What Does R/C Stand For? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
View Poll Results: What Does R/C Stand For?
Remote Control
8.33%
Radio Control
55
91.67%
Voters: 60. You may not vote on this poll
Old 03-24-2008, 02:51 AM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Default What Does R/C Stand For?
I've heard it both way many times.
R/C = Radio Control or Remote Control
So which is it? And can you provide proof?
Thanks,
Frank
Murocflyer is offline
Old 03-24-2008, 02:52 AM
Airhead
Redneck Member
Airhead's Avatar
Hey Frank,
I believe it to be Radio Control. at least that is what I have always thought..
Airhead is offline
Old 03-24-2008, 02:54 AM
Radio control.
Remote control are those little toy cars that are tethered to the controller by a cable.
Or what you use to change the channels on the tv:p
Old 03-24-2008, 03:04 AM
Sky Sharkster
Sky Sharkster's Avatar
Default R/C?
Hi Frank,
I believe R/C in the modeling context stands for "Radio Control".
"Remote" can be any type of device that is actuated by a controller in a different location. For example an undersea search vehicle using a cable-transmitted control system is an "RV" or Remote Vehicle. A camera (or flash unit) triggered by an infared light beam is a remote control device. Even the "Clapper" is a remote-controled device, using sound as the signal.
So, our models are also remote control devices, using radio signals for the control.
JMO,
Ron
Sky Sharkster is offline
Old 03-24-2008, 03:19 AM
I'm bored - a quick check on the internet shows these abbreviations for RC................................................ .................................................. ....... Radio Control...Remote Control...Radio Controlled...Release Candidate...Roman Catholic...Remote Controlled...Rotary Club...Return Code...Royal College...Racing Club...Racing Car...Reality Check...Rugby Club...Reading Comprehension...Radius of Curvature...Racing Champions...Reaction Center...Reformed Church...Reduced Cost...Resistor Capacitor...Reserve Component...Resistance And Capacitance...Robot Control...Regional Center...Run Command...Rate Change...Recreation Center...Royal Crown...Running Club...Run Commands...Reserve Capacity...Run Control...Runs Created...Reletive Coordinates...Rubber Cement...Real Cool...Resource Configuration...Relativistic Correction...Responsibility Center...Rivest Cipher...Rookie Collection...Ring Count...Rendering Context...Requirements Contract...Really Crappy...Really Crap...Revlolutionary Control...Revenue Cutter...Right Check...Runtime Commands...Reduced Configuration...Raiding Cavalry...Run and Compile...Recursive Control...Rating And Certification...Region Commissioner...Retained Customers...Read And Cover...Riot Chick...Royal Crockery...Rivest Cipher...Roman Catholic...The Reflection Coefficient...Really Crappy...Real Car...Recorded Cassette Runtime Commands...Roller Coaster...Reserve Component...Rons Code...Real Catholic...Run Command...Regular Component...Run Control...Recruitment Counselor...Red Cooling...Respiratory Chain...Rig Compensator...Run Commands...Recoup Costs...Rising Conflicts...Result Cache...Reverse Complement...Really Clean...Reserve Capacity That is 10 minutes of my life I will never get back....... Mike
Old 03-24-2008, 03:23 AM
ragbag
Smile
YEP.....But thanks for sharing it with us.
ragbag is offline
Old 03-24-2008, 03:40 AM
Airhead
Redneck Member
Airhead's Avatar
Radio control.
Yup,
I call it a clicker....
Airhead is offline
Old 03-24-2008, 03:47 AM
Laggard
Who's got my six?
Laggard's Avatar
Radio Control
Laggard is offline
Old 03-24-2008, 04:17 AM
Rabbitcreekok
Rabbitcreekok's Avatar
Riot Chick? Really Crappy......... Thanks Mike, for things I never knew.
Rabbitcreekok is offline
Old 03-24-2008, 04:55 AM
gzsfrk
gzsfrk's Avatar
As mentioned by others, the acronym "R/C" (or "RC"), when used in the context of the aircraft upon which this site focuses, most often refers to "Radio Control" due to the most common nature of the control systems used. However, there are exceptions, such as my Air Hogs AeroSoar indoor flier, in which case the "RC" would instead stand for "Remote Control", as it uses an infrared-based control system.
