Flying the Super Cub - Page 7 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-22-2008, 02:12 AM
  #151
CHEECH
IN THRUST WE TRUST
CHEECH's Avatar
Originally Posted by jksecunda View Post
I just went out in the yard and tried to fly the plane with no power. I DID put the battery in the plane. It went about 20ft and went down. It seems balanced, about center of the wing, leans forward a little. Oh well. Easy to get discouraged in this hobby.
Hey Sec. Stop beating yourself up brother. At the same time we are our own hardest critic. I felt the same way when I was crashing time and time again. Its going to happend.
Fly that sucker, figure it out and before you know it you'll be posting some happy endings. I admit at first I was wound a little too tight for this hobby. With the help of freinds here at W.F. I learned to let go a little, and try to enjoy the learning process.
Cheech
P.S. Im yet to release my happy ending. But we will get there.
CHEECH is offline
Old 08-22-2008, 02:30 AM
  #152
dk_aero
dk_aero's Avatar
Originally Posted by BatteriesIncluded View Post
This one looks easier to make and can be done with stuff on hand:
http://www.instructables.com/id/East...d-Speed-Meter/
or you can use the beaufort scale:
http://www.unc.edu/~rowlett/units/scales/beaufort.html
Very cool! Thanks for the link!
dk_aero is offline
Old 08-22-2008, 04:46 PM
  #153
ray54
I will post some pictures as soon as I figure out how
ray54 is offline
Old 08-22-2008, 06:12 PM
  #154
ray54
Here are the Pictures of my super cub do you guy's see any problems the battery is in the plane and the control is on.
ID:	76089   Click image for larger version
ID:	76090   Click image for larger version
ID:	76091   Click image for larger version
ID:	76092   Click image for larger version
ray54 is offline
Old 08-22-2008, 06:15 PM
  #155
Zoo
The Black Baron
Zoo's Avatar
Default looks
Looks good to me..... Now...go out and give em hell!!
Zoo ~~~^..^~~~
Zoo is offline
Old 08-22-2008, 06:21 PM
  #156
Zoo
The Black Baron
Zoo's Avatar
Default wind meter CHEAP & GOOD!
Check this one out man...$39, handheld digital.
http://www.dasdistribution.com/produ...ers/AR-816.htm
Zoo ~~~^..^~~~
Zoo is offline
Old 08-22-2008, 06:32 PM
  #157
Sabrehawk
Sabrehawk's Avatar
Smile
Yeah not bad Zoo, though it still has to be held in the hand and aimed directly into the wind to measure it. One advantage the windtronic from HL has, it can be setup and left alone and reads the wind from any direction and displays all info at the same time.
Hehe, but then it's twice the price.
Sabrehawk is offline
Old 08-22-2008, 07:23 PM
  #158
toons
Who, Me, Fly?
toons's Avatar
Came in late... does this SC have ailerons? If not, I don't see any dihedral in the wings!
toons
toons is offline
Old 08-22-2008, 07:28 PM
  #159
Zoo
The Black Baron
Zoo's Avatar
Default re:
No Tunes...none...and I see you're point Sabrehawk and a good one it is. For the extra scratch I'd go with yours. Can it be attached to your car antennae?
Thanks,
Zoo ~~~^..^~~~
Zoo is offline
Old 08-22-2008, 07:56 PM
  #160
Sabrehawk
Sabrehawk's Avatar
Smile
No Zoo, but it can be attached to any tripod cause it as a threaded hole in the base. I have a mini tripod it's attached to, but a larger one can also be used if needed.
I usually place it on top of my Cherokee where it's up higher and easily visible & checked.
Oh and I was gonna say the same of the wing too, it doesnt look to have much if any dihedral, but not sure why. And a 3 ch ship does need some dihedral for good turning ability.
Old 08-22-2008, 08:01 PM
  #161
toons
Who, Me, Fly?
toons's Avatar
The wing dihedral absolutely must be there for a stock SC to fly...
- toons
toons is offline
Old 08-22-2008, 08:12 PM
  #162
toons
Who, Me, Fly?
toons's Avatar
ray54 -
Your SC wing should look like this...
- toons
toons is offline
Old 08-22-2008, 08:25 PM
  #163
Sabrehawk
Sabrehawk's Avatar
Smile
Hmmmm, I think I see why his wing is flatter, his struts look like string or fishing line drawn up too tight. They dont look like the originals that the SC comes with for sure.
Old 08-22-2008, 08:27 PM
  #164
Fly Time
Ask me how I know
Fly Time's Avatar
Yes, there must be dihedral for a plane to turn effectively with just a rudder. Don't know how you got your wing so flat, but I'll bet it's hard to fly like that.
Fly Time is offline
Old 08-22-2008, 11:42 PM
  #165
dk_aero
dk_aero's Avatar
The CG looks good, but that wing is definitely a problem...
The dihedral of a wing determines the amount of self-correction capability an aircraft has in the roll axis. More dihedral allows more self-correction at the expense of less lift, more drag and less axial rolls. Nevertheless, dihedral is sometimes necessary and is especially important for trainer aircraft.
Remove the wing and set it on the table. With one wing tip down against the table, the other wing tip should angle up above the table. Distance from the table to the high wing tip should be approximately 3 1/2 inches (around 8 degrees dihedral).
