Flycam one 2 recording problems?? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-20-2008, 10:50 PM
The Punisher
Question Flycam one 2 recording problems??
For some reason when i record, the footage only records for a couple of minutes then the flycam one 2 shuts off??
I record on v r , also tried v e.
The battery was charged for about 4 to 5 hrs.
Fitted with flycam 2gb memory card. I have tried it fitted on both electric aircraft and glow powered aircraft.
Any suggestions why it should shut down after about 2 mins
The Punisher is offline
Old 09-21-2008, 07:03 AM
Ben D wing
Ben D wing's Avatar
Ditto, mine too! Also, if I use the cam in my hand it works in all of the modes ok. If I mount it on my Funjet and film whilst flying, it seems to record in multi frame mode. Could this because the Flycam is mounted very close to the Rx and getting pulsed interference?
Ben D wing is offline
Old 09-21-2008, 08:12 AM
Lazy Bee
I'd rather be flying!
Lazy Bee's Avatar
Punisher, I have not used mine for awhile, & sometimes my memory does strange things, but I had the same shutdown problem & seemed to figure out that the camera had to have the power on while connected to the computer in order to fully charge, or maybe even to charge at all. I think what was happening in my case was that the battery only had enough juice to run a short time.
Sorry Ben D, but I don't have any clues about your issues.
Lazy Bee is offline
Old 09-21-2008, 10:48 AM
Ben D wing
Ben D wing's Avatar
If the camera is used without mounting it to a plane (ie. flying it) it functions perfectly. As it is all solid state circuitry surely it can't be movement sensitive, although I am still wondering if it is affected by being mounted too close to the Rx.
I think I will try it on the Cularis next as it can be mounted a fair way from any electronics that may cause interference.
Old 09-21-2008, 08:19 PM
Lazy Bee
Lazy Bee's Avatar
Come to think of it, I think I've gotten the best results when mounted on a 1/5 scale Cub wing. I've used it some on a slo-stik, mounted in center near rcvr., but have had stopping issues there.
As for the charging, as I said earlier, my memory is lacking. I'm thinking now maybe what is important is that PC is on the display when charging. Sometimes that doesn't seem to be a problem (it goes to it automatically), but sometimes in the past it seemed as though I had to put it in PC mode before connecting. I'm really not sure. Maybe soemone who knows or can help will chime in.
Lazy Bee is offline
Old 02-16-2009, 11:13 AM
adent
I've also had this problem with fly cam one II, that it shuts down. I read
about a solution for the problem, I havn't tried it myself, but I think it should help. The camera came with a mount, on that mount is four connector-pins. Two of theese are ground and +5V. If you connect an external battery there, it seems like the camera does not shut off.
If you connect the camera to the ESC/BEC make sure it can supply the 300-400 mA needed (mine got really really warm, so not to good).
//Mikael
adent is offline
Old 02-19-2009, 08:28 PM
nascarwings
nascarwings's Avatar
i had one..its in the old junk bin now i gave up on it...a 15 dollar cam from wallmart takes as good video...i do know one proplem is that when the li-po battery gets cold it will shut down...
nascarwings is offline
Old 02-19-2009, 08:38 PM
groundrushesup
groundrushesup's Avatar
All around I feel like I got ripped on the FCONE2. I have similar problems with the premature shutoff - Also the most maddening thing is the out-of-sync audio even with a super-fast Sandisk X3 card with well over the recommended read/write speeds.
And the aperture is so tiny that filming in any condition other than midday sun creates contrast issues with the video.
So, I don't use it too much. I'm looking into an AIPTEK HD gun-grip type cam - weightier, but I have seen lots of excellent video shot with them.
groundrushesup is offline
Old 02-19-2009, 09:13 PM
nascarwings
you put it in a nut shell..lol...the cam is a ripoff...i picked this one up at walmart in Orlando FL in Dec and am having good luck with it"s DXG 569V Silver Ultra-Slim HD Digital Camcorder it hates any bad vibrations and likes lots of light but the video is great!!
Old 02-20-2009, 12:09 AM
Sabrehawk
Sabrehawk's Avatar
Smile
These reports from ya'all and others on this is why I havent went for it yet, and have stuck with the first one they produced which has worked flawlessly since I've had it.
Sabrehawk is offline
Old 02-20-2009, 12:34 AM
nascarwings
smart man...
Old 05-24-2009, 03:37 PM
redflyier1993 (youtube)
Exclamation Flycam1 2
I have the same prob, Guys, im gonnat soon take it back to the shop, i have already emaild the main company, but no reply yet.
Yeah mine starts to record for a while the no warning turns off, bery annoying especially when im waisting fule trying to wet it to work on my panic bi-plane. URGGGhh
Dose anyone know any new news about this probem ??
Thanks, there are vids of my plane flying on youtube (copy and past my name into the search bar) This is befor all this crap started happening. Also i have the same audio prob as in one of the vids, you hear the motor start then like 10 sec later it starts moving on the screen. Very annoying. at the moment im using my Hd camera to film it in the sky, But it cant being in the acbeat the actual thing.
Owell
Thanks Curtis
redflyier1993 (youtube) is offline
Old 05-24-2009, 04:02 PM
adent
Try to feed external voltage as I mentioned earlier. And the lag between audio and video can be because the SD-card you are using is to slow (==cheap) Try a faster card.
adent is offline
Old 05-24-2009, 04:04 PM
Default probs with flycam one2
Thanks, mate
Old 07-09-2014, 01:48 PM
JeffMowery
Default FLYCAM Planet Camera Steady Rig
I am using Flycam products from last 2 years. Haven't faced any problem with it so far. They perform pretty good and am highly satisfied with their performance and results.
I own a hand held stabilizer Flycam Planet Rig which is a combo of a stabilizer and a fig rig. Pretty efficient in giving low angle shots and all other sort of shots which made my videos free from all type of unwanted shakes.
http://www.dvcity.com/dvshop/FLYCAM-...CM-PLANET.html
https://www.youtube.com/watch?v=m3zOwFKdpUA
JeffMowery is offline
donjiskra
06-25-2013 06:44 PM
Crash9
Aerial Photography
01-10-2008 06:59 PM
GreenAce92
Aerial Photography
08-21-2007 07:44 PM
k-vette
Flight Simulators
02-11-2006 09:57 PM
Diego642
Flight Simulators
12-21-2005 06:15 AM
Quick Reply: Flycam one 2 recording problems??
Page generated in 0.08202 seconds with 13 queries
