Support_Needed osd - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Eagle Tree Systems, LLC discussion Discuss support issues and product questions with Eagle Tree Systems
Support_Needed osd
Old 06-28-2010, 12:09 AM
108buzz
Default osd
Okay, So I have the OSD Pro, Elogger V3 and all the sensors. I have been trying to get it to work right with no luck. To mant directions and nothing is simplified. I keep getting the sofetware needs to upgrade. So I do it and it says it is successful but then it comes up again. I cant get all the sensors to show up on the video and all it says is to configure the OSD with your computer which I have tried. Conclusion is this thing sucks and is a big pain in my A$$. It is not user friendly. What a waste of money. If you want a headace and wasted hours, buy it.
108buzz is offline
Old 06-28-2010, 12:22 AM
Past President of PSSF
I would suggest calling the supplier directly, I'm sure that Eagle tree will help you.
It would be better than putting them down, as it seems other people have used it OK.
Wildflyer is offline
Old 06-28-2010, 12:48 AM
108buzz
.... Mr. sales rep.
108buzz is offline
Old 06-28-2010, 12:57 AM
Bub Steve
Bub Steve's Avatar
easy there Buzz,, you should call Them up before calling folks out that want to help,
were a friendy bunch here,,bubsteve
Bub Steve is offline
Old 06-28-2010, 01:20 AM
Twmaster
Registered User
Twmaster's Avatar
But have you tried to talk to the manufacturer?
It may be something simple. Eagle Tree has a good rep. Perhaps they deserve an opportunity to help?
Twmaster is offline
Old 06-28-2010, 01:21 AM
108buzz
Sorry, but I am tired of pay alot of money for something that should work right out of the box. I have been messing with this for a full day and it still does not work right. Now, I have to waste more time and call support to try to get it to work right; when it should have done that from the beginning.
108buzz is offline
Old 06-28-2010, 02:07 AM
Bub Steve
Bub Steve's Avatar
I understand Buzz, Hope its something simple, I'm not above gett'in peved at stuff that does'nt work, these guys here will steer you right, bubsteve
Old 06-28-2010, 02:10 AM
108buzz
I'm sure they will but it still piss me off that I must call for something new.
108buzz is offline
Old 06-28-2010, 02:22 AM
Bub Steve
Bub Steve's Avatar
Buzz: You know *&%^ Happens Sometimes,, but not always,,,
Heres a phone # I looked up, bubsteve
call at 1-425-614-0450, extension 3. Our normal telephone support hours are 1 PM to 4:00PM, Monday, Wednesday and Friday, USA Pacific Time (GMT – 7). Our telephone support center is closed on Tuesdays and Thursdays.
Old 06-28-2010, 02:47 AM
108buzz
Thanks for the number.
To everyone who has viewed this topic. Let me appoligize for my attitude, I am stressed and tired, which is by no means an excuse for my attitude and negative comments. Anyway, I apoligize and thanks to everyone and their inputs. I will figure this out eventually.
108buzz is offline
Old 06-28-2010, 03:06 AM
108buzz
Stevecopper, I have Four questions that maybe you can answer. First, I was told to install a BEC, but I do not remmeber where I am to install it (Between What?)? Second question, Battery backup can be how much votlage? Can I use a 3S li-po? Third question, I have a ferit ring and am not sure where to install it. I am guessing it has to do with blocking the TX signals. Forth question, Do I install the temp sensor iotn TPM1 on the elogger V3?
108buzz is offline
Old 06-28-2010, 03:25 AM
Bub Steve
Bub Steve's Avatar
I can help on all but the last ?,, A BEC (Battery elimenator circuit) goes from you lipo (three cells fine) then to you RX, the Ferrite ring should be looped on near RX plug ( you right it a R S defuser) you'll need to unplug the red wire going to RX from the ESC as you powering from the BEC now,, hope this helped, bubsteve
Old 06-28-2010, 03:49 AM
108buzz
Okay, I have wired other aircraft this way. I thought it was wired into the OSD or eLogger some how. Thanks.
108buzz is offline
Old 06-28-2010, 03:59 AM
108buzz
What size BEC/ I have one that can handle 3.5A up to peak 4.2A
108buzz is offline
Old 06-28-2010, 08:07 AM
billpa
108Buzz, really sorry to hear about your issues with our equipment. We're here to help, either by phone, or web ticket here, or we can answer questions on this thread.
If you are getting the "firmware needs updating" message, make sure you are clicking on the particular device (OSD Pro or eLogger) whose firmware version is lower than the version indicated on the button. The present firmware version is listed in the text just above the button.
If you're updating the OSD Pro firmware, after you do the update, the page to configure the OSD's on-screen parameters should appear. Then, you can configure the parameters to your liking, and click OK.
billpa is offline
Old 06-28-2010, 09:18 PM
Bub Steve
Bub Steve's Avatar
That should handle it, bubsteve
billpa
Aerial Photography
03-19-2009 05:36 PM
VCtony
Aerial Photography
07-07-2008 08:19 AM
VCtony
Aerial Photography
03-04-2008 10:54 PM
oxxyfx
Aerial Photography
11
03-03-2008 10:05 PM
jmstech
Aerial Photography
36
01-04-2008 02:09 AM
Quick Reply: Support_Needed osd
Page generated in 0.07954 seconds with 10 queries
