Build Thread; Mountain Models QF-2 DLG - Page 3 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-22-2008, 11:43 AM
smokejohnson
smokejohnson's Avatar
How's it going Ron?
smokejohnson is offline
Old 07-22-2008, 11:52 AM
Sky Sharkster
Sky Sharkster's Avatar
Default QF II Update
Hi James,
Sorry to say I haven't worked on the glider since I put the dihedral in. I crunched my Corben Super Ace micro and have been repairing it. Should be back to the QF II in a couple of days.
Hi Brian, Thanks for the update on the kits, mine has the full-length spars. Got my Scorpion motor and Rx batteries Saturday, Thanks!
Matt, Welcome to the QF II club! Hope you enjoy the build, it's fun.
I'll be posting here soon, building goes a lot faster if you don't have to stop for repair work!
Ron
Sky Sharkster is offline
Old 07-29-2008, 01:05 PM
Sky Sharkster
Default Hinging The Tail Surfaces
Back to work!
Here's the hinging process for the stab and rudder. Although MM recommends packing tape, I had some clear hinge tape from Hobby-Lobby.com, so that's what I used.
First I sanded the 45 degree bevel on the rudder (yes, I'm left-handed) and elevator.
Wiped the dust off the surfaces, pinned in place.
Put tape on the side away from the bevel.
Done!
Ron
ID:	73968   Click image for larger version
ID:	73969   Click image for larger version
ID:	73970   Click image for larger version
ID:	73971   Click image for larger version
ID:	73973   Click image for larger version
ID:	73974   Click image for larger version
Old 07-30-2008, 01:21 AM
Sky Sharkster
Default More Tail Surfaces
Here's the next step on the tail surfaces; Glue in the ply control horns, for this I used thin CA so it would wick into the small joint.
Then, sand a channel into two pieces of cross-grain strip stock, glue these pieces to the stab and fin. Here I used thick CA ((Medium), these pieces provide a solid mating surface to later attach the tail to the F/G boom.
ID:	74007   Click image for larger version
ID:	74008   Click image for larger version
ID:	74009   Click image for larger version
ID:	74010   Click image for larger version
Old 07-30-2008, 12:10 PM
Sky Sharkster
Default Preparing To Join Tail Surfaces. Boom
The last preparation to the tail surfaces before joining to the boom is to add triangle stock beside the mounting strip. Two pieces alongside the elevator mount and one under the fin block. After I glued these on, I re-shaped the channel by wrapping sandpaper around the boom and using it as a shaped block.
Then, sand the rear 5-5/16" of the boom with wet sandpaper, I used 320 W + D paper. The tape is to mark the length to be sanded. Lots of carbon dust!
Here's the dry-fit of the stab and fin.
Ron
ID:	74041   Click image for larger version
ID:	74042   Click image for larger version
ID:	74043   Click image for larger version
ID:	74044   Click image for larger version
Old 07-31-2008, 11:45 AM
Sky Sharkster
Default Stabilizer To Boom
Here's the stab glued to the boom. I used 30 minute epoxy.
ID:	74157   Click image for larger version
ID:	74158   Click image for larger version
ID:	74159   Click image for larger version
Old 08-01-2008, 03:27 PM
Sky Sharkster
Default Fin/Rudder To Boom
After looking at a couple more photos in the instructions, apparently there's a piece of triangle stock on each side of the fin mounting blocks. It only shows one piece on the first photo, but two later. So I added one, and epoxied the fin to the boom.
The instructions show a nifty method of using aluminum "L" stock to align the fin, but I didn't have any. So I rigged up a 90 degree triangle and eyeballed it. I'll keep checking the alignment until the epoxy cures.
Ron
ID:	74283   Click image for larger version
ID:	74284   Click image for larger version
Old 08-02-2008, 10:04 AM
Sky Sharkster
Default Boom To Nose Pod
Here's photos of the fin-to-boom joint.
