Problems arming Hextronik 36A ESC - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 05-31-2008, 03:21 PM
budokaiboy
Default Problems arming Hextronik 36A ESC
Hey guys, I just converted a mini rio boat to brushless. When I try to arm the 36A Hextronik ESC it arms, but as I release the trigger on 3 different radios and receivers that I tried, the motor starts to spin up before the trigger gets back to its' "normal" position. I've tried playing with the travel adjustments on my Spektrums DX3R and DX3 and even used a Traxxas TQ2 from a Rustler VXL .
So, it does arm but I can't let go of the trigger without it engaging the throttle.
I also tried a Phoenix 25A ESC and it did the same thing.
budokaiboy is offline
Old 05-31-2008, 07:10 PM
gyrocptr
Could you provide the brand of radio that you have?
When the trigger is "pulled", is that your "hi" throttle or "low" throttle position?
gyrocptr is offline
Old 05-31-2008, 08:58 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
Hi,
I had a similar problem, but had to adjust the low end "Throttle Off" setting
on my computerized JR X642 transmitter.
I have the HXT 36A ESC and ordered the USB programmer with it ($3.95), sure makes it easy to do the set up. It's a great ESC!!!!
Don
donjiskra is offline
Old 05-31-2008, 10:57 PM
budokaiboy
Thanks buddy! I also have the usb programmer I left everything at default except the cutoff voltage.
Old 06-01-2008, 02:02 PM
donjiskra
WAA-08 Pilot
donjiskra's Avatar
The "low voltage cut-off" is used for the battery pack, not throttle control.
You need to set your transmitter low idle throttle setting.
Check your transmittter.
Don
Old 06-01-2008, 03:49 PM
budokaiboy
Gyro, I have a couple of Spektrum radios. One is a 3R and the other is a 3XR.
burncycle
01-13-2008 03:35 AM
why_fly_high
12-26-2007 05:41 PM
stampede_dude
11-23-2007 09:53 PM
peterkron
03-03-2007 05:01 AM
triniheli
02-24-2007 11:32 PM
Quick Reply: Problems arming Hextronik 36A ESC
Page generated in 0.05797 seconds with 11 queries