Also, check the alignment of the horizontal stabilizer. Mark a spot on the behind the wing saddle at the centerline of the fuselage. Measure from the centerline spot to one of the tips of the stabilizer. Measure from the centerline spot to the other tip of the stabilizer. They should be same (at least within 1/8"). Check that the vertical stabilizer appears aligned with the centerline of the fuselage.
Install the wing on the plane and measure from the left wing tip to the left horizontal stabilizer tip. Now measure from the right wing tip to the right stabilizer tip. Measurements should be the same. These measurements insure that the wing is square with the horizontal stabilizer.
Hope this helps! Hang in there!
~ DK
dk_aero is offline
Old 08-23-2008, 12:03 AM
  #166
Fly Time
Ask me how I know
Fly Time's Avatar
Dihedral is ALWAYS necessary for a plane that has no ailerons. It provides lateral stability and allows the plane to bank when it turns. I'm not saying that it won't fly without dihedral, but it certainly won't fly well.
Fly Time is offline
Old 08-23-2008, 12:40 AM
  #167
dk_aero
dk_aero's Avatar
Correct... if you have no ailerons you gotta have dihedral... Even most trainer type ships that do have ailerons will have some dihedral...
Also note that high wing monoplanes will require less dihedral than low wing monoplanes...
dk_aero is offline
Old 08-23-2008, 01:10 AM
  #168
Sabrehawk
Sabrehawk's Avatar
Smile
Yep, yep my decathalon has dihedral, and it's a 4ch ship. In fact if ya lookat most any full scale plane they too have some.
The more I look at those pics, the more it looks like those wires are pulling it down cause they even look like they are bending down. Especially in the first pic from the left.
Well, gotta go fly I got this 10yr old who's been itching to go out again. So off we go.
Doug, we're going over to Ron Regis park on hwy 169 if yer feeling like it.
But if that's crowded, we'll go to North Meridian park, or maybe Honeydew.
Old 08-23-2008, 04:01 AM
  #169
ray54
I fixed The wing tonight at work. One strut was borken at one end, thats why the fish line. put struts back on with a little hot glue on wing parts wing picks up about 3" now
ray54 is offline
Old 08-23-2008, 08:57 AM
  #170
humboldt guy
humboldt guy's Avatar
Originally Posted by Angler-Hi View Post
Thanks Sabrehawk. I think that one from HL will be about the cheapest one I can find, which is ironic because HL prices have jumped a bit.
thanks for the link Humboldt, but I don't think I want to spend almost $200.00 for a wind meter. I really appreciate the response though friend. Thanks.
How about the entry level one for about 65 bucks? That's what I use.
humboldt guy is offline
Old 08-23-2008, 09:19 AM
  #171
humboldt guy
Phenomenal thread! I don't own a SC, but I'm helping 2 of my friends learn to fly on theirs (I get my stick time on em too). I've learned a lot about the SC and flying in general just on this thread, which was a surprise! Many thanks to my fellow wattheads.And Cheech, I'm nightshift also (helps explain why some of my posts are....strange). My solution is to sleep in the morning, get up early afternoon and go play, sleep again in eve before work. That way I always have some daytime to play in, I consider it a perk actually. Good flying all!
Old 08-23-2008, 10:57 AM
  #172
jksecunda
Jeff
jksecunda's Avatar
Thank you, Thank you(taking a bow). I just wanted to know how to fly my super cub. AND as of yet, still have not had a successful flight(take off and landing). If anyone living in the Fort Wayne Indiana area would like to assist an older rc beginner, it would be most appreciated.
jksecunda is offline
Old 08-23-2008, 12:17 PM
  #173
cbatters
cbatters's Avatar
I know this makes no sense to me but if you dial in down elevator wont it go down when you throw it? When it stalls, it does not necessarly mean that the engine fails, does it? If the engine is not on, then how can it stall? Questions, questions. Whats a flyer to do? I still dont get all the flying verbage.
The wing needs air speed to develop left to stay aloft. If you have too much elevator dialed in, the plane will climb when you throw it but loose air speed and then stall.
The goal of adding down elevator is to have the plane fly level and maintain sufficient air speed to keep from staling.
If you have slightly too much down elevator dialed in you can always pull back a little on the stick. If iyou have too much up elevator dialed in and it pops up and stalls, there is absolutel nothing you can do and it will crash.
If I was standing next to you I would tell you to throw it MUCH harder and level. Practice throwing a broom like a a spear and then do the same throw with the plane.
QUick confirmation: When we talk about hand launching the plane with no engine the radio is on and you have the radio in your other hand ready to use correct?
cbatters is offline
Old 08-23-2008, 12:22 PM
  #174
cbatters
cbatters's Avatar
Did it stall and crash or just glide at the same angle into the ground? If it did not stall then you can either pull back a little on the stick to extend the flight or add one click at a time to the elevator to trim the plane.
Throw it like you are thorowing a football at eye level to someone 40-50' away.
cbatters is offline
Old 08-23-2008, 12:27 PM
  #175
jksecunda
Jeff
jksecunda's Avatar
Yes.
Quick Reply: Flying the Super Cub
Page generated in 0.15471 seconds with 16 queries