Next I sanded the section of the boom that joins with the pod, again 320 W + D paper.
Epoxy the boom into the fuselage.
The pod is weighed down flat and the stab aligned with the board. I also put a 24" ruler across the wing mount to aid the alignment with the stab.
The rear of the boom should be raised 3/16" above the board.
ID:	74312   Click image for larger version
ID:	74313   Click image for larger version
ID:	74314   Click image for larger version
ID:	74315   Click image for larger version
Old 08-03-2008, 01:04 AM
Sky Sharkster
Default Battery Hatch, F/G'ing the Nose
Time to cut the battery hatch away from the nose pod. First I probed to find the join line, then cut it thru with a 45 degree angle. Next, slit the tacked-on hatch loose.
Now, the application of the 2 oz 'glass cloth (also supplied with the kit) and Minwax Poly.
Cut the 2 pieces to size.
Brush on the Minwax.
Done!
ID:	74342   Click image for larger version
ID:	74343   Click image for larger version
ID:	74344   Click image for larger version
ID:	74345   Click image for larger version
ID:	74347   Click image for larger version
Old 08-03-2008, 05:44 PM
Sky Sharkster
Default 2nd Coat
Photos;
(1) After an over-night drying, I trimmed the excess cloth off the nose and hatch. In a few spots it had lifted, generally near the corners and edges.
(2) After brushing on a 2nd coat, I let the Minwax set up a bit, until it started to get tacky. Then I used a scrap of plastic sheet (backing sheet from Microlite) to rub the loose sections back down. I also flattened the tip of the nose, where the overlaps had bubbled up slightly.
Ron
ID:	74373   Click image for larger version
Old 08-08-2008, 11:03 PM
Sky Sharkster
Default Upper Wing Sheeting
After a busy week at work, I finally managed to squeeze in a little work, the upper wing sheeting.
(1) First I trimmed some of the epoxy that had oozed out from the clamps.
A slight step or ledge between the doubler and spar was cleaned up.
(2) And the dihedral joint is shaped up.
(3) After a dry fit, I was disappointed to find a few slots didn't match up with the alignment pegs or "feet" that stick up. Whether this was due to not gluing the ribs in perfectly vertically, the wood swelling and shrinking (it's been alternately hot + dry, then raining here) or plain old poor workmanship on my part (most likely!), it bothered me. So I made a "slot enlarger" by trimming an emery board.
(4) Here's the fit of a couple enlarged holes. Guess I'll have to live with it.
(5) A couple more. There were 5 altogether on the right wing.
(6) Slow CA on the spar. Next I kept pressing/sliding my fingers along the spar/sheeting joint until it was dry.
(7) End view before gluing the front of the sheet to the ribs. I dripped fast CA (from the leading edge) along the rib/sheeting joint while holding the sheet in place. One rib at a time!
(8) Done!
(9) End view of right wing. Although I was wearing goggles, had a window open and a small fan going, the "fast" CA fumes were strong enough to make me glad to be done with one wing.
Ron
ID:	74833   Click image for larger version
ID:	74834   Click image for larger version
ID:	74835   Click image for larger version
ID:	74836   Click image for larger version
ID:	74838   Click image for larger version
ID:	74839   Click image for larger version
ID:	74840   Click image for larger version
Old 08-11-2008, 01:57 AM
Sky Sharkster
Default Left Wing Done, Sanding
Here's the left wing top sheeting, after it dried I sanded the entire wing with # 320 wet or dry, using only a sanding block. The CA leaked through the alignment holes in a few spots.
(1) Medium CA on the spar, next I'll spread it out evenly.
(2) Sheeting glued to spar, but not to ribs, yet.
(3, 4, 5) After gluing all ribs with fast CA and sanding.
ID:	74976   Click image for larger version
ID:	74977   Click image for larger version
ID:	74978   Click image for larger version
ID:	74979   Click image for larger version
Old 08-11-2008, 02:29 AM
  #63
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Looking really great Ron! You do good work. Nice build thread also. I don't think you have left one stone unturned.
