OOPS! battery tray problems - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-25-2008, 07:03 PM
jonloe
i are is help you
jonloe's Avatar
Default OOPS! battery tray problems
ok so i feel like an idiot. i crashed my new corsair on her maiden, nothing bad a few scratches in the paint job but thats it ( curse those high weeds) , wellll at least until i inspected it better. the motor mount was loose, so i pulled it out slopped some glue in and taped the motor in place and let it dry. the next day i picked her up, the motor was nice and strong, so i turn her over to take the battery out and charge it WOOPS I LEFT THE BATTERY IN!!!!!!
i grab it and pull. nothing. there must have been a slight crack in the battery tray, as my battery is now glued in place. ive tried slipping an exacto knife around it, but theirs glue all over, as i left it drying with the nose up. so i have no ideas how to get the battery out any suggestions?
thanks for the help,
jon
jonloe is offline
Old 08-25-2008, 07:53 PM
eflight-ray
eflight-ray's Avatar
If the battery wont come out of the tray, can you get the tray out of the model? even if it means cutting through it.
What glue did you use? (too much of )
eflight-ray is offline
Old 08-25-2008, 08:17 PM
Firestem4
inexorably eccentric
Firestem4's Avatar
cant you use Acetone or something to debond the glue? It wouldnt damage the battery (i, think...anyways) And chisel away at the glue with your exact-o knife?
Firestem4 is offline
Old 08-25-2008, 10:01 PM
jonloe
i are is help you
jonloe's Avatar
well its not really a battery tray, its more of a chunck of foam cut out so my battery can fit, and i highly doubt i could get some debonder here without a massive amount of money and a huge waste of time
any other ideas?
jon
jonloe is offline
Old 08-25-2008, 10:05 PM
You "MAY" get lucky and the heat of the battery (lipo?) might free up the bond with the glue. Fly it!!!!!
Old 08-25-2008, 10:32 PM
jonloe
i are is help you
jonloe's Avatar
nope its a nimh brick. and the glue that i used was that kind that is liquid but it turns into foam as it sets ( im at a loss of words for what its called) would that make a difference?
jon
jonloe is offline
Old 08-25-2008, 11:06 PM
gfdengine204
gfdengine204's Avatar
You mean Gorilla Glue?
gfdengine204 is offline
Old 08-25-2008, 11:13 PM
pd1
Still Learning
pd1's Avatar
You might be able to use a hack saw blade to carefully cut around the battery.
If you can cut the hole wider, you might be able to rock the battery back and forth an loosen it up.
Failing that, pick a place that would be easy to repair. Then cut the foam away so the pack is exposed.
When you get the pack out, re glue the foam back into position.
Hope this helps.
Paul
pd1 is offline
Old 08-25-2008, 11:17 PM
jonloe
i are is help you
jonloe's Avatar
umm its kinda like gorrila glue, exept hungarian off brand
thats a good idea with the hacksaw, i might just go for that. the only problem is that its right behind the motor and im wondering if it would mess with the structural integrety. bu ti think ill try it
jonloe is offline
Old 08-26-2008, 12:30 AM
Firestem4
Firestem4's Avatar
well. if you are using gorilla glue and you can fuss with the weight/CG a little bit. just gorilla glue the structure by the motor...that wont go anywhere afterwards
Old 08-26-2008, 12:42 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Leave it in the airplane, charge it and fly. Since it is NiMH, you don't really have to worry about it bursting into flames.
Rabbitcreekok is offline
Old 08-26-2008, 05:00 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
I had a Tiger Moth that I ended up selling with a 1800 3S lipo for the same reason! Glued that sucker right in there. I flew it 50+ times and Im sure the new owner flew the snot out of it too. I was just careful about charging/storing it.
So, I say leave it be and charge it in the plane! Saves time.
Laine.
lmopar69 is offline
Old 08-26-2008, 06:34 PM
jonloe
i are is help you
jonloe's Avatar
that might be what i will do, but i dont remember the mah of the battery, and am getting a new charger, so thats problably important to know. also i might want to get knew batterys
jonloe is offline
HeliG
E-Flite Helicopters
10
03-30-2008 08:05 PM
adam
Batteries & Chargers
11-21-2007 06:58 PM
Frodo
Beginners - Helis
01-05-2007 08:55 PM
Ron S
02-08-2006 04:55 PM
nova801428
09-10-2005 03:12 AM
Quick Reply: OOPS! battery tray problems
Page generated in 0.06731 seconds with 12 queries
