brushless in runner shaft swap - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 10-13-2014, 12:35 AM
Rhino_Aus
Default brushless in runner shaft swap
Hello all!
I recently purchased several different 12mm sized inrunners from HobbyKing (turnigy 1220, 1230, and BL1230) which have 2.00mm shafts that taper to 1.48mm where you would attach a prop or gear to. I need a 2mm shaft the entire length but don't know how to open these motors as there is no obvious way to take them apart. Does anyone have any experience or advice?
Rhino_Aus is offline
Old 10-13-2014, 10:37 PM
NoResults
On Turnigy motors that I have had to reverse shafts you just remove the keeper ring and collette and hammer it out or put in a vice and press.
NoResults is offline
Old 10-13-2014, 11:20 PM
Rhino_Aus
That's the bit on not sure on. What are and how do I remove the keeper ring and collette?
Old 10-14-2014, 02:30 AM
flydiver
flydiver's Avatar
INRUNNER > the shaft is generally fused/glued/permanently-attached to the rotating magnets. Chances are you are out of luck for shaft replacement.
Here's how you open them:
Motor Shaft Replacement
Best bet is something like Chellie is suggesting below.
flydiver is offline
Old 10-14-2014, 10:34 AM
1.48 mm _ 1.5 mm same thing, prop adapters, Hope this helps, Chellie
http://www.ebay.com/itm/NEW-Great-Pl...item4d258b37f1
http://www.ebay.com/itm/EFLM1933-Pro...item3f3eb4383d
http://www.ebay.com/itm/NEW-Great-Pl...item5b029d6f69
http://www.micronwings.com/Products/...nPropAdapters/
http://www.hobbyking.com/hobbyking/s...arehouse_.html
the hole is 1.5mm that will squeeze down onto a 1.48 mm shaft
http://www.micronwings.com/Products/...mm/index.shtml
DuraflyMicro Series - Replacement Propeller Adapter (US Warehouse) ... 8/9/2014. any with a 1.5mm prop shaft This fits the AP05-3000kv brushless motor.
terrynshed
03-22-2019 01:37 PM
ServoCity
New Product Announcements
07-09-2014 03:26 PM
matiac
10-23-2012 01:53 AM
RobWoodall
05-29-2012 11:23 PM
golfryan
03-09-2012 06:29 PM
Quick Reply: brushless in runner shaft swap
Page generated in 0.09029 seconds with 13 queries