Frank
Murocflyer is offline
Old 08-11-2008, 04:17 AM
  #64
smokejohnson
Agreed, nice build and thread. Thanks for sharing Ron.
Old 08-11-2008, 04:29 AM
  #65
Sky Sharkster
Default Thanks, Guys!
To Frank and James. thank you for the kind words. It's not going fast, but sooner or later I'll get this plane done! Haven't had the free time to really keep working on it.
It hasn't been a hard build at all, just a couple of places I didn't understand the directions fully. After I got a few steps along, they became more clear.
Just got my RX batteries in the mail, Hobby-Lobby had one backordered and it came in. Also got a couple extra from Mountain Models.
http://www.mountainmodels.com/produc...d7ebd16580b7a5
Ron
Old 08-14-2008, 01:31 AM
  #66
jb48
Default 3 inch short carbon fuselage?
A friend of mine and me are scratchbuilding each one a QF-2. My friend made a mistake and glued the carbon tube through the second bay from rear, which means that the tail is now about 3 inch nearer the fuselage than the design spec. So instead of a distance of about 20 inch from rear of fuselage to stab, it`s now around 17 inches.
Our question is: Can this «shorter» tail moment can affect the flight caracteristic seriously? What to expect?
jb48 is offline
Old 08-14-2008, 01:58 AM
  #67
Sky Sharkster
Default Short Tail?
Hello JB,
Well, I hate to say it, but the answer is "Yes". It will adversely effect the flying ability. You've modified the "Tail Volume Coefficient".
http://www.djaerotech.com/dj_askjd/d...s/formula.html
The size of the tail surfaces, the length of the tail moment arm, the center of gravity and some other factors (like the wing airfoil, area, tail airfoil) all work together to increase stability, control response, surface deflections and so on.
If you change any one factor (and three inches is a substantial change) you change everything.
I've never flown this design before, but have flown many gliders, from scratch, plans, kits and ARFs. Based on these experiences, I would say the shorter TMA will reduce the pitch stability, stall response, rudder response and lateral stability.
I don't know of a way to (now) increase the boom length without adding unnecessary weight, or making it too weak. At this point the most efficient way to correct this would be to remove the boom from the nose, trying to do as little damage as possible, and re-glue it in the correct location.
Sorry, but that's my best advice!
Ron
Old 08-14-2008, 12:00 PM
  #68
jb48
Thanks for the quick answer Ron. I`ll transmit your comments to my friend who, I think, will make a new fuselage...a one evening proposal for him.
For myself, the building of my own QF-2 is going well, especially considering that I (we) use no kit, a somewhat challenging proposal since the plans sheet drawings are intended for kit building. But with the Paul Daniel`s building manual (around 76 pages) it`s doable. More on that later on.... Thanks again.
jb48 is offline
Old 08-14-2008, 12:35 PM
  #69
Sky Sharkster
Default Build From Scratch?
Hi JB,
I think building a new nose is the best solution, or making the best of a bad situation. I forgot you were building from plans instead of a kit, now you're a real "Scratch" builder!
Here's the beginning of the sequence for adding the leading edge to the wing.
(1) The sheeting is slightly oversize, sorry the first photo is blurred, but you get the idea.
(2) Another shot of the L.E. Sheeting
(3) Here I started cutting the sheet down and bevelling the front edge to mate with the angled L.E. placement. Some builders call this a "Diamond" L.E. I'm only working on a couple of rib bays at a time, starting at the tip.
