Park Zone P-51 Help
Old 01-02-2009, 09:23 PM
a4gturn
Default Park Zone P-51 Help
I'm a newbie to this, so be gentle. The nylon gear attached to the shaft of the motor is loose. It slides up and down on the shaft and it slips when the power is applied resulting in almost no propeller.
What is the best way to afix the gear to the shaft?
a4gturn is offline
Old 01-02-2009, 09:55 PM
PZ512608
I have one but i havent had that problem yet. I would try some light CA hope that works for ya it a good plane
PZ512608 is offline
Old 01-02-2009, 09:58 PM
PZ512608
but if the gears chewed up might what to change it first
PZ512608 is offline
Old 01-04-2009, 05:58 PM
Gohmer
Banned
Smile Prop Shaft
Best fix is to replace the shaft and gear assembly. http://www.horizonhobby.com/Products...ProdID=PKZ1504
Gohmer is offline
Old 01-05-2009, 12:35 AM
ltbidrawn
Default new gear assembly
the main gear is pressed onto a spleened hub (at the end of the drive shaft). they are tough to remove and sometimes destroy the plastic main gear in the process.
an entire new gearbox is about 6 bucks. takes about 10 minutes to remove and replace.
ltbidrawn is offline
Old 01-05-2009, 01:12 AM
groundrushesup
groundrushesup's Avatar
I concur. Did you by any chance punch this plane in on its beak? I have run the gearbox with a 3550Kv inrunner and a 2700Kv inrunner for 10's of flights and never had the spur separate - I have had the front half of the fuselage separate from the wing and the tail for sure, but either yours took a mighty direct fore-aft shock, or there is a crack you just don't see.
Order yourself a gearbox and save the shell in the bag - you will need it later. Trust me on this.
groundrushesup is offline
Old 01-19-2009, 02:13 AM
a4gturn
Thanks you guys. All great tips. I bought a new pinion and pressed it on myself. So far, so good, and as suspected by groundrushesup, I did "punch this plane on it's beak "once.
a4gturn is offline
Old 01-19-2009, 04:01 AM
groundrushesup
LOL well yeah, this plane in particular with it's 3" spinner does have quite a pronounced beak, huh?
Piratemed
ParkFlyers
22
01-09-2015 02:32 AM
cigarslicer
3D Flying
14
03-05-2009 04:07 PM
clt12981
34
03-03-2009 04:11 AM
Robert Peberdy
ParkFlyers
12-26-2006 12:51 AM
kloudking
09-05-2006 03:11 AM
Quick Reply: Park Zone P-51 Help
Page generated in 0.09705 seconds with 9 queries
