Comet Taylorcraft - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Comet Taylorcraft
Old 01-22-2008, 12:38 AM
pd1
Still Learning
pd1's Avatar
Default Comet Taylorcraft
Got a little time off from work and started a new plane yesterday.
I found these plans while cleaning up at my dads house.
I built this plane nearly 50 years ago. It was rubber powered then.
Now I'll build it electric.
It has a 54 inch wing span, I think I'll cut it down a bit to be more like Duane Cole's plane.
The plans were old and yellow and delicate so I had them coppied at Staples.Click image for larger version
Second side layed out over the first.Click image for larger version
I cut out the formers by photocppiing them and pinning them to the balsa.
Fuse starting to take shape.Click image for larger version
ID:	52954Click image for larger version
Paul
pd1 is offline
Old 01-22-2008, 05:08 AM
Sparkie
Got epoxy
Sparkie's Avatar
Nice one Paul, looks like it is going together pretty quick, I checked out Duane Cole's plane, pretty sharp. what are you planning for power plant?
Glenn
Sparkie is offline
Old 01-22-2008, 05:11 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Subscribed
Grasshopper is offline
Old 01-22-2008, 02:51 PM
pd1
Still Learning
pd1's Avatar
Hi Glenn,
I've got a couple BL motors in the drawer that need a home.
Probably one of them.
Doesn't look like it will need much power.
Paul
pd1 is offline
Old 01-22-2008, 07:57 PM
RacerPaul
No doors or fenders!
RacerPaul's Avatar
Watching...
Paul
RacerPaul is offline
Old 01-22-2008, 08:03 PM
alienx
alienx's Avatar
Yep, this is going to be a nice plane. I am imagining your craftsmanship applied to a nice high-wing scale plane!!
You made short order of the formers too. That's the one thing that is keeping me from trying my own scratch build. Not cutting the formers themselves, but having to try to put all the slots for the stringers and whatnot. Even if you can get them cut small enough, I can't see how it is possible to get them all lined up!!
What is the span on this (if I missed it)?
EDIT: I guess lining up the slots is only a big deal if you change the size because you enlarged the plan.
alienx is offline
Old 01-22-2008, 08:33 PM
gfdengine204
gfdengine204's Avatar
Subscribed as well, just cuz Tom is....
So, you cut the formers out of balsa sheets? Dang.....
gfdengine204 is offline
Old 01-22-2008, 09:51 PM
pd1
Still Learning
pd1's Avatar
Andy, Even if you enlarge plans the locations of the formers and stringer remain the same.
Wing span is 54 inches. I will probably shorten it a tad.
I use a razor saw for most of my cutting.
I cut the slots with the saw and use the tip of the knife to cut the tab free.
Kev, Yup it's balsa. I stink at foam.
Paul
pd1 is offline
Old 01-22-2008, 10:01 PM
alienx
alienx's Avatar
Are you going to clip the wings?? I think anything in the 54" area is nice! Especially if you build it light and floaty!! Do you have a target AUW? I happen to know a guy that built a plane that flys at 74 ounces, with a mere 39 inch span.
OK, I guess like every other plane I've struggled through in here, you have to just jump in and solve the problems when you get to them. OR, I could send you the plans and let you cut the parts!! You seem to be good at it.
Looking forward to your usual 2-day build!!
alienx is offline
Old 01-22-2008, 10:04 PM
pd1
Still Learning
pd1's Avatar
Andy, I have the forward formers and stringers on already.
I'm waiting for glue to dry on the sheet I added to the nose.
Since I'm not in a hurry I'll keep using Titebond.
I'll post pictures tomorrow.
Paul
pd1 is offline
Old 01-22-2008, 11:13 PM
jofrost
It flew once before...
jofrost's Avatar
Paul ,
Great subject ! Looking forward to seeing this one . I don't think my "Lizzie" will be ready for Sunday . Maybe another week or so .
-John
jofrost is offline
Old 01-22-2008, 11:32 PM
gfdengine204
Paul,
Using Titebond, do you let it wick into the joint, do you "paint" or brush it on both surfaces, or is there another method to use that glue? (All I have done so far with a balsa kit is CA on the joints).
Old 01-22-2008, 11:42 PM
Gnascher
Got My TX - Need 2 Fly!
Gnascher's Avatar
subscribed. Looking forward to this one.
Gnascher is offline
Old 01-23-2008, 01:24 AM
pd1
Still Learning
pd1's Avatar
A few more pictures.
Kev I think CA is good, it just seems a little more brittle than Titebond.
I personally dab it on one piece and clamp the pieces together.
Then I use a stick of scrap balsa and add a little around the joint.
Landing gear braces in.Click image for larger version
Sheet on clothes pins to hold until dry.
Stringers on, stringers are 1/8 x 1/8 .Click image for larger version
View of nose with sheet on bottom, Next will be the ply gear mounts.
The longerons were upped in size from 1/8 to 3/16.
3/16 is over twice as strong.
Total weight so far is 2.3 ounces.
pd1 is offline
Old 01-23-2008, 01:26 AM
ShutterAce
Do the Monkey with me!
ShutterAce's Avatar
Very nice!!! Nothing like a good scratchbuild.
ShutterAce is offline
Old 01-23-2008, 01:41 AM
pd1
Still Learning
pd1's Avatar
ShutterAce, Thanks.
Here's a shot of Duane Coles Taylorcraft.
pd1 is offline
Old 01-23-2008, 02:06 PM
jb48
Suscribed on this very nice build thread.
jb48 is offline
Old 01-24-2008, 12:03 AM
jofrost
jofrost's Avatar
Paul ,
Looking very nice ! Hey , is that the ME262 in the background there ? When can I expect to see that one go ? Still waiting to see you Fockwulfe fly too
-John
jofrost is offline
Old 01-24-2008, 12:06 AM
pd1
Still Learning
pd1's Avatar
John, You can see them fly, but you have to go out to the field.
I like your Lizzie.
Paul
pd1 is offline
Old 01-24-2008, 12:27 AM
jofrost
jofrost's Avatar
I like your Lizzie.
Paul
Paul ,
Which field do you have in mind ? Sparky has his Cub ready and may need a qualified pilot to maiden and trim out for him !
-John
jofrost is offline
Old 01-24-2008, 12:57 AM
smokejohnson
smokejohnson's Avatar
Very cool build thread Paul. Subscribed
smokejohnson is offline
Old 01-24-2008, 02:21 AM
ShutterAce
ShutterAce's Avatar
ShutterAce, Thanks.
Are you sure it's his? LOL
Your's is lookin' great!. All these older civies are just good looking planes. My favorite is probably the Cessna 180 but I really like them all.
Old 01-24-2008, 02:19 PM
pd1
Still Learning
pd1's Avatar
ShutterAce, I like the Cessna 180 too.
Much more than the Taylorcraft.
Paul
pd1 is offline
Old 01-24-2008, 02:57 PM
pd1
Still Learning
pd1's Avatar
Tail is done.
Landing gear base is in and wing rear hold down ply is in.
Stab pinned to board.Click image for larger version
ID:	53342 Rudder and finClick image for larger version
Stab size has been increased over original
Had to draw new plan for tail Click image for larger version
Wing rear hold down and gear base in.
Lite ply from a Clementine boxClick image for larger version
Tail sanded and pinned on fuse.Click image for larger version
pd1 is offline
Old 01-24-2008, 03:03 PM
alienx
alienx's Avatar
Looks great Paul. Inspiring!
alienx is offline
Quick Reply: Comet Taylorcraft
Page generated in 0.14894 seconds with 11 queries