(4) End view
(5) Bottom view
(6) Top view
ID:	75376   Click image for larger version
ID:	75377   Click image for larger version
ID:	75378   Click image for larger version
ID:	75379   Click image for larger version
Old 08-16-2008, 06:38 PM
  #70
Sky Sharkster
Default Prepping L.E. Sheeting
Another busy work week, but I managed to get in a few hours this morning. After slowly cutting to shape the L.E. sheeting (to accept the "Diamond" L.E.) a few bays at a time, I decided to try a different and hopefully faster method. Is there a tool that will remove long, straight layers of balsa, very thin sections and is easy to control? Why, yes!
(1, 2) Razor plane, shaving off extra material
(3) Right wing L.E. sheet, cut to size
(4) Front view
(5) End view
(6) Bevelling the inside edge of sheet 45 degrees, used an emery board
(7) Top view, L.E. held in place, not glued
(8) Bottom view, not glued
ID:	75524   Click image for larger version
ID:	75525   Click image for larger version
ID:	75526   Click image for larger version
ID:	75527   Click image for larger version
ID:	75529   Click image for larger version
ID:	75530   Click image for larger version
ID:	75531   Click image for larger version
Old 08-16-2008, 07:14 PM
  #71
Sky Sharkster
Default Right Wing done
Here's the right wing L.E. installation.
(1) Rubber bands, glue, wing propped up
(2) Titebond along the L.E. sheet, next I'll even it out with a toothpick
(3) Close-up of one section
(4) Done, let it dry
ID:	75535   Click image for larger version
ID:	75536   Click image for larger version
ID:	75537   Click image for larger version
Old 08-17-2008, 05:15 AM
  #72
jb48
Hi Ron. I have 2 questions for you and/or other QF-2 kit builder(s). Since I am building a QF-2 entirely from scratch and since it will be my very first experience with discus launching glider, I will like to know how long has to be the launching pin glued in the wingtip? Same length top and bottom of the wing?
Another question concerns the rudder and elevator pushrods exit from fuselage: would it be a good idea to direct them (or at least the rudder one) tru the carbon tube? How do you intent to route the pushrods from servo arm to tail control horns? I wonder how to nicely do that part of building. Ah yes, a last question: could routing the antenna tru the carbon fiber tube be detrimental to radio signal?
Thanks a lot for your appreciated help.
jb48 is offline
Old 08-17-2008, 12:01 PM
  #73
Sky Sharkster
Default Launching Peg, Pushrods
Hello JB,
I haven't gotten to the tip peg or servos yet, but according to the instructions the pushrod guides are glued inside the fuselage. Starting from the rear, about 1-1/4" inch in front of the stabilizer, up to F3, there are a couple of slots in F3 for the guides. They exit the boom (at the rear) one on each side. Depends on whether you're right-handed or left-handed. The plans have a small detail of this on the boom side view.
Here's a photo of the launching peg, it's about 2" long and 3/16" diameter C/F tube. No mention of how much sticks out on each side, but most of the DLG's have it even, top + bottom. Index finger around the top, middle finger around the bottom.
Also no mention of where to route the antenna, I plan to tape it to the bottom (outside) of the boom.
There are also 2 long C/F ribbons that are CA'd to the top and bottom spar, tip-to-tip. This is done after the wing is sheeted, will post photos soon. The peg goes through the C/F at the tip.
Good Luck!
Ron
Old 08-24-2008, 02:12 PM
  #74
Sky Sharkster
Default Wing Sheeting Finished
Here's some photos of the wing sheeting, top + bottom. I'm not too happy with my workmanship, some gaps where the L.E. angle meets the sheet. For some reason I had a hard time matching this up.
ID:	76290   Click image for larger version
ID:	76291   Click image for larger version
ID:	76292   Click image for larger version
ID:	76293   Click image for larger version
Old 08-25-2008, 02:54 PM
  #75
buzzbomber
Matt Smith
buzzbomber's Avatar
Looks good to me! My kit's still in the bag, unfortunately I have a few more important non-hobby related projects holding me up at present.
buzzbomber is offline
Quick Reply: Build Thread; Mountain Models QF-2 DLG
Page generated in 0.19480 seconds with 94 queries
