LCD adaptor for power supply? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-23-2008, 11:47 PM
skylane42
Default LCD adaptor for power supply?
Anyone tried one of these as a power supply for a charger?
http://cgi.ebay.com/AC-POWER-ADAPTER...QQcmdZViewItem
skylane42 is offline
Old 08-24-2008, 02:19 AM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Boy that looks like a good one.
5 Amp 12 Volt supply for less that $15 delivered.
I paid $20 (plus shipping) for mine.
I can't see any reason why that wouldn't work
Heli Jim is offline
Old 08-24-2008, 04:21 AM
rcflyair
I use one very much like it (same specs.) and it works great!
rcflyair is offline
Old 08-24-2008, 05:03 PM
Sir Raleigh
I'm using a Nintendo GameCube power adapter. Although the output is only 3.5 Amps it's still good enough to run my GT Power A6 charger and charge 2200 mAh Lipos and it cost me $5.00 at the Flea Market.
Sir Raleigh is offline
Old 08-25-2008, 02:11 AM
btsai
Did you guys that use one of those make an adapter for your charger plugs or just snip the end and put on a matching connector? Pictures?
btsai is offline
Old 08-25-2008, 04:23 AM
Sir Raleigh
I put a cigarette lighter socket on the power supply and a cigarette lighter plug on the charger. That way I can plug my charger either into the power supply or the cigarette lighter socket in the car. I don't use the alligator clips at all.
Old 08-25-2008, 01:21 PM
skylane42
After wearing my car battery down to the point that it would not start, I try to stay away from using the cigarette plug in or the power plug in my car. That is why the AC power adaptor.
Old 08-25-2008, 03:47 PM
Sir Raleigh
These portable power packs also have a cigarette lighter socket.
I also have a cigarette lighter jack to alligator clips adapter so I can connect directly to my car battery if I want to since the cig lighter socket in the car turns off with the ignition key.
I just thought it would be more convenient to have the cig plug on the end instead of having to fumble around with alligator clips all the time.
Old 08-25-2008, 04:29 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Personally, I'd look for one that is 13.5 volts, instead of 12.0 volts.
However, it should work just fine for you.
Old 08-25-2008, 04:44 PM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
What is an extra 7 watts going to do?
SkunkyMagoo is offline
Old 08-25-2008, 04:59 PM
Lieutenant Loughead
UNCLUB OWNER
It's not about the watts -- it's about the voltage. When you connect your battery charger to a 12-volt car battery, you aren't getting 12.0 volts; you're getting 13.5 volts.
Our chargers have a regulator inside them, which allow higher voltages to be converted to the voltage necessary to charge our LiPos... A fully charged 3s LiPo is going to be roughly 12.5 volts.
Your charger CAN do it, but you're asking it to take 12 volts, and convert it to 12.5 volts (or even higher (maybe 14 volts?), during your 3s LiPo charge cycle). In order to do this, you're going to lose some of your AMP capacity (due to the voltage conversion, the heat dissipated, and other losses in the conversion system).
If you start with a 13.5 volt power supply, the conversion is cleaner -- with much less "waste".
Take a look at this charger (it's one I happen to own). The input voltage range is 11 to 15 volts. If you read the manual, the following statement is included: "Applying less than 11V to the inputs will not be sufficient power to allow the charger to work properly."
If you start with 12.0 volts, and try to convert that to charge a 3s LiPo, your input voltage could (depending on the amps the power supply can deliver) get dragged down below 11 volts... :o
theluckyone17
17
10-17-2010 05:59 AM
JckedUpCustomz
Ebay for sale
09-13-2007 08:14 AM
JckedUpCustomz
New Product Announcements
09-10-2007 07:12 PM
mpotter187
05-08-2007 12:50 AM
buzzadan
Beginners - Helis
05-04-2006 01:39 PM
Quick Reply: LCD adaptor for power supply?
Page generated in 0.05897 seconds with 9 queries
