F-22 Raptor thrust vectoring scratch built twin ducted fan jet
Old 06-16-2009, 02:25 AM
MikeysRC
Default F-22 Raptor thrust vectoring scratch built twin ducted fan jet
I just threw this together a few days ago. Pretty fast with good vertical performance. Only uses two servos. Each servo is connected to an aileron and elevon.
FREE PDF plans for this jet will be available in the near future from
www.mikeysrc.com
[media]http://www.youtube.com/watch?v=WDNLNAYjFVE[/media]
The jet uses;
Twin GWS 64mm EDF units
2 4400kv brushless motors from hobbycity
2 9 gram TowerPro servos from hobbycity
2 40 amp ESC speed controllers from hobbycity
Ideal battery is 2 1300mAh 20 11.1V batteries. BUT 1250mAh - 1800mAh also worked.
Flight times range between 5-7 minuets depending on how much of a speed freak you are =)
"Mikey"
ID:	103424   Click image for larger version
ID:	103425   Click image for larger version
ID:	103426   Click image for larger version
MikeysRC is offline
Old 07-02-2009, 04:38 AM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Plane flys great. Loved the puppet. Profile twin EDF is different. Can't believe nobody else has told you good job.
Alpea42 is offline
Old 07-02-2009, 06:07 AM
MikeysRC
Thanks Alpea42,
I really appreciate those kind words and thank you for checking out the video. I just bought a HD video camera to take better flight videos.
"Mikey"
MikeysRC is offline
Old 07-02-2009, 10:55 PM
Alpea42
Alpea42's Avatar
Hey R/C plane videos are not easy to make. It's a small fast moving subject very difficult to follow. I saw you did alotta editing on your video. Where you junked most all the footage but the fly bys. That takes some editing skill too.
Alpea42 is offline
Page generated in 0.08218 seconds with 14 queries
