Pattern aircraft Discuss electric powered pattern aircraft in here
What MFG. for this Pattern? [email protected]"
Old 03-21-2012, 12:50 AM
BOB275
Default What MFG. for this Pattern? [email protected]"
I was given this electric with a few missing parts. Can anyone ID this for me. Will appreciate it. Bob
Photo attach.
ID:	158314   Click image for larger version
BOB275 is offline
Old 03-23-2012, 04:44 AM
cbinfl
That's an Aeroworks " Stingray". I had one. A real nice plane. Make sure you cut an exit hole for cooling.
cbinfl is offline
Old 03-23-2012, 04:51 AM
BOB275
Well thank you so much for that info.
What electric motor did you use?
BOB275 is offline
Old 03-23-2012, 05:04 PM
cbinfl
Bob, I used a Hacker 30-28S with a 40 amp esc and a 10x6 prop. Any 480 size motor should work fine. Also a 2200 battery. I usually fly about 5 + minute flights. In fact that's what killed mine. Got talking while flying and went 8 + minutes and lost it ! A senior moment.
charlie
cbinfl is offline
Old 03-25-2012, 06:39 AM
dumpsterjay
It's all in the thumbs
dumpsterjay's Avatar
Default Aeroworks Stingray.
Bob275,
I've built two AeroWorks StingRays. The first one I lost due to a thermo overloaded ESC. Having figured out what the problem was, I then set about to cure the Problem.
On the second StingRay, I added twin Air Scoops to the top of the fuselage in the motor Area to promote better cooling of the motor, battery and ESC. I think that it even looks more like a StingRay with the twin Air Scoops.
Bob, The Stingray is one of the best, if not the best flying pattern planes of it's size.
I had a Hyperion G2220-10 Glider Motor on mine, A Scorpion Commander 45A ESC, Futaba S-3154 digital servo's, 3s 16c 2100mAh Lipo, and a APC 9x7.5e prop.
I was getting around four hundred Watts at 40A and let me tell you it was one sweet flying plane.
Now It's a Hanger Queen and I'm flying larger pattern planes now, But the AeroWorks StingRay is still one of the best pattern planes of it's size that I've ever flown.
J
ID:	158462   Click image for larger version
dumpsterjay is offline
EDFrules
Pattern aircraft
11
04-29-2011 10:10 PM
Quick Reply: What MFG. for this Pattern? [email protected]"
Page generated in 0.07466 seconds with 18 queries
