Old 10-07-2011, 10:43 AM   #1
raitheslacker
Exclamation DIY LED Afterburner HELP!
Not sure if this is the right thread for this but here it goes...
Looking to make a led afterburner on one of my planes. I want the led brightness to coincide with the throttle. I know that one way to do it is to connect the led's to a low amp brushed esc inline with the brushless esc then connect both esc's to the throttle channel via Y-harness and voila.
I'm looking to skip the whole extra low amp brushed esc. Would I be able to just connect the led strip to an open channel on my rx and mix it in with the throttle? Or would the voltage be incorrect? Any help is greatly appreciated.
raitheslacker is offline
Old 10-07-2011, 01:09 PM   #2
r_kopka
Electric Only
r_kopka's Avatar
2kW  1kW  Globetrotter Pilot
No.
The rx only gives a PWM signal with short pulses differing a bit in length and with no power at all. In any case you need some kind of electronics. And a brushed ESC should be quite cheap nowadays (ebay...).
RK
r_kopka is offline
Old 10-07-2011, 01:33 PM   #3
raitheslacker
Originally Posted by r_kopka View Post
No.
RK
Yeah just tested an led strip on my rx. Not enough juice to light it up. Was super dim and only 3 out of 24 lit up.
Now my question is this. I will be running 4s batteries so how do I attach a voltage regulator to the led strip? What kind of voltage regulator would I need?
Old 10-07-2011, 08:16 PM   #4
Friends: (8)
Here's what I use.
I have a string of Leds controlled by a Castle Creations, Pixie-7P with the red wire cut to disable the BEC.
It can handle 7 amps and up to 21Volts with red wire cut, but you will need to put a resistor in series with your leds to drop the voltage down to something they can handle without burning up.
Ohm's law can help you figure the value for the resistor.
My led strip pulls 400 ma at 12 volts. If I want to run it from a 4s pack, I am going to assume the pack is putting out about 16 volts. (at full charge it would be 4 x 4.2 = 16.8) That means I am 4 volts too high. I need to find a resistor that will have a 4 volt drop across it at 400 ma.
In electronics, E represents Voltage, I represents Amperage, R represents Resistance
(all in full units)
Ohm's law is
volts equals -- amps times resistance -- or E = I x R
Amps equals -- voltage divided by resistance -- or I = E/R
Resistance equals -- voltage divided by amps -- or R = E/I
So in my example to find the resistor, I will use the amount of voltage I need to drop (sort of get rid of) which is 4 volts,
and the current the leds pull when operating at the voltage they are designed for, in my case 400 ma,
since 1 ma means 1/1000 of 1 amp, 400 ma = 0.400 amps
Put all this into the formula and it is --- 4 / 0.4 = 10 ohms
So I would put a 10 ohm resistor in series with the leds, and then I could run them from 16 volts without burning up.
Since watts equals I x E in my example I will also lose 0.4 x 4 = 1.6 watts, not enough to bother with a fancy voltage reg.
Hope this helps
If I knew the voltage your leds require, and the total current at that voltage, I can figure the resistor for you.
Old 10-07-2011, 08:35 PM   #5
raitheslacker
Originally Posted by Wildflyer View Post
Here's what I use.
(all in full units)
Ohm's law is
Hope this helps
The voltage is 12v but i do not know the current :/
Purchased this from eBay. Not much info on it. Any recommendations?
http://www.ebay.com/itm/180687140964...ht_3493wt_1163
Old 10-07-2011, 10:40 PM   #6
r_kopka
Electric Only
r_kopka's Avatar
Better take 3s from the balancer cable. The current is not so high so it won't disbalance the battery much.
Typical BECs don't give you 12V.
RK
r_kopka is offline
Old 10-08-2011, 03:41 AM   #7
Friends: (8)
Pulling the 12v or 3s on the balancer cable will work just fine. It's simpler than a resistor, just watch the balance of the battery, because you will be discharging some cells a tiny bit faster than others, if the leds are wired correctly. I have seen some suggested wiring diagrams that would pull much more current than necessary.
If you don't have a good digital meter to read volts, amps & resistance, I would highly recommend getting one, also a inline wattmeter is almost necessary when setting up a good flying plane, it will help you choose the right prop, without burning up the motor.
Good luck if you need more help, we are here.
The basic electricity lesson I posted first, may come in very handy, when you can't tap into the battery's balance plug. I do some custom work with just bare leds. Some need very different voltages and currents, than others, so I just gave you what I do all the time, didn't mean to bury you in tech talk.
Old 09-11-2018, 03:22 PM   #8
Karnsy
I hope this reaches someone as the post is old. I am looking to get an afterburner kit but it runs straight off the receiver leads to the battery. Why would this not be ok ? Does anyone have one or been using one ? Found it on Ebay. I cannot find a 70mm one that plugs into the balance plug of my 6cell. Can anyone point me in the right direction. I want to do it right. Thanks !
Karnsy is offline
Old 09-11-2018, 11:05 PM   #9
View Panther's Gallery10
Club: Lockyer Valley Aeromodellers can be found on Facebook.
Why don't you just buy one of these?
Made specifically for what you want.
Old 09-11-2018, 11:22 PM   #10
Karnsy
Panther,
Thanks for the reply. I actually was thinking about that one. But some of the reviews caution about how to wire it up. Also does not hook into the balance plug but directly to the battery. I have read that is not as good. Confusing because it is made to be wired into the planes system as described.
Karnsy is offline
Old 09-12-2018, 12:41 AM   #11
I use a multi colour changing Ring on my FX61. You can lock the colours but it doesn't change with engine revs.
Old 09-13-2018, 01:39 PM   #12
Karnsy
Default Does anyone have this afterburner ?
I was thinking on getting one http://hobbyking.com/en_us/dr-madthr...___store=en_us
But I was hoping somebody has some experience with it ? Seems like just what I'm looking for.
Karnsy is offline
Old 09-17-2018, 09:29 PM   #13
Love my Stinger
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (16)
Have you tried or thought about this I did it in the past and it came pretty good.
https://www.flitetest.com/articles/f...d-afterburners
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Old 09-19-2018, 02:42 PM   #14
Karnsy
I did check that out but it seemed like a lot more work so decided not to go that route.
Karnsy is offline
LED STrobe Davethebluessinger Night Flying 23 05-12-2015 09:49 PM
diy size 400 motor n3o Brushless Motor Construction 1 10-05-2011 03:09 AM
For Sale LEDIA LED strips 1 meter 4 colors avail Dannyrevs General RC items For Sale and WTB 2 08-10-2011 01:21 AM
HZ Super Cub and LED lights - help needed. bcmedic16 Power Systems 9 02-04-2011 10:54 PM
Page generated in 0.13322 seconds with 46 queries
