Speed 400 Motor Problems - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-16-2008, 09:39 PM
Dillion
Unhappy Speed 400 Motor Problems
Hi, I'm usally over at RCUnivese but they no longer have the answers for me I need some help with electric I usally fly nitro but our club lost it's nitro field so all we have is a Electric field. I have been setting up a Cloud Ranger. With suggestions from the manufacture and hobby-Lobby here is where I am. Follow are all my specs.
Ok what am I doing wrong here. I have no power to speak of. Heres the setup. A 24oz. Plane. A “Graupner: Speed 400 Motor , 7.2V Thrust 8Oz. Volts 8.4 Gearbox 2.33:1 Battery: 7.2v 20C 1550mAh using a Electrifly C-12 ESC for Brushed Motors Prop: 9x6, with more suggestion from HL, I now tried a 10xAA battery pack with no better power. I'm just not getting any forward thrust. Whats wrong in this setup. (Besides me)
Please help.
ID:	69527   Click image for larger version
ID:	69528   Click image for larger version
ID:	69529   Click image for larger version
ID:	69530   Click image for larger version
Dillion is offline
Old 06-16-2008, 09:46 PM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
Sounds like a simple "this motor is not big enough" problem. Not sure if you could run a 3S on it and that will help, but lessen the life of the brushed motor. You are looking for around 18-24 oz of thrust (if that is your AUW).
SkunkyMagoo is offline
Old 06-16-2008, 11:55 PM
Dillion
Default Which Motor please.
Lets say I'm not rich, what motor would you suggest. I would like to use my 7.4v batteries. First is 10C 7.4V 1800mAh 2cell, next 2 cell 7.4v 1000mAh LiPo mini Battery, and the third 20C 1550mAh 7.4V 2Cell, I also have a 10xAA 1000mAh 10cell. So knowing I want to use them, the Plane is a "Cloud Ranger" by Herr coming in at about 22 to 24 Oz, with about a 10 oz wing load. Thank you
Dillion is offline
Old 06-17-2008, 05:08 AM
RUSH
RUSH's Avatar
If you want to stick with the brushed motor, I'd suggest trying out a 6V speed 400 and something like a 10x7 prop if you have the ground clearance (9x6 or 9x7.5 if not). You might not be able to use the 1000mAh pack if it can't put out at least 12A, but the other lipo packs would be okay. I wouldn't suggest running the AA pack since it's heavy, but if you do I would stick with the 9x6 with that pack.
Also, run an electric prop - it looks like the one you have one there now might be a glow prop (sorry if I'm mistaken). The E props are more efficient.
RUSH is offline
Old 06-18-2008, 08:33 PM
lawn-dart
lawn-dart's Avatar
Default I had the same problem with a Mini Telemaster........
It called for the same set up. Not enough power. I went with the 2830 Hobby city Outrunner with a simple series 30amp esc.
With frieght and everything the new power system was about $30.00.
Big differance, takes off in about 15 feet, flys well.
Just my 2 cents worth.......
lawn-dart is offline
Old 06-18-2008, 08:36 PM
lawn-dart
lawn-dart's Avatar
Default Now I'm confused.........
I just went back and looked again at the pictures posted, and the one of the full plane shows it to have a gold and silver out-runner on it. IT even has a prop saver hub.
Old 06-25-2008, 12:35 AM
teamgs
Respect mah Authoritay!
teamgs's Avatar
Welcome to Wattflyer, Dillon.
Using only your 2 cell lipos, I think that brushless outrunner with direct drive is the way to go. You can get motor, mounts, and esc for $30, which will almost double your current thrust, plus add a little more speed.
If you want to stay brushless, you could a get a long can speed 400 motor, which will take more amps, then add something like a 10x4.7 prop for more thrust. You could also get a speed 480 race motor, but the cost of that is the same as a whole brushless setup.
Regards,
Gary
teamgs is offline
Prof100
ParkFlyers
07-03-2007 05:24 PM
jetfixr
06-03-2007 12:42 PM
RSS Feed
RCU RSS Feed
10-28-2006 05:10 AM
ewegman
07-06-2006 06:53 AM
Quick Reply: Speed 400 Motor Problems
Page generated in 0.09200 seconds with 20 queries
