spitfire - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
spitfire
Old 08-18-2007, 03:23 PM
  #76
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Make sure the file isn't too large. Look in the lower window, it gives you file size limits. Use JPG when you can because it is the largest file limit. (7.44mb I think)
brnyrbbl is offline
Old 08-18-2007, 03:25 PM
  #77
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
I am going to guess the file is too large
FlyingMonkey is offline
Old 08-18-2007, 03:26 PM
  #78
FlyingMonkey
Flite Test Fan
I like this plane, I might have to make one one of these days....
there is a replica at the museum in Ft. Rucker. amazing that men would fly these things
Old 08-18-2007, 03:39 PM
  #79
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Originally Posted by brnyrbbl View Post
Tom.. while you are on the subject of attachments, is there any way to attach a pic you have already uploaded. I can see all the pics I've uploaded but can't find a way to access them when creating a new post.
Hi Aaron,
I think you can open the picture in the post you loaded it to, right click on it and save as. Then you can insert it in a new post. Is that what you mean?
Grasshopper is offline
Old 08-18-2007, 03:58 PM
  #80
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Actually I was referring to >UserCP >Attachments. It lists all the pics you have uploaded. It only has the option of delete. I was wondering if there was a way to attach previously uploaded pics into a new post. As of now, I can only see the option of attaching pics from your computer or web. Maybe Mike can add that feature to attach previously upped pics so I don't have duplicates. Otherwise, what's the point of storing them on WF?
brnyrbbl is offline
Old 08-18-2007, 04:09 PM
  #81
Grasshopper
What are you wanting to do with them Aaron? Are you wanting to grab them for attaching to an additional post? I've never used that feature in the user CP but just noticed I have 28 pages of attachements there. Heck, I never even knew thay were there.
Old 08-18-2007, 04:19 PM
  #82
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
LOL!!.. that's what I mean.. What's the point of storing them on WF if we have to reupload them from our PC everytime we create a new post and want to attach them.
brnyrbbl is offline
Old 08-18-2007, 04:23 PM
  #83
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Let's see if it works.. I chose "show thumbnails" then right clciked on the pic and selected "copy". I then "pasted" in the quick reply window and it appears to work. If the pic is in this post it does.
**You have to click on the thumbnail to get the full screen pic then copy/paste.
brnyrbbl is offline
Old 08-18-2007, 04:27 PM
  #84
FlyingMonkey
Flite Test Fan
but it was TINY
Old 08-18-2007, 04:28 PM
  #85
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Try again.. I copied/pasted the thumbnail but it only showed the thumbnail so I opened the pic then copied/pasted again.
brnyrbbl is offline
Old 08-18-2007, 04:31 PM
  #86
FlyingMonkey
Flite Test Fan
Just go open a photobucket account. You can organize and file your pictures. It makes life so much easier.
you don't even have to do the funky three keys to copy thing to save the picture's img code, you just click on the line, it automatically copies it for you to use where you will...
Old 08-18-2007, 04:34 PM
  #87
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Sorry for stearing your thread off course spitfire. I was trying to figure out the picture thing for you and I should have used the "test" forum.
brnyrbbl is offline
Old 08-18-2007, 04:47 PM
  #88
spitfire
Not the best
spitfire's Avatar
ok here are the pics and i also made most of the left wing
ID:	38437   Click image for larger version
ID:	38438   Click image for larger version
spitfire is offline
Old 08-18-2007, 04:49 PM
  #89
FlyingMonkey
Flite Test Fan
er, I am pretty sure the wing ribs aren't supposed to be cut between the notches for the spars...
Old 08-18-2007, 04:51 PM
  #90
spitfire
Not the best
spitfire's Avatar
yes they do... hopefully
spitfire is offline
Old 08-18-2007, 04:55 PM
  #91
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
errrr.. I have to agree with Monkey.. usually ribs are one piece for structural integrity and strength. Don't worry yet though. Does the manual say if they are supposed to be split? You can always pick up some balsa sheet then trace the cut ones you have and re-make them if you have to.
brnyrbbl is offline
Old 08-18-2007, 05:07 PM
  #92
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
The solid line in the plans where you split the ribs is usually a cross brace. It is a solid piece of balsa that sits flush between the top and bottom of the rib or between the spars in some cases and extends between the ribs. Hopefeully your plane is built differently than most and you have it correct.
brnyrbbl is offline
Old 08-18-2007, 05:18 PM
  #93
spitfire
Not the best
spitfire's Avatar
i don't have a building manual, but here is what the plans some what indecated.
spitfire is offline
Old 08-18-2007, 05:23 PM
  #94
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
The spars seem pretty "meaty" so I think you will be ok. You could always put a small doubler where the cut is. (sort of like a band-aid)
brnyrbbl is offline
Old 08-18-2007, 05:24 PM
  #95
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Are the wings solid sheeted? If they are you definitely will be Ok.
brnyrbbl is offline
Old 08-18-2007, 05:30 PM
  #96
FlyingMonkey
Flite Test Fan
ahhhhh, maybe it is intended for the solid spar.
That makes more sense.
  #97
FlyingMonkey
Flite Test Fan
I am impressed, to be building off from plans with no directions.
Quite a feat.
Old 08-18-2007, 05:31 PM
  #98
spitfire
Not the best
spitfire's Avatar
well it is supposed to have cap strips and monokote but i am going to sheet the wings with balsa, and the spares are very meaty they are pine
spitfire is offline
Old 08-18-2007, 05:38 PM
  #99
brnyrbbl
Powered by Visa
brnyrbbl's Avatar
Try to keep the sheeting as thin as possible. If it was designed for monokote than it may not fly to well with the extra weight of the sheeting. What are you planning for covering material?
brnyrbbl is offline
Old 08-18-2007, 05:47 PM
  #100
spitfire
Not the best
spitfire's Avatar
1/16" and monokote
spitfire is offline
Quick Reply: spitfire
Page generated in 0.14414 seconds with 15 queries
