Heads UP RC discussion Heads up RC discussion and support. Monitored by Heads UP RC.
motor 3548-07
Old 05-03-2011, 03:05 AM
cpmalish
Default motor 3548-07
hi,jeff or anyone who may be using this motor 3548-07, I have it mounted on a 3-3.5 plane and I hooked up to the watt meter and with a 4 cell 4400 mah lipo and a 50 amp ESC 11x6 wood prop it pulled 17.7 amps 221 watts I'm guessing I might of picked the wrong motor or is there something I'm doing wrong any help is greatly aprriciate thanks,Chris
cpmalish is offline
Old 05-03-2011, 12:18 PM
Hi Chris the 3548-07 is a low KV/RPM motor, 700Kv/RPM, for what you want, a 3548-09 would have been better, its a 900KV motor,
on the 3548-07 you can run a 12x8 or 12x10 prop on it with a 4 cell, but check it with a Wattmeter to be on the safe side.
also check your Lipo, it could be weak, check it against another lipo of about the same size, just to make sure its not a weak lipo, also check your dean connection and esc to motor connectors to make sure they are tight.
and something else you can do is to run a 5 cell with your 3548-07 that will wake it up with a 11x6 wood prop again, check it with a wattmeter to be on the safe side, Take care and have fun, Chellie
Old 05-03-2011, 03:20 PM
cpmalish
Thanks chellie I'm of to the LHS this morning hopefully they have some props instock they are more car people then flying but we'll see thanks again for the help I'll get back with the watt readings,Chris
cpmalish is offline
Old 05-03-2011, 07:28 PM
all_up_in_the_air
HeadsUp RC.com
Sorry for the delay in replying. I was out of town.
Chellie answered your question beautifully....couldn't have done it better myself (thanks Chellie!). If you can't find the right prop at your LHS, we have a good selection in stock.
all_up_in_the_air is offline
Old 05-03-2011, 11:52 PM
Thats Because I Learned from you Jeff with all the great Motor information that you provide on your motor pages with the thrust, prop, esc, and lipo recommendations, Keep up the great work Jeff, I send a lot of people to your Motor pages for information on props, esc, thrust , and motors for their planes, I have not ever heard anyone complain from the results of using your Motor Recommendations Take care and have fun, Chellie
Page generated in 0.07964 seconds with 10 queries
