TURNIGY Multi-F DC Watt Meter 75A - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-13-2008, 04:36 PM
sbrv24
Default TURNIGY Multi-F DC Watt Meter 75A
Hi ,
I recently bought my self the below watt meter :
http://www.hobbycity.com/hobbycity/..._Watt_Meter_75A
I have set it up and treid it on my electric set ups and am sure it would help me a great deal in understanding my set ups eventually but as of Now I am not able to interpret the readings it generates .
I know this is not really a new product on UH and there would be users of the product in the group here , hence I would request so guidance on how to figure out from this meter the following :
1) The current Draw of my Motor Max at full throttle
2) The flying duration of the set up at full throttle
3) Any other info that can be derived from this meter.
Rgds
sai
sbrv24 is offline
Old 07-14-2008, 03:55 PM
eflight-ray
eflight-ray's Avatar
I don't actually have that meter I have the Astro Wattmeter but the information is basically the same.
Mine as all the read-outs in the window at once - Amps, Volts, Watts, Ah, where as the Turnigy seem to have Amps, Volts, Watts, mS, (servo pulse width timing?).
Volts - gives a good indication of the state of your pack, especially if it's a nimh, and also shows just how much the volts drop on full power.
Amps - the important one, they tell you if you are anywhere near the motor and ESC's limit. Always try to stay under that limit. You would probably find cheaper cells give less amps.
Watts - is just Volts x Amps.
mS - just shows the servo output timing, probably useful if setting up without a Tx, but I'm guessing there, have never used or needed that.
Duration, this is theoretical only as too many things change in flight, so it is really more down to the flight characteristics and when the LVC cuts in, i.e. you can't draw all the capacity out of a battery without damaging it so probably 70% is nearer the usable capacity.
Time (minutes) = Battery pack capacity (Amp/Hours*) divided by Motor Currenty (Amps) times 60 (minutes in an hour).
T = Capacity A/Amps x 60
*For the pack, use Amp/Hour instead of milliamp/Hour, 1800mAh = 1.8Ah, 2100mAh = 2.1Ah etc.
The calculation for flight time is almost a waste of time, (pun intended). As the load changes if climbing, diving, doing aerobatics, the LVC, how much the prop unloads when flying as against on the ground etc. Also fitting a bigger capacity battery doesn't always work as the extra weight can spoil the flight depending on the model, especially lightweight ones.
Hope this helps and hasn't confused you too much, the main things to watch are the Amps, (too much lets the 'magic smoke' escape from the electronics ), and most importantly just how well the model itself flies.
eflight-ray is offline
Old 07-14-2008, 04:44 PM
gzsfrk
gzsfrk's Avatar
You've already got this one, sbrv24, so I guess this is a moot point for you. But for anyone else reading, I'd suggest getting the Watts Up! meter for just $4 more (the price is $39 for members who have placed at least one order, so be sure to sign in first if you plan on adding it to your cart). Very easy to use and provides lots of great info. It's one of my favorite tools.
gzsfrk is offline
Old 07-14-2008, 05:29 PM
sbrv24
I went in for this meter only because it has a PCM throttle kinda knob so I can test without the Tx. Does the WATT"S have the same feature ?
sbrv24 is offline
Old 07-14-2008, 05:34 PM
gzsfrk
gzsfrk's Avatar
No, it's just an inline wattage/voltage tester. But it just works great, and is ridiculously easy to use. The PCM throttle IS a nice feature, though.
gzsfrk is offline
Old 08-17-2009, 03:46 PM
netjunky
does the pcm dial give actual full throttle or will you get more out of your transmitter??
netjunky is offline
Old 11-21-2009, 10:06 PM
tiger moth
tiger moth's Avatar
Hi,
Just got one of these Turnigy meters myself.
Yes, it gives full throttle control. Even gives two Pulse Width ranges (I presume for different radio standards)
The meter works as advertised. You can use it inline with your radio controling throttle (just don't plug the ESC into the meter) or on a bench without a radio using the pulse width control. Very nice!
- John
ID:	113816   Click image for larger version
ID:	113817   Click image for larger version
ID:	113818   Click image for larger version
ID:	113819   Click image for larger version
tiger moth is offline
Old 11-22-2009, 08:47 AM
Insomniac
Insomniac's Avatar
One thing to note with the turnigy meter... it does NOT have reverse polarity protection!
Guess how I found that out....
Insomniac is offline
Old 11-22-2009, 01:37 PM
tiger moth
tiger moth's Avatar
Good to know! Thanks for the heads up.
Just be extra careful soldering up your connectors and DON'T use the banana plus that come with the meter! Use a connector that physically cannot be plugged in the wrong way around.
BatteriesIncluded
09-22-2008 01:28 AM
supi7
New Product Announcements
09-18-2008 05:45 AM
supi7
04-25-2008 09:52 AM
claya2
Batteries & Chargers
04-01-2008 09:23 PM
Turbojoe
Scale E-Powered Aircraft
01-29-2006 03:08 AM
Quick Reply: TURNIGY Multi-F DC Watt Meter 75A
Page generated in 0.07389 seconds with 20 queries
