Different Prop for Pusher? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-27-2008, 11:54 PM
mtuhoop24
mtuhoop24's Avatar
Default Different Prop for Pusher?
I am going to get a pusher jet and I was wondering if you use a different prop than for a normal electric plane?
I know you reverse the motor but what if anything do you do different with the prop!!??
Thanks.
mtuhoop24 is offline
Old 11-28-2008, 01:12 AM
kohned
Same old same old. Put the numbers to the front just like in tractor configuration, the prop is still pulling the same direction. Look at the contour of the prop to make sure you have it turning correctly and you're good to go.
kohned is offline
Old 11-28-2008, 01:19 AM
powerlines
I AM NO SHOES!!!
powerlines's Avatar
Reason for a pusher prop is cause it is HARD to change direction on a Glo motor.. Electrik you just change wires.. Brushless run just as good one way as the other.. Brushed you use to have to change timing..
powerlines is offline
Old 11-28-2008, 01:32 AM
mtuhoop24
mtuhoop24's Avatar
Thanks guys. so the motor faces the opposite direction and the prop faces the same direction. Got it......I knew that but like to have some affirmation!
Old 11-28-2008, 03:15 AM
Liquidity
Combat Vet
Liquidity's Avatar
Yup that is correct. Also if you want counter rotating props, you would need a pusher.
Liquidity is offline
Old 12-01-2008, 12:53 AM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
OK, that has me wondering, a lot of beginner planes, like the EZ* and many of PZ's birds are pushers and brushless. Are these moters especially made for pusher props? Or are the props special (they're made to rotate "backwards", maybe?)
FlyWheel is offline
Mike Freas
12-06-2007 01:41 AM
NoThreat
07-02-2007 05:21 AM
jafoca
06-21-2007 02:41 PM
jb48
09-05-2006 05:08 AM
fletchrrr
01-09-2006 05:38 AM
Quick Reply: Different Prop for Pusher?
Page generated in 0.11087 seconds with 14 queries
