External BEC solve spektrum rx problems?? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-13-2008, 02:28 AM
borgy
Default External BEC solve spektrum rx problems??
Hi Guys,
I lost a plane a while ago, after speaking with the supplier the conclusion was that the esc went up in smoke which momentarily spiked or dropped the voltage to the rx which was a AR6100 causing it to reboot and resulting in a crash. I know of at least three other people who have lost planes from similar causes with Spektrum RX's. My question is would a external BEC like the park BEC prevent this problem from happening again??
Also when flying an aircraft how long should I wait between flights?? I have a Parkzone T28 and I had a stryker until the above incident, I always basically put one battery through it, felt the esc if it wasn't hot I just through another in and kept flying should I be waiting longer??
B
borgy is offline
Old 07-13-2008, 03:11 PM
Ohio AV8TOR
Ohio AV8TOR's Avatar
The ParkBEC is a very good investment and BEC's are becoming the smart move for Spektrum receivers. A linear BEC which is what ESC's have are not up to the task as well as switching BEC's.
Ohio AV8TOR is offline
Old 07-14-2008, 02:38 AM
elcamino
funflyer
on my small foamys 16 oz and under and just useing three small micro servos I have been ok with the bec built into my castle creations speed controls. Any thing bigger than that and i use a seperate bec and I have never had a problem they are cheap insurance.
elcamino is offline
Old 07-14-2008, 03:08 AM
borgy
Thanks thats what I was hoping to hear.
borgy is offline
Old 07-15-2008, 12:34 PM
flypaper 2
flypaper 2's Avatar
Why are you blaming it on the rcvr. when it's the ESC that crapped out. A rcvr. on 72 would have crapped out the same way if the ESC went up in smoke. It's the linear regulator in the ESC that's the problem.
flypaper 2 is offline
jobu
Batteries & Chargers
14
08-29-2008 02:20 AM
jobu
08-27-2008 04:07 AM
constantCrash
07-05-2008 06:26 AM
celticflyer
8
02-17-2008 01:36 AM
NCC1700
03-12-2007 01:34 AM
Quick Reply: External BEC solve spektrum rx problems??
Page generated in 0.08463 seconds with 13 queries
