Dx6i mix problems ailerons for spoilers - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-10-2008, 03:34 PM
sapper378
Derek
sapper378's Avatar
Question Dx6i mix problems ailerons for spoilers
Hello all,
Flying a Multiplex Easy Glider Electric. Three weeks in, great fun.
A late starter at 59 yrs here, but as real flying has become so expensive I thought I would try another hobby. RC Aero seems to fit the bill. In the speki manual it says with dual ailerons set they can be used as spoilers (both up?). The manual then says nothing about how to do. I have spent an age trying to fiddle with mixes but all I have managed so far is both ailerons down but only when the stick is all the way to the right. Does this mean, even if there is a way to do it, I would have to fly rudder and elevator only?
I did manage to mix the rudder and ailerons, but it seemed like cheating. so I tuned it off.
Any help appreciated, sorry in advance if this should be in beginners forum.
sapper378 is offline
Old 06-10-2008, 03:57 PM
adhoc
(inactive)
adhoc's Avatar
Originally Posted by sapper378 View Post
Hello all,
I'm not clear on what you mean by "only when the stick is all the way to the right." Which stick, the aileron?
Let me walk through the whole flaperon/spoileron setup; forgive me if you've already done all this...
First we need to confirm that you in fact have two separate aileron servos, and they are plugged into separate channels on your receiver (not with a Y-harness). The left aileron should be plugged into the Aux channel, and the right aileron should be plugged into the Aileron channel.
Next, on your DX6i go to the Setup List (bottom of the Adjust List), then select WINGTAILMIX, then select DUALAILE, change that from INH (inhibit) to ACT (active). (Yeah, they could have made all this more clear.)
Finally, go to the Adjust List, select FLAPS, and experiment with different settings for NORM+ and LAND for the FLAP column. (I don't have my DX6i in front of me to try it, but I'm pretty sure this is where you do it.)
Note that with flaperons or spoilerons, you are trading off aileron throw for these functions -- you'll lose some roll responsiveness. I wonder if that's what you're experiencing. You may want to back off how much flaps/spoilers you're dialing in...
Let me know if this makes sense... We'll get this sorted out with you... :-)
adhoc is offline
Old 06-10-2008, 04:15 PM
sapper378
Derek
sapper378's Avatar
Hi Andy, what time is it with you, its 1600 here. Any how , thanks for the steer.
Two aileron servos, connected as you say.
DualAil set to ACT.
It was the aileron stick I was moving, but I had messed about with so many things I couldn't figure what was what. So I just reset the box to start again.
I'm going to play with the Flap setting as you suggest.
Thanks again.
Old 06-10-2008, 04:21 PM
adhoc
(inactive)
adhoc's Avatar
DualAil set to ACT.
Thanks again.
Ah, I got ya, probably have a weird mix going. You don't need a custom mix to do flaperons/spoilerons... Good luck, let us know how it works out...
p.s. 8am here, suppose I should get the dog walked and go to work...
adhoc is offline
Old 06-11-2008, 03:48 AM
sapper378
Derek
sapper378's Avatar
Sorry not to reply I had to go to work also. Night shift this week. I will be trying the flap thing later today.
Old 06-11-2008, 02:23 PM
sapper378
Derek
sapper378's Avatar
Hello again Andy, Thanks for the steer , I have got it sorted, with your help.
It was the flaps setting I needed to change, as you said.
Just waiting for a new speed contoller now. the original was damaged in an "event" on Sunday.
Oh well, the joys of RC Flying.
Old 06-11-2008, 03:10 PM
adhoc
(inactive)
adhoc's Avatar
Hey, glad to hear it! As for "events," the only way to avoid those is to not fly...
adhoc is offline
Old 06-19-2008, 05:48 AM
FunFlyer
FWIW, I have done that with my Senior Telemaster, and have mixed in some rudder when the flaperons are down to improve steering as some aileron sensitivity is lost when flaps are down. This helps during finals!
Cheers...
Adrian
FunFlyer is offline
Capt Easy
17
10-12-2008 11:24 PM
richg99
09-28-2008 07:16 PM
constantCrash
06-09-2008 03:53 PM
Daylight99
05-28-2008 01:32 AM
jeffsend
Delta & Flying Wings
09-29-2007 12:19 AM
Quick Reply: Dx6i mix problems ailerons for spoilers
Page generated in 0.09374 seconds with 12 queries
