Help Programming a ZTW esc with an E-flite 90 using a Spektrum TX 6 with a Spektrum AR 610 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Support & Suggestions If you need tech support post your question here or site suggestions too.
Old 11-13-2016, 10:31 PM
Kgotshaw
Default Programming a ZTW esc with an E-flite 90 using a Spektrum TX 6 with a Spektrum AR 610
I am having trouble programming my ZTW esc with my E-Flite 90 electric. The ZTW and the 90 are perfectly matched as long as they are in sync. I would appreciate any help anyone could offer as I am unable to read nor speak Chinese. Thank you, Keith
Kgotshaw is offline
Old 11-14-2016, 07:42 AM
What do you want to do ?
Throttle range ?
Set for motor magnets ?
Set brake ?
Soft on / off ?
LVC ?
ESC's have many functions that can be altered - but generally out of box works for majority of models.
Old 11-14-2016, 03:17 PM
Tepid Pilot
Tepid Pilot's Avatar
Altitude Hobbies sells ZTW ESC's stateside and has links to the manuals in English:
Gecko Series: http://www.altitudehobbies.com/ztw_gecko_manual.pdf
Mantis Series: http://www.altitudehobbies.com/ztw_mantis_manual.pdf
Apparently there have been timing issues with the Gecko series:
https://www.rcgroups.com/forums/show...6#post30402578
HTH.
TP
Tepid Pilot is offline
Old 11-14-2016, 11:51 PM
I'd like to add Altitude Hobby has excellent customer service. They care about customer satisfaction.
On the flip side,the ZTW esc 85amp gave me issues with a eflight motor on my sig smith mini. There were issues with the esc's programing and Altitude gave me a refund. Garret the owner of Altitude answers the phone and will work through any customers needs. I wound up with the castle creations Talon 90 amp esc.
Old 11-15-2016, 12:00 AM
Kgotshaw
Thank you so very much Tepid Pilot for the info. Today I found a ZTW site in English and was able to manage a slow start successfully; however, this is not what I was going for and hopefully with the info you provided, I will be able to accomplish my task. I do believe I am going to lean toward the Castle Talon like I have in my Seagull Glasair Sportsman 2.
Again, thank you. Keith
Kgotshaw is offline
02-25-2018 11:51 AM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
15
06-14-2016 08:52 PM
flyinwalenda
09-24-2013 09:38 PM
Quick Reply: Help Programming a ZTW esc with an E-flite 90 using a Spektrum TX 6 with a Spektrum AR 610
Page generated in 0.05716 seconds with 12 queries
