Blade Micro CX Coaxial Ultra Micro Heli - Page 7 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-31-2009, 04:04 PM
  #151
Twmaster
Registered User
Twmaster's Avatar
Heh. I was about to suggest the thread return to it's original subject.
If you wish to continue discussion of the other helis please take that to another more appropriate thread/forum.
Twmaster is offline
Old 01-31-2009, 04:15 PM
  #152
caskydog
skydog
caskydog's Avatar
Default switch:
Thanks Mike and will do.
SKYDOG
caskydog is offline
Old 02-01-2009, 05:48 AM
  #153
Twmaster
Registered User
Twmaster's Avatar
Thanks folks.
Well I've been flying the little mCX a couple times each day. I cannot be happier with it. My cat is afraid of it and almost managed to smack it out of the air on a low fly-by!
Wish I'd have bought one when they came out!
Twmaster is offline
Old 02-18-2009, 05:45 AM
  #154
MNfly
Got altitude?
Default 1st time heli pilot
All I can say is that the MCX is tough and a heck of as lot of fun. I had never flown a heli before and in about 6 hours with the MCX and I was flying a friends CX pro. Granted not as well as he does but was doing ok and doing spot landings on a one foot circle, fast figure eights and skid taxi take offs and landings
I have read posts about the MCX being fragile and breaking parts but so far I have only broken the inner shaft blade yoke about 4 times in thwe first four hours and fixed it with epoxy and have broken nothing since. This is not to say I have not whacked the blades and bounced off walls and dropped from ceiling to floor a few times. I think it is pretty tough. It helps to chop the throttle when you are in trouble. It can take the fall.
I would reccomend anyone getting a MCX put some epoxy around and inside the inner shaft yoke where it splits to toughen it up for the for sure blade strikes. and it is obvious to me that this is probably the weakest link in this heli.
I have found that the battery charger batteries will last at least as many charges if not more than advertised and the heli lipo will last about 7 minutes.
All in all I think it is a heck of a little indoor heli.
MNfly is offline
Old 02-18-2009, 06:13 AM
  #155
giddyuperic
This was my first too, But I have been flying planes for about a year now. So I got the mxc bnf and put it on my dx6i I have had this thing for over two months now and I fly the cra$ out of it and I have had no breaking of any thing knock on wood. I have even gone threw a battery. Great bird. I have the MX3 with the lights on the way.
giddyuperic is offline
Old 03-18-2010, 08:40 PM
  #156
Boyracer
Hello to all!
I need your help asap.I have an MCX since a few days and i had no problem at all (except an inner shaft rotor head brake).But i have a serious problem now.I was flying as usual and after a while the heli started to ignore the controls quite offten.The led in the front turned off and on again every 5-10 second for less than 1-2 sec.If i put it on the ground and release the controller,but the helli does the same,inc small movement of the servos.I have tried with a nother battery in the heli and in the controller as well,than rebind it no satis.Any idea??? THANKS
Boyracer is offline
Old 03-19-2010, 06:36 AM
  #157
VamPower
Urban R/C
VamPower's Avatar
Originally Posted by Boyracer View Post
Hello to all!
It sounds like a battery problem. I know you said you tried another battery, but maybe you have 2 bad ones? Or your charger isn't charging them? If you measure battery voltage and it is over 4.0v, then I would say you need to replace the main board.
VamPower is offline
wangilder
09-30-2007 11:16 AM
fastie
06-12-2007 03:49 AM
coldsteel45
05-27-2007 05:51 PM
hobbyshopguy
01-18-2007 04:18 PM
tallflyer
04-13-2006 03:45 PM
Quick Reply: Blade Micro CX Coaxial Ultra Micro Heli
Page generated in 0.09315 seconds with 13 queries
