Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Foamies
Old 09-08-2018, 01:40 PM   #76
aaindthu
Friends: (4)
I flew my RC Trainer today. But first of all, I want to thank you all very much for guiding me, for your suggestions and I sure got some motivation from you all despite my failures. I am so glad that I registered to Wattflyer.com. Here is the video of my maiden flight. Landings were a bit rough but the plane survived.
As you can see, I brought back my plane in one piece. No serious damage.
The landing gear bent backwards.
And it is a bit nose heavy. I'll fix that next time.
thank you all again !!
aaindthu is offline
Old 09-08-2018, 05:05 PM   #77
Rabbitcreekok
Rabbitcreekok's Avatar
View Rabbitcreekok's Gallery8
Globetrotter Pilot  WAA-08 Pilot
Friends: (30)
Nice job with the maiden flights. I can see you getting a little more stable with each flight. Once you get the CG correct, your flights will be more stable since you will not have to fight the controls to keep the plane level.
As you fly, try to keep the control movements small as possible so you don't have to recover from a wild gyration with another large movement. Smooth is best.
Also remember that altitude is your friend. At this point you should be flying about 3 mistakes high, meaning you can recover from three mistakes before you impact mother earth.
An easy to adjust the CG to the rear is to use small finishing nails in the rear of the plane. You can tape them to the fuselage until you get it correct, then poke them into the foam and hold them in with a piece of tape.
You are doing great with your perseverance of the project. Keep up the good work.
Jim
AMA 735658
Rabbitcreekok is online now
Old 09-08-2018, 05:37 PM   #78
Club: A lone flyer!
Friends: (6)
That is an excellent video.
Your plane certainly has more than enough thrust. It takes of in just a a couple of meters!
Being an own design you may well have to experiment quite a bit before it flies really well but you will know when it does simply because it will largely fly itself!
Well done. Keep going.
Old 09-08-2018, 06:24 PM   #79
Friends: (19)
Well done
Old 09-08-2018, 10:32 PM   #80
View Panther's Gallery10
Club: Lockyer Valley Aeromodellers can be found on Facebook.
Congratulations aaindthu. Excellent result! Hope you enjoy your plane and have many safe trouble free flights.
Old 09-09-2018, 01:05 AM   #81
View Don Sims's Gallery114
Friends: (40)
Great to see you've flown it. Congratulations!
Don
Old 09-10-2018, 08:45 PM   #82
Abuelo
Abuelo's Avatar
Club: Open flying at the Chandler Bowl
Friends: (7)
Congratulations on your successful first flights, and doing so with your own design. That is a tough combination and you succeeded.
Please keep us posted as you progress with your flying, designing, and building.
It is the mark of an educated mind to be able to entertain a thought without accepting it. - Aristotle
Abuelo is offline
Old 09-11-2018, 12:14 AM   #83
aaindthu
Friends: (4)
thank you very much, Abuelo. I will keep in touch.
For my next project, I think I will build a Rudder, Elevator only glider for soaring (with dihedral wings ofcourse). Powered by 4 x AAA size batteries. I already bought some HD foam boards.
Will keep you posted. Thanks again.
Aaindthu.
aaindthu is offline
Old 09-13-2018, 04:29 PM   #84
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Club: Fort Bend R/C
Friends: (6)
I read only one reference to CG without providing you a method
of precisely locating the CG of your model. Here are two methods.
It does not matter the size, couple, span or weight...it has to be
balanced in order to fly without porposing constantly.
http://www.scaleaero.com/CG_Calculator.htm
Both methods of calculating are shown in this one web site.
Ed Clayman
"Flite-Metal For The Look Of The Real Thing"
Flite-Metal is offline
Old 09-13-2018, 06:25 PM   #85
Friends: (19)
Hi Flite ... I think most of us made decision to advise putting CoG in safe area 20 - 30% chord as it was basically a straight wing. The guy is starting out and for myself - I considered linking a CoG calculator app for him - but then thought he has enough to get on with ...
Its a good tool though to have so it will certainly benefit him now that he's seen the advantage of getting it in the safe area.
Old 09-13-2018, 07:02 PM   #86
Club: www.rmvc-cumulus.nl
An excellent CG tool
www.ecalc.ch (16 languages)
→ toolbox
→ cgCalc
Vriendelijke groeten Ron
Without a watt-meter you are in the dark, until something starts to glow
e-flight calculators watt-meters diy motor tips Cumulus MFC
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 05:22 PM
Griffwerks MX 3D Foamie Plane - Mini Review njg 3D Flying 7 06-21-2014 03:40 AM
E Fly Radio th1bill RC Radios, Transmitters, Receivers, Servos, gyros 4 10-05-2013 05:04 AM
TOO WINDY TO FLY YOUR FOAMY? - Try Slope Soaring AEAJR Foamies 6 11-13-2011 06:21 AM
I can Fly! Really Fly! prof_fate Beginners 24 10-14-2011 04:57 PM
Page generated in 0.16895 seconds with 42 queries
