Deans connector and a 12v power supply?? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-08-2008, 09:23 PM
Angler-Hi
Angler-Hi's Avatar
Default Deans connector and a 12v power supply??
I have a 12v power supply that I got from max2112. It has a car lighter adapter on it with visible polarity (red and black wire) from the power supply to the car lighter. I was wanting to cut the red/black wires from the car lighter adapter and solder a deans connector to it. Then I want to cut the alligator clips off my charger and solder a deans connector to it. Then plug the two together. That way I can run my charger off the power supply that plugs into my wall. I would also take the wires with the gator clips and solder them to a deans as well. That way I can charge my batteries at home inside and then hook up the gator clip adapter when I go to the field.
My question is this...would a deans connector hold up to carrying 12v of current?
Here's a few pics of my power supply and charger:
ID:	74818   Click image for larger version
ID:	74819   Click image for larger version
ID:	74820   Click image for larger version
ID:	74821   Click image for larger version
Angler-Hi is offline
Old 08-08-2008, 09:33 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
I have done that with my chargers Mike. I have a Deans connector in the cord and I can either plug a cigarette plug on them or alligator clips. Which ever I need. I've had no problems so far and have 3 Common Sense balancing chargers set up that way.
Grasshopper is offline
Old 08-08-2008, 09:34 PM
max2112
max2112's Avatar
Default Yep.
[quote=Angler-Hi;453919]...would a deans connector hold up to carrying 12v of current?quote]
Sure it will.
Think of it this way:
These are the same battery connectors that we send 11.1 VDC(3 cell LiPo) to an ESC pulling 25 amps. If it can work for 36 inch plane, it'll work for a charger. And the charger will have a lot less amps being pulled by the load.
max2112 is offline
Old 08-08-2008, 09:35 PM
Angler-Hi
Angler-Hi's Avatar
Thanks guys!!! I'm gonna get on it right now. WAHOO!!!!
Old 08-08-2008, 10:30 PM
Rodneh
Which Dean's connector, there are several. If you are speaking of the large two pin plug with one connector with the prongs at right angle to the other, yes. That connector will handle up to 20 amps with no problem. Voltage has no bearing as long as it is less than 120 volts, it is the current that matters. Of course you do not want to have the voltage present when you connect the two connectors if you have a low impedance load on it as you will get arcing that will pit the connectors. Make the connection then turn on the power when using a low impedance load.
Rodneh is offline
Old 08-08-2008, 10:34 PM
Angler-Hi
Angler-Hi's Avatar
Thanks Rod. I just finished up and she works great!! Thanks everyone!
ForestCam
11-09-2012 06:37 PM
theluckyone17
17
10-17-2010 05:59 AM
ORD2FRA
06-17-2009 09:58 PM
simibill
04-13-2008 03:29 PM
paranoia
02-05-2007 09:03 PM
Quick Reply: Deans connector and a 12v power supply??
Page generated in 0.10119 seconds with 18 queries
