #76
export!
Default snap!
Thanks for the confirmation. I may be able to get some video but it really is kind of scary when it happens.
The plane torques violently and the prop+prop adapter is really stressed.
Scott
export! is offline
Old 04-10-2010, 03:05 PM
  #77
aramsdell
aramsdell's Avatar
Cool
Yeah it is some wierd and violent outside snap into an inverted spin. Reduce throws or add tons of expo.
aramsdell is offline
Old 11-10-2011, 02:50 AM
  #78
cwolfe
cwolfe's Avatar
I know this is an old thread, but I just ordered this model. Can't wait to do some custom work on it. Great work here!
cwolfe is offline
Old 11-10-2011, 03:15 AM
  #79
aramsdell
aramsdell's Avatar
You'll love it. Mine bit the dust at the NEAT Fair in NY this last Sept. I flew it during the mass warbird launch on Friday. 50 or so warbirds all up at one time. I got cut in half by a fast moving something that I think also made it to the ground in pieces. I have a pair of Williams Bros. wheels with no home now.
If you have enough rough landings then you will be looking for some wheels. I think they are the 2.5 " Williams' Bros. Heavier but so much nicer than the plastic that comes with the arf.
Al
Old 11-10-2011, 03:30 AM
  #80
cwolfe
cwolfe's Avatar
I'm wondering how it flies?
cwolfe is offline
Old 11-10-2011, 03:36 AM
  #81
cwolfe
cwolfe's Avatar
Can't wait to work on this model
cwolfe is offline
Old 11-10-2011, 03:37 AM
  #82
cwolfe
cwolfe's Avatar
Hope to get the CG right.
cwolfe is offline
Old 11-11-2011, 12:22 AM
  #83
aramsdell
aramsdell's Avatar
I found the plane to be fairly forgiving. The wings can eventually warp a little with changes in moisture etc. but it still flew well even then. After 2 years I really had no idea what the wing incidences were supposed to be. I just made everything look symetrical and had washout on the upper wing.
Use low rates on rudder except to taxi. It is EXTREMELY sensitive to large rudder deflection. Take it WAY up high and give it full rudder and you will see what I mean. Be prepared. You will probably be in an inverted spin.....
Balanced properly it will cruise slowly past you and looks so nice.
I programmed in some elevator to throttle compensation. A little down elev.as the throttle advanced. Trimmed to fly level at lower throttle settings.
Great luck !
Al
Old 11-11-2011, 01:16 AM
  #84
cwolfe
cwolfe's Avatar
Thanks Al. Really looking forward to it. I love WWI warbirds. I'm pretty new to RC. I have been mostly doing elec. coversions on Guillows and Dumas kits with some success. My 20" J-3 conversion turned out well. She's flies great on 3ch, but I have to wait for dead calm to get her out. My first plane was a PZ Micro Corsair. Yeah, 30 secs Smash, but eventually did get some time on it before the final smash. It's guts are in the 20" J-3. I recently bought a 28" EPO J-3 from HobbyKing and have been learning on it. A nose rebuild later and I'm getting the hang of it. I also have a 24" Guillows Cessna build going on and a 24" Guillows laser cut Thomas Morse on the shelf. I plan to take my time on the Nieuport 28 and get some more experience before she gets the maiden. Thanks again, Curtis
cwolfe is offline
Old 11-11-2011, 07:27 AM
  #85
Kmot
Kmot's Avatar
Hi Curtis,
You are aware, I presume, that the subject model of this thread has been superceded and the small N28 that Maxford now sells is an entirely new and different model?
If in fact you have the all creme colored, older version than what has been posted in this thread should be helpful to you. I only flew mine on one day, actually. I posted about the maiden in this thread somewhere. As I recall it flew well enough but I needed to make some adjustments to the CG and control throws. I have never flown it again, it just hangs from the ceiling of my shop, looking good like a static scale model.
Kmot is offline
Old 11-11-2011, 03:59 PM
  #86
cwolfe
cwolfe's Avatar
The one I ordered is the discontinued 33" model. Which I believe is the one you have here.
cwolfe is offline
Old 05-18-2015, 03:18 PM
  #87
recovered
Originally Posted by Glacier Girl View Post
Got a bud who has one.
MAKE 100% sure it's CG is nose heavy for first flight!!!
You must use rudder and ailerons for turns, to keep the nose from dropping.
Has a nasty snap to it if you let it slow down too much.
And like most you need to fly it all the way to the ground, too slow and it tends to nose over.
You are so right! Had a Nieuport 28 that crashed after nose weight fell off! I had 5 perfect flights before that. I'm going to use lead shot in the cowl so I don't have that problem on next plane! Also going to epoxy lead weights inside engine box close to the firewall.
recovered is offline
Old 05-18-2015, 04:59 PM
  #88
Its a really old thread ... but no worries ...
Here's my N28 from the 1980's ... I placed 8th in Southern England Scale with her .... from the OK Models, Pilot Model Co kit ...
Merco 60 Glow motor, JR Propo radio ...
An absolute pig on the ground !! But that's due to the very short nose to wheel distance and long tail arm on her. Ground looping and tip dragging was everytime ! Except the day of competition !!
I have the plans for her ... one day I might build another ... 'sucker for punishment !' ....
But a beautiful looking model ... flies superb ... but oh that ground handling !!
simibill
WWI Era
19
06-02-2009 05:00 AM
delsol
WWI Era
12
07-10-2008 05:22 PM
Hodakaguy
Scale E-Powered Aircraft
19
06-15-2008 07:18 PM
Capt Easy
05-12-2008 07:37 PM
Gnascher
09-25-2007 12:06 PM
Quick Reply: Maxford Nieuport 28 ARF
Page generated in 0.07363 seconds with 12 queries
