Too big of tail blades - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Standard & Large E-Heli Talk Discuss all standard and large sized electric rc helicopters in here
Old 08-07-2014, 03:37 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
Default Too big of tail blades
So I fixed up the 450x, installing new tail blades that are a tad larger. I set everything up perfectly and idled up at 60% throttle, checking centering of tail. Then I gave it some throttle to make it light on its skids, everything seemed fine, when suddenly a grip blew apart, and the whole rear housing. All it seems to need it a new housing and grips, everything is okay, belt is fine. What would cause this though? I made sure belt was a good tension, it had a bit too much slack so I moved the boom out a tad. Could the tail blades be too large, and when I have it rudder it put too much stress on the housing.
thepiper92 is offline
Old 08-07-2014, 03:54 AM
"Could the tail blades be too large, and when I have it rudder it put too much stress on the housing"
Yep.....as a general rule with collective pitch, never cheat on the tail rotor blade or tail pitch assembly. The housing assembly (as a unit) is designed for a specific size blade, hub, holder and control ball linkage.......going with bigger blades not only stresses the tail rotor holder, bearings and collars, but also requires the belt tension to be perfectly set....to tight you get an explosion....to loose you get stripping and vast amounts of vibration. All of which have an impact on the gyro's ability to compensate and keep up with the main rotor head speed...!
Old 08-07-2014, 04:10 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
Thanks, they were quite a bit larger, the belt would have slipped, but I adjusted it so it took a bit more force to move the belt on itself. Guess the issue was just too large of blades. At least the damage isn't too bad. Think I have a spare housing already that was shipped to me accidentally. I gather the only way to use them is use a aluminum housing, aluminum grips, etc.
By using larger I gather it has more authority and stress trying to keep up with the main rotor.
Old 08-07-2014, 04:57 AM
I converted every 450 I owned to CNC main rotor and complete tail rotor assemblies....ABS/plastic may be cheaper, but the wear and tear over time (and mishaps) CNC is 1000 times better.
If you intend to convert, be advised mixing and matching CNC with ABS is a no-no......go all the way or don't go at all....for the Blade 450 you have, it will be hard to find complete assemblies, almost every vendor, that even carries parts for that Blade, sells the parts individually and it gets quite pricey....
Here's a couple of links to give you an idea what your'e up against:
http://www.redrockethobbies.com/category-s/932.htm
http://www.rakonheli.com/e-flite-upg...blade-450-3d-x
http://www.helihobby.com/helicopter-...-450x.html?p=3
http://www.wowhobbies.com/e-flite-bl...-3d-parts.aspx
http://www.helidirect.com/blade-heli...8_236_1858.hdx
http://www.horizonhobby.com/products...380A#t4-HOPUPS
In most cases, the Blade 450x and Blade 450 3D tail assemblies are identical........I'd even look into the Trex 450 Sport assemblies and compare....there may be a tail boom size difference, but the belt width and tail blade rotor compatibility may very well be the same size....and Trex (Align) parts are everywhere and very good quality.
Old 08-07-2014, 05:28 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
In my case would I be better off sticking with stock parts now. I am also having an issue with the canopy it seems, as with the spectrum mg servos, the servo horn rubs against the canopy. I definitely need a wider canopy, even if on a few mm wider, or without the sides that taper inwards.
Old 08-07-2014, 06:39 AM
Why larger tail blades?
With the plastic grips you do need to be careful, but usually the stock blades work fine so no point changing.
Old 08-07-2014, 06:49 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
Well the combo I bought came with tail blades, stock ones were a bit damaged, so I installed them. Should have realized the potential risks. I have a spare tail case, all the is needed is grips...and stock blades. Still don't know what to about canopy, not sure who makes canopies that are larger overall, would be nice having it fit over battery better too.
Old 08-07-2014, 07:38 AM
I'm confused. If they came with the original Blade 'combo' package then they should be the correct blades for the heli... no?
Old 08-07-2014, 07:40 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
It was a canopy, blade, fin combo, so my 450x is now sporting red fins...and a canopy that is now carved up to allow the servo movement.
Old 08-07-2014, 01:02 PM
Ahh.. ok i understand now. Good luck with your future flights, sounds like it's about time your luck changed!
Ricardo Morales
Beginners - Helis
02-17-2013 09:55 PM
Doc Austin
3D Flying
01-05-2013 04:19 AM
11-16-2011 10:31 PM
cncfoam
65
07-15-2011 08:47 PM
siansoft
04-21-2011 02:31 PM
Quick Reply: Too big of tail blades
Page generated in 0.10185 seconds with 12 queries
