Vintage and old timer models Discuss nostalgic vintage aircraft
Ace Nomad
Old 08-04-2015, 10:37 PM
Eddy
Eddy's Avatar
Default Ace Nomad
I am looking for Pics, or plans for a real old Ace Nomad. It was a small rudder only escapement sailplane with a motor pod mounted on top. Late 50's to early 60's, and it had polyhedral. I think that it used a Pee Wee .020. Span had to be about 36" to 48" maybe ? ? ?
Thanks.
Eddy
Eddy is offline
Old 08-04-2015, 11:41 PM
Henry Sistrunk
Henry Sistrunk's Avatar
Default Nomad
Is this it? http://www.hippocketaeronautics.com/...?topic=11751.0
Henry Sistrunk is offline
Old 08-04-2015, 11:47 PM
Early kits were wood structure wings, later ones had the foam wings. Either is correct for nostalgia class.
Old 08-05-2015, 12:27 AM
Eddy
Eddy's Avatar
You have found it ! Thank you very much. I will be able to use this.
Eddy
Eddy is offline
Old 08-06-2015, 02:44 AM
Abuelo
Abuelo's Avatar
Eddy,
Highly suggest adding a wing spar in the two center sections. The wing structure is OK for just drifting through the sky but weak for any type of maneuvering. My Nomad had an Ace pulse rudder only system and flew great, right up until the wing folded.
Bill
Abuelo is offline
Old 10-30-2015, 06:05 AM
rogerk
That was one fav FF for me back then. .049 powered. Silkspan covered. Build from a mag plan. Before Ace kits.? It spent months in a large tree, flew again. Next build was L19 .049 FF. Wish to find plans for.
rogerk is offline
Old 10-30-2015, 04:34 PM
Abuelo
Abuelo's Avatar
Is this it? http://www.outerzone.co.uk/plan_details.asp?ID=242
Abuelo is offline
Old 10-31-2015, 07:25 AM
rogerk
Nice, but not the one. Probably is better.. The one I scaled up in drafting class used balsa strips for the Fus formers. It flew so well. A Just me?
rogerk is offline
Old 10-31-2015, 08:23 AM
There used to be 2 to 10 plans you could build from (often after scaling up X2 to X4) in EACH magazine...
That was from appx 1930 to the mid 1970's and there were several magazines each month.
That's a lot of potential plans with almost no info to go on for finding it.
Old 10-31-2015, 06:50 PM
Abuelo
Abuelo's Avatar
Eddy
Eddy,
When you do build this I'm interested in seeing how you set up the electric motor and the related ESC, etc., with the motor on a pylon. Easy to do with the .020 but not with the wiring?
I have the Nomad back on the build-another list and i'm a fan of Ted Strader's designs. Will build with wing spar(s) this time.
Thanks,
Bill
Abuelo is offline
Batteries & Chargers
11
09-24-2012 07:28 AM
Cowboy
18
05-21-2012 06:16 PM
Flysohigh
14
11-09-2011 11:01 PM
hobbypartz
New Product Announcements
11-09-2011 04:07 AM
partzee
06-19-2011 11:04 PM
Quick Reply: Ace Nomad
Page generated in 0.13273 seconds with 13 queries
