carbon fiber Cheap!!!!!!! - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Field Equipment For Sale & WTB Buy & Sell field equipment and accessories here. Free to buy or sell!
Old 01-04-2006, 12:03 AM
jrplane
Default carbon fiber Cheap!!!!!!!
I have LOTS left!!!!!Carbon fiber ribbon !!!!
.007" X.130"
10'@ $5
50'@ $20
100'@ $35
this is shipped!! In the lower US
The 1st pic is plain old fan fold
the 2nd pis is the same piece with 1 piece of carbon CA'd top the top! much stiffer
the 5th pic is 3/32 balsa with carbon CA'd to it, the lead blocks weigh 2lbs!!!
this stuff works great on foam planes for renforcemening wings , spars,
paypal: [email protected]
here is a link to the original post:
http://www.rcgroups.com/forums/showthread.php?t=391514
ID:	5462   Click image for larger version
ID:	5463   Click image for larger version
ID:	5464   Click image for larger version
ID:	5465   Click image for larger version
jrplane is offline
Old 01-04-2006, 03:42 AM
thomdoe
What length does the fiber come in. Thanks, Keith
thomdoe is offline
Old 01-04-2006, 04:41 AM
Rugar
FAA# OUTLAW!
Rugar's Avatar
10', 50', or 100'
Rugar is offline
Old 10-21-2006, 04:02 AM
rtrickyjr
rtrickyjr's Avatar
Want to get 100', but don't have paypal. Can we do this with a check or something?
rtrickyjr is offline
Old 10-26-2006, 04:43 PM
cbatters
cbatters's Avatar
2Q
1. Are you still selling the carbon fiber ribbon?
2. I have never worked with CF so I am wondering how you cut it? DOes it just snap when you bend it at a right angle?
cbatters is offline
Old 10-26-2006, 09:05 PM
rtrickyjr
rtrickyjr's Avatar
Guess not LOL
No reply ...
Old 11-06-2006, 08:11 AM
Lee R. Wheeler
Sent $10.00 for 20ft. Paypal sent.
Lee R. Wheeler is offline
Old 11-06-2006, 12:40 PM
cbatters
cbatters's Avatar
Received the carbon strip and have a question about how to use it to strengthen wings / stabilizers.
1. Is the strength increase achieved by laminating the carbon tape onto foam/balsa?
2. Does it have to be glued (with CA/Epoxy) or can it also be taped onto a foam surface?
TIA,
Clint
cbatters is offline
Old 11-07-2006, 08:54 PM
Lee R. Wheeler
Put it down carefully on the wood spar make sure it is the right width. And Ca. it down. I use a rubber glove on whatever hand and smooth it out.
Old 11-19-2006, 04:05 PM
oracle_9
The CA will bond to the rubber gloves, at least it does to mine. What I do is you need some PE plastic, like the thin clear bag at a the vegatable section of the supermartket or what I use, the food vacuum sealing bag. Either case you need to test which surface of the bag to use. On a scratch piece of foam or balsa apply some CA and then cut out a small piece of bag and apply it over the CA, and hold for several seconds, if it doesnt bond with the CA, then thats the right surface to use.
Then as Lee describes, lay down the strip, apply CA, and but this plastic bag with the non-bonding side down, and hold down. You should feel it will become hot, thats because the CA is chemically bonding the carbon to the balsa or foam. Dont do all the length at the same time. I suggest to do at increments of 12", which means each hand pushes down on 6" of length. The following sections of 12" should use a newly cut piece of bag, dont resuse the previous cut piece or it will now bond.
oracle_9 is offline
Old 12-04-2006, 02:34 AM
smak_blaze
Paypal sent for 20'
thank you
smak_blaze is offline
Old 12-28-2006, 12:25 PM
rcpilotmach1
Hello I would like to purchase a 50 ft ribbon of your CF...Do ypu sell any CF round push rods???Please advise....Thank you....
rcpilotmach1 is offline
Old 03-20-2007, 06:31 PM
kydeer7301
jrplane - do you still have any of the CF ribbon left?
kydeer7301 is offline
jaizon
04-10-2008 02:44 AM
HoaRC
06-10-2007 10:16 PM
normblitch
05-01-2007 01:52 AM
Milton
02-20-2007 10:36 PM
rahtware
9
01-29-2006 08:02 AM
Quick Reply: carbon fiber Cheap!!!!!!!
Page generated in 0.12127 seconds with 18 queries
