Parkzone Micro Cessna 210 - Page 5 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-22-2008, 03:01 PM
  #101
Mike_Taylor
Micro Flyer
Mike_Taylor's Avatar
Sunfn,
SOunds like you picked up one of your buddie's X by mistake. The beeping is it trying to find its own TX signal. You can re-bind it (center the sticks, push the left stick straight down/in - like a button) by following the instructions on page 2.
Mike_Taylor is offline
Old 01-22-2008, 11:52 PM
  #102
Sunfm
yah belive me i tried EVERYTHING
and my buddies planes beep too when finding the signal but they find it quick
and i know my TX works becuase i have bond it to my buddies plane
but neither mine or any of my buddies TX's will bind to mine
I think I will ship it to parkzone
i called them and thats what they said to do and it would be under warrenty
thanks
Sunfm is offline
Old 01-24-2008, 03:16 PM
  #103
briskability
bing bang bop
briskability's Avatar
Can the dx6 be programmed to fly this little monster?
briskability is offline
Old 01-24-2008, 04:55 PM
  #104
Mike_Taylor
Micro Flyer
No, it cannot. The TX for the model(s) are only about $40 though...
Old 02-02-2008, 03:56 AM
  #105
jecchile
jecchile's Avatar
Has anyone seen the CITABRIA model?...
I understand that is coming out NOW...
jecchile is offline
Old 02-05-2008, 04:26 AM
  #106
redneckflyer
GIT-R-DONE!
redneckflyer's Avatar
this would be a fun one to build from scratch
redneckflyer is offline
Old 02-12-2008, 03:36 AM
  #107
Numb Thumbs
Numb Thumbs's Avatar
Question Citabria
G'Day guys!
I bought a Citabria yesterday.
Flys very slowly if you want - around walking speed and can easily do figure 8's across a basketball court.
Had a fantastic time for one and a half batteries when it lost power dramatically. The motor seems to have seized up. Full throttle can't turn the prop and the plane beeps.
Any ideas??
Numb Thumbs
Numb Thumbs is offline
Old 02-12-2008, 04:12 AM
  #108
RickTheRaven
Default Citabria Motor
So they do exist!
I had the same problem with my new Cessna. After the first recharge, the engine stopped in mid-flight. I cut the plane open and put a drop of oil in the prop shaft and it worked OK for another two minutes, then seized again. I called customer support and they said "send it back." I said "Could I trade it for a Citabria?" (which was not available when I ordered the Cessna). Support guy said "You would have to wait a long time" so I assume it is still not available in the US.
RickTheRaven is offline
Old 02-12-2008, 04:18 AM
  #109
briskability
bing bang bop
So I was thinking of taking away the rudder control for ailerons on my cessna 210, do you think this could work?
Old 02-12-2008, 10:43 AM
  #110
caltrop
Can't Help Myself
caltrop's Avatar
Thumbs up Cessna Aileons
Good idea! Then you would have a almost fully aerobatic micro-Cessna. You might be able to fly inverted but with the wing design I doubt it would fly well upside-down. You might want to reduce the dihedral since you would not need the added stability.
The only time you really need rudder is for crosswind landings & takeoff's. Then there's 3D and precision flying which need rudder. But since the Cessna doesn't do wind go ahead and make some ailerons.
Do the ailerons first then you can try other mods. One thing at a time until you see how well it works.
I'm interested to see how well it comes out.
caltrop is offline
Old 02-12-2008, 06:13 PM
  #111
briskability
bing bang bop
Well I put em on there and now I just got to go try it out, the way I have it setup the rudder could still be used along with ailerons to give smoother turns if wanted but I will see how just ailerons goes first.
and It added 1.5g of weight, it was 18g now its 19.5g.
Old 02-12-2008, 07:05 PM
  #112
briskability
bing bang bop
The tape is on there for now just so I can adjust them for now. And of course it started to rain 1sec after i stepped outside so I decided to just try it once anyway, I set her down gave it some throttle and then the prop flew off. so far not so good. How can I get more deflection out of these?
http://www.youtube.com/watch?v=Ws8bKTHVjq8
ID:	55517   Click image for larger version
ID:	55518   Click image for larger version
Old 02-12-2008, 09:53 PM
  #113
jecchile
jecchile's Avatar
Default Citabria...
Call Horizon Hobbies - they are very good at solving customer problems... OR, your dealer should be able to help...
Good luck.
jecchile is offline
Old 02-12-2008, 10:34 PM
  #114
briskability
bing bang bop
? i dont think there going to help me mod my plane
Old 02-13-2008, 01:27 AM
  #115
jecchile
jecchile's Avatar
Default Citabria...
Sorry, I meant for my response to go to "Numb Thumbs"... you are correct, they will not help you modify your Cessna 210.
jecchile is offline
Old 02-13-2008, 04:49 AM
  #116
caltrop
Can't Help Myself
caltrop's Avatar
Thumbs up More Throw
Move the pushrod to the outer hole on the rudder horn by the tail. Then move the rod closer to the center on your horn.
Be careful, you don't want too much travel. Try it first the way you have it.
Interesting setup. I was thinking to do surgery on the plane and make a dedicated aileron system. Hey, if it works OK.
caltrop is offline
Old 02-14-2008, 07:31 PM
  #117
briskability
bing bang bop
they didnt work so good. I had to put the control on the rudder along with the ailerons to get it to turn but it did make a difference then, alot sharper turns but I would not do it, its just that I have another fuse wing n tail section comin for this one. I did duild a scaled up model of this plane last night, I will put ailerons on here if it works.
ID:	55756   Click image for larger version
Old 02-24-2008, 02:41 PM
  #118
gfdengine204
gfdengine204's Avatar
Well kids, I maidened my Cessna210 last night at the weekly indoor flyin, and all I can say is WOW! Once she was trimmed, she flew awesomely. Can't wait to fly her outdoors on a nice calm evening. (Of course, I also can't wait for some nice 50-60 degree evenings.....)
gfdengine204 is offline
Old 02-24-2008, 08:34 PM
  #119
jecchile
jecchile's Avatar
Wait till you see the new Citabria fly... it is a sweetheart...
jecchile is offline
Old 02-24-2008, 09:44 PM
  #120
gfdengine204
Yeah I have heard that.....<sigh> Oh the problems we have eh?
Old 02-24-2008, 11:37 PM
  #121
Tommyr
Tommyr's Avatar
WE NEED VIDEO!
Tommyr is offline
Old 02-25-2008, 01:52 AM
  #122
jecchile
jecchile's Avatar
Originally Posted by Tommyr View Post
WE NEED VIDEO!
You can see a video here:
http://www.hobbyzone.com/rc-planes-p...tabria-rtf.htm
A friend just bought one and I saw it fly last Thursday... I like my Cessna 210 but the Citabria is a much better flyer.
jecchile is offline
Old 02-25-2008, 02:06 AM
  #123
Tommyr
Tommyr's Avatar
Cool, THANKS!
Is it really slower then the Cessna?
Tommyr is offline
Old 02-25-2008, 02:17 AM
  #124
jecchile
jecchile's Avatar
Cool, THANKS!
Yes, it can fly slower - the wing span is about 1" longer so the wing area is greater... really nice looking airplane. If my Cessna bites the dust, I will get one for sure.
jecchile is offline
Old 02-29-2008, 03:55 AM
  #125
RickTheRaven
Default Re: Citabria
Does it use the same battery and transmitter as the 210?
Quick Reply: Parkzone Micro Cessna 210
Page generated in 0.15489 seconds with 15 queries
