PAK DA Bomber in Five Easy Pieces
Old 04-12-2013, 03:34 AM
Bobdaeronort
Bobdaeronort
Default PAK DA Bomber in Five Easy Pieces
Here is my latest project.
My version of a Russian PAK DA Bomber concept.
Here her glide tests.
http://www.youtube.com/watch?v=FkDTFYR3iuM
Here are some pics.
Name:	PAK DA @11.jpg
ID:	167742   Click image for larger version
Name:	PAK DA @9H.jpg
ID:	167743   Click image for larger version
Name:	PAK DA @11H.jpg
Bobdaeronort is offline
Old 04-13-2013, 02:45 PM
Bobdaeronort
Bobdaeronort
Well it seems I am once again gainfully employed this time in my industry. So now I will have more money to pour into my hobby but less time to do it.
Old 08-09-2013, 05:55 AM
Bobdaeronort
Bobdaeronort
Finally back to work on the PAK DA today.
I've made a new one based on the info from glide testing the previous three.
The elevons are reduced leaving the broad tail for stability. There may yet be a center piece to keep it ridged.
The wing shape and canard placement is exactly like the Su-47 Berkut.
I have added the elevons to the wing rather than cut them from it to make a more stealth looking trailing edge.
Name:	PAK DA @9.jpg
ID:	170186   Click image for larger version
Name:	PAK DA @ 10.jpg
ID:	170187   Click image for larger version
Name:	PAK DA @ 10Low.jpg
ID:	170188   Click image for larger version
Name:	PAK DA @ 12 Low.jpg
ID:	170189   Click image for larger version
Name:	PAK DA 12H.jpg
Old 08-09-2013, 10:00 PM
Bobdaeronort
Bobdaeronort
A successful maiden flight of my five easy piece forward-swept wing PAK DA Bomber
http://youtu.be/25Yj22OJCmg
Old 08-10-2013, 03:34 PM
Bobdaeronort
Bobdaeronort
Moved the canards.
Name:	PAK DA Canard Mod.jpg
Old 08-11-2013, 04:10 AM
Bobdaeronort
Bobdaeronort
evening sortie
http://www.youtube.com/watch?v=e6RxxktsRIQ
Old 08-11-2013, 04:11 AM
Bobdaeronort
Bobdaeronort
Another sortie
http://www.youtube.com/watch?v=PDB3Efk3Phw
Old 08-11-2013, 02:14 PM
Bobdaeronort
Bobdaeronort
I had to take down my last video. It seems I violated Sony playstation's copyright by calling this PAK DA a "Krazy Ivan". It happens to be the name of their new FPS game.
Who knew?
So any body out there got any ideas for a name for this bird?
Old 08-11-2013, 06:00 PM
Bobdaeronort
Bobdaeronort
Encounter with a light pole.
http://youtu.be/j58_rxY0CTg
Old 08-12-2013, 11:51 AM
Bobdaeronort
Bobdaeronort
Reduced the VR ( ventral rudders) by 30% and took her for a spin.http://www.youtube.com/watch?v=JsaZDFotZpA
Old 08-13-2013, 03:44 AM
Bobdaeronort
Bobdaeronort
http://youtu.be/WFcQLB2Wq_s
Old 08-18-2013, 03:29 PM
Bobdaeronort
Bobdaeronort
http://www.youtube.com/watch?v=huctjxCYi3s
Old 09-03-2013, 11:04 PM
Bobdaeronort
Bobdaeronort
http://www.youtube.com/watch?v=7VKsMUlWsZA
Old 09-04-2013, 08:19 PM
JBRanger
Nice!
Sent from my iPhone using Tapatalk - now Free
JBRanger is offline
Old 09-08-2013, 02:14 PM
Bobdaeronort
Bobdaeronort
Another onboard cam flight.
http://youtu.be/kJR17tt5fbQ
Old 09-28-2013, 02:21 PM
Bobdaeronort
Bobdaeronort
Plans for the tailless FSW PAK DA Fighter / Bomber
http://www.mediafire.com/view/nakf0u..._DA_Bomber.PDF
Old 10-17-2013, 05:49 AM
Bobdaeronort
Bobdaeronort
My latest attempt at a sixth Generation Tailless FSW "Ivan" PAK DA Bomber.
Name:	Ivan PAK DA @12.jpg
ID:	171459   Click image for larger version
Name:	Ivan PAK DA @9.jpg
ID:	171460   Click image for larger version
Name:	Ivan PAK DA @4.jpg
Old 10-17-2013, 06:14 AM
cant wait to see that one fly
Old 10-19-2013, 07:21 AM
Bobdaeronort
Bobdaeronort
Niether can I.
I maidened it today. Didn't work out well. My bad. As I was doing the set-up I changed from the tried and true (works just fine on my previous PAK DA/FA) elevon set-up to an aileron-elevator setup which I had tried before and learned (apparently not well enough though) does not work. A funny thing about the Tailless Forward-Swept-flying-Wing, it needs the rear wing surface to be flat in order to be stable in pitch. Even minor trim can cause the plane to pitch up end for end. I put that finding aside and learned all over again that it is so true. Also in my haste to build it I warped it slightly which gave it an annoying desire to roll left.
Already begun building a new one. Slowly this time. Gonna have to buy a new Hot-Glue gun though.
Old 10-22-2013, 02:16 PM
Bobdaeronort
Bobdaeronort
Foggy and Cold here today with chance of rain and possibly snow later.
When I get my work done I'm cutting out another PAK DA Ivan and trying out my new hot-glue gun.
Old 10-24-2013, 12:55 AM
Bobdaeronort
Bobdaeronort
Found time today to build another Ivan PAK DA.
Took my time and added CR as I went to keep the main wing true.
Glide tests are positive.
I changed the wing-tips by striking the line from the tailing edge tip at 60 degrees back to the nose.
Methinks it makes for a more interesting outline.
Name:	IVAN II @9H.jpg
ID:	171614   Click image for larger version
ID:	171615   Click image for larger version
Old 10-25-2013, 05:39 AM
Bobdaeronort
Bobdaeronort
First attempt at flight with to much wind [email protected] with Gusts @ 19.
http://youtu.be/swoJjsVcav8
Old 02-19-2014, 04:54 AM
Bobdaeronort
Bobdaeronort
http://www.youtube.com/watch?v=PDdNZ9Zh68w
Old 02-24-2014, 07:01 PM
Bobdaeronort
Bobdaeronort
http://youtu.be/6MNb-_l-hCY
Old 02-25-2014, 06:49 AM
Originally Posted by Bobdaeronort View Post
That looks nice and it flies great Too, Nice Job Take care, Chellie
Quick Reply: PAK DA Bomber in Five Easy Pieces
Page generated in 0.18210 seconds with 28 queries