To clarify, "Radio Control" is a subset of "Remote Control". Therefore, a "radio controlled" device is always potentially "remote controlled", but a "remote controlled" device is not always "radio controlled".
(I say "potentially" because you could technically be inside a device such as a plane or automobile that you are controlling via radio control, in which case that would not actually be "remote" control.)
gzsfrk is offline
Old 03-24-2008, 05:20 AM
TLyttle
TLyttle's Avatar
R/C; Really Confusing, Rarely Consistent, on and on. Early on we used to say "Radio? yes. Control? sometimes..."
TLyttle is offline
Old 03-24-2008, 02:13 PM
Yep - Riot Chick would have been my vote in the poll - had it been included!
Old 03-24-2008, 02:42 PM
Angler-Hi
Angler-Hi's Avatar
Well, I'm an idiot because I voted "remote controlled". Ya know what, who cares, go fly something already.
I like this poll Frank, it gets you thinking. Good job friend.
Angler-Hi is offline
Old 03-24-2008, 02:48 PM
idealhobbies
idealhobbies's Avatar
I think that in some cases it depends on where you live too. Soda = Pop etc....
idealhobbies is offline
Old 03-24-2008, 05:45 PM
Dr Kiwi
Which leads us to RC Cola............
Dr Kiwi is offline
Old 03-26-2008, 05:49 AM
batman
batman's Avatar
I think originally it meant radio control but with infra red and others it should now mean remote control. Not that I give a damn about it. Think I might go find the remote control and watch some TV.
batman is offline
Old 03-27-2008, 05:02 AM
hillbille
hillbille's Avatar
Reed switches that were operated via Radio signal to effect Control of a specific surface.
Just my $0.02 worth.
Hillbilly
hillbille is offline
Old 04-01-2008, 07:16 PM
50+AirYears
From the start, when the pioneers such as Chet Lanzo, the Good brothers, and other hall of famers were developing it, R/C meant Radio Control. That is, control of a model or full size aircraft through a radio link to operate control surfaces.
I first heard the term 'remote control' applied to our R/C plane by kids who didn't really know much about what was going on.
Remote control, as far as I'm concerned, goes back to any kind of control system, mostly tethered, sometimes IR or sound, where the operator is removed from direct contact with any sort of device. So, R/C, radio control, is a type of remote control. In the late 40s or early 50s, Jim walker, and maybe others, actually experimented with an acoustic remote control system. Problems with weight and background noise.
Sometime in the very early 50s, Air Trails, or one of it's later incarnations, had an article and plan for a single channel plane that actually was tethered. No radio, just a long 2 wire tether, I think about 150' or 200', attaching the plane to the flyer to operate an escapement from the ground. Doable, but apparently, unlike with toy cars and trucks, not too practical.
Thus, even control line models are a kind of r/c, or remote control model.
Hope I added to any confusion.
50+AirYears is offline
Old 04-01-2008, 07:24 PM
Bub Steve
Bub Steve's Avatar
50+AirYears:: I'm a newbie as I started in the 50's!!!Love hear'in from "the real" old timers!!HaHaaa! your bout my favorite bub here and make me smile alot, your bub, steve
Name:	petty an red 436.jpg
Bub Steve is offline
Old 04-02-2008, 05:38 AM
BEC
Bernard Cawley
Radio Control....but then we have the magazine formerly known as "Quiet Flyer" spelling out "remote control" every time they use the abbreviation "RC" and we have a hobby shop in the area that calls itself "Remote Control Hobbies". *sigh*
BEC is offline
Old 04-02-2008, 06:49 AM
Twmaster
Registered User
Twmaster's Avatar
Frank, you left off one choice for the definition of R/C.
Really Costly.
Twmaster is offline
Old 04-02-2008, 04:24 PM
gzsfrk
gzsfrk's Avatar
Really Costly.
This. Can I change my vote?
gzsfrk is offline
Old 04-02-2008, 05:19 PM
bowtie hi
Who cares ?
bowtie hi is offline
Old 04-02-2008, 06:21 PM
50+AirYears
R/C is remote control by means of radio. So What?
Old 04-02-2008, 06:33 PM
Bub Steve
Bub Steve's Avatar
REAL-CASH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!bub, steve
Quick Reply: What Does R/C Stand For?
Page generated in 0.15818 seconds with 15 queries
