Super KAOS Build - Electric - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-30-2013, 08:51 AM
  #76
Just looks better with the canopy and a pilot (to me)
With vs without, and placement of, the canopy can affect knife edge and dutch roll.
But your long battery hatch will make putting the canopy as far aft as i would put it a bit difficult.
Old 06-30-2013, 01:30 PM
  #77
soarrich
Soarrich
soarrich's Avatar
Good luck with the maiden flight.
The servo placement doesn't look very "Old School."
I'd go with a canopy, Kaos' need the canopy for the "look" and the forward side-area. If you cut off the last inch of the canopy it would fit on your hatch nicely and would be a great hot air outlet.
soarrich is offline
Old 06-30-2013, 01:38 PM
  #78
paxskipper
New Electric Flyer
paxskipper's Avatar
Very nice build set the CG at 25% of the wing cord for the maiden flight, so you wont have a tail heavy issue, and then adjust the CG from there, little by little untill you find the sweet spot ..
Thanks.
It seems that the 25% would make it very nose heavy, which is certainly better that tail heavy. As I recall the plans have the CG at about the 33% position - just checking.
paxskipper is offline
Old 06-30-2013, 01:48 PM
  #79
Originally Posted by paxskipper View Post
Thanks.
25% is ultra safe - but can actually cause issues too. I generally start at about 28-30%. Most planes tolerate that pretty well and they are not so nose heavy.
Now I have flown planes that need to be at 25%, but you are usually OK a tough further back. Just because a plane is tail heavy does not mean it will crash.
Old 06-30-2013, 01:52 PM
  #80
soarrich
Soarrich
soarrich's Avatar
I'm flying my Kaos balanced right on the spar.
soarrich is offline
Old 06-30-2013, 02:44 PM
  #81
paxskipper
New Electric Flyer
paxskipper's Avatar
I'll move my forward battery up a little and make it a little nose heavy for the CG position I marked. Likely a safe thing to do for the maiden flight anyway.
Old 07-01-2013, 02:03 AM
  #82
Thanks.
Hi yes, 25% is a Tad nose heavy but safe, Most Maiden Flights fail because of a tail Heavy Issue, I set all of my Planes to 25% CG on the maiden flight then adjust from there, so far no problems Good luck on the Maiden flight, Chellie
Old 07-02-2013, 01:03 AM
  #83
soarrich
Soarrich
soarrich's Avatar
How did you make out today?
soarrich is offline
Old 07-02-2013, 01:29 AM
  #84
paxskipper
New Electric Flyer
paxskipper's Avatar
Maiden did not happen today, but it looks like it will be Tuesday morning.
Old 07-02-2013, 07:41 PM
  #85
paxskipper
New Electric Flyer
paxskipper's Avatar
Thumbs up Maiden Flight
Well first flight happened this morning. Got it trimmed out pretty well. Only managed a single flight today, but I'm planning on trying again tomorrow.
Name:	KAOS Maiden Small.jpg
Old 07-02-2013, 08:14 PM
  #86
Congrats man!
Old 07-02-2013, 08:50 PM
  #87
pd1
Still Learning
pd1's Avatar
Glad the test flight went well.
pd1 is offline
Old 07-02-2013, 09:29 PM
  #88
soarrich
Soarrich
soarrich's Avatar
Congrats on the test flight! I see you added a canopy, looks good.
soarrich is offline
06-28-2017 04:22 PM
01-09-2017 02:23 AM
hillbillynamedpossum
107
08-26-2013 11:23 PM
Mustang
06-23-2013 11:27 PM
Doclove524
09-03-2011 03:04 AM
Quick Reply: Super KAOS Build - Electric
Page generated in 0.12644 seconds with 15 queries
