Micro Sized Electric Helicopters Discuss micro and mini sized electric rc helis in here
WLToys V911-1 - what a gem!
Old 01-09-2014, 08:26 PM
Default WLToys V911-1 - what a gem!
I only bought this after seeing friends wife fly one at the field in a little wind. I was amazed at the ability of the little machine.
Open box, check it over, charge up 2 of the 7 batts I have for it.
Plugged in, bound and then fly. Brilliant.
Only niggle - the very short sticks on the Tx. Couple of short lengths of bamboo added and taped secure had that sorted.
Excellent.
Old 01-09-2014, 08:33 PM
neet little heli.
[media]http://www.youtube.com/watch?v=FDXWt_KSMRU[/media]
Old 01-10-2014, 01:52 AM
pmullen503
Excellent.
The V911 can be controlled with a TX using the Flysky protocol/module like the 9x.......
pmullen503 is offline
Old 01-10-2014, 08:19 AM
Yes I know ... I as going to change one of my 9x back to FlySky for this .. but the replacement 9xr crapped out.
With the stick extensions - makes it much better ... in fact I may just leave it as is.
Old 01-11-2014, 12:53 AM
pmullen503
I mounted the stock 9x antenna on the Flysky module to make it removable when I did my Spektrum mod.
The V911 is the only reason I still have a Flysky module.
Old 01-11-2014, 07:23 PM
My 9x has the antenna on the module anyway. I never bought the full Turnigy with wired antenna. I have factory original and Turnigy bare-bones Tx's.
Old 01-12-2014, 05:57 PM
Here's the real full flight maiden after adding the stick extensions to the Tx ...
[media]http://www.youtube.com/watch?v=H3wawqYlWLg[/media]
Old 01-15-2014, 04:10 PM
rcbuildernoob
heard good things about this heli got the syma f3 on sale for $15 they are supposedly almost exact same from what ive heard.
rcbuildernoob is offline
Old 01-22-2014, 01:26 PM
Having a little trouble now with batterys ... they lose contact easily ... one in fact needs 'twisting' to work ....
Old 01-22-2014, 02:04 PM
If all seven of your batteries are playing up then it's more likely to be the wires or the plug attached to the heli and not the batteries themselves.
Seeing you fly your V911 got me to dig out a similar size little FP heli I got from Hobbyking a while back, they can be a lot of fun. My son and I had a game of full contact combat flying in our living room, me with the heli, him with a Hubsan micro quad Both helis lived to tell the tale, just.
Old 01-31-2014, 05:30 PM
rcbuildernoob
Yea i agree with jet took apart one of the syma f3 batteries and soldering doesnt look to great dont know about the wl. Recently had a collision with a book case and both ends of the flybar broke so now waiting to get the money to order the spare part for it along with 2 parts for a double horse 9074. But must say it took a beating before it gave.
Old 01-31-2014, 06:55 PM
The socket on the Helicopter is not too good ... one pin does move. But the worst are the battery plug ends ...
My parallel charge block connects to all batterys ... but one shows near dead.
I need to sort a way to make solid the helicopter socket ... without incurring weight ... CA is not an answer as that will pass through into the socket itself ...
Old 02-01-2014, 01:07 AM
rcbuildernoob
Hmmm had a cheap 20 dollar 3ch rc heli that did that but used a hotglue gun and problem was fixed might also try super glue near 0 weight depending on how much you use and bonds to almost anything.
Old 02-01-2014, 09:29 AM
Superglue is CA ... and I think the CA will creep through the pin 'hole' ...
I have thought of a dab of hot glue or Epoxy.
I can plug in a battery and when pressed - connects ... let go and it disconnects.
Old 09-04-2015, 10:54 PM
squidger
squidger's Avatar
Looks good. I have just bought the WL Toys V977. Similar size but cp. Youtube vids show them flying really well. Think mine has a problem though. I get it airbourne and trimmed for hover and all is good then during the flight it starts to go right (main rotor cyclic right) I compensate with a little left stick to get back to the hover then it goes right some more. After about 2 mins of flying I end up with half the right stick left movement to keep a stable hover. Unplug the battery and start again and it hovers well at neutral for a few seconds then it starts going right again. Must be giro related but can't fathom it out.
squidger is offline
Old 09-04-2015, 11:39 PM
squidger
squidger's Avatar
Definitely giro related. This heli has two modes on the tx ref giros. 3g and 6g. In 6g mode the heli returns to hover when you return the right stick to neutral so is more stable. In 3g mode if you return the right stick to neutral the heli carries on moving in the last commanded direction. In 6g mode I have the problem I outlined in the last post but in 3g mode she flies superbly all be it a harder mode to fly in. For the 60 I paid for the heli which included the tx I'm not going to argue, I'll just fly it in 3g mode all the time.
http://www.hobbyking.com/hobbyking/s...y_to_Fly_.html
squidger is offline
Old 09-04-2015, 11:57 PM
Sounds like you are suffering bad initialisation of gyro in 6g more. If 6g is like HHold .... then this can happen if initialization is wrong.
Old 09-05-2015, 12:11 AM
squidger
squidger's Avatar
Instructions are chinese translated to complete gibberish so I will just fly it in 3g mode. Alot of heli for not alot of money though.
squidger is offline
Old 09-05-2015, 09:27 AM
There is probably a routine to re calibrate the accelerometers that are the 4th 5th and 6th 'g' in a 6g system. .. But how you do it I've no clue.
Old 09-05-2015, 09:30 AM
With these models the important bit is to actually put battery first to model .... put down steady and still .... switch on Tx. The model then initialises to its position. Unlike most models ... these are usually Rx first then Tx.
Old 09-05-2015, 09:53 AM
But would that explain the slow drift where the heli was ok for the first few minutes them progressively went right more and more? And all the more unlikely why it would do exactly the same thing flight after flight? And why is it ok in 3g mode?
Sounds to me like the controller needs calibrating. This is something that you can do in the 6 axis controllers in quads but I've never used such a controller in a heli.
But there again.. you might be right, certainly worth a try powering up like you said.
Old 09-05-2015, 12:00 PM
squidger
squidger's Avatar
Have calibrated the TX which made no difference.
squidger is offline
Old 09-05-2015, 01:47 PM
The gyros are in the heli, not the Tx.
On the 6 axis multi rotor controllers i've used there is a procedure to calibrate the accelerometers so you don't get this drifting. If you can do it on this heli and/or how you do it i don't know.
Not much help i know.....
Old 09-05-2015, 02:09 PM
The biggest error made by people is the not leaving the heli on ground still long enough when powering up Tx. Its power up and wait a little bit till another series of beeps ...
You can in fact upset the initialisation by having trims altered ... so best to neutralise trims ... power up ... initialise and then fly.
Calibrating as far as I know is not possible ... but I could be wrong.
My mate flies this heli and he made a point of the powering up sequence. Its' even same with my 911. But of course I don't have 6g.
Old 09-05-2015, 08:19 PM
squidger
squidger's Avatar
Tried that tonight Nigel. Then flew in 6g mode had no drift to right this time but drifted fwd so bad had full back on stick for hover at one stage. As I said flies beautifully in 3g mode so not worried.
squidger is offline
Quick Reply: WLToys V911-1 - what a gem!
Page generated in 0.11748 seconds with 11 queries
