T28 Trojan
Old 08-17-2017, 01:11 AM
  #1326
Doug 14
4s was a success, i didnt push it too hard , check my temps on motor and esc a few times and it wasnt any hotter then with 3s , alot faster when you need it but comfortable at lower speeds , glad i dodnt buy more 3s , they are hard to cone by here in Ontario, I guess 2200mah 3s is a common pack for most planes so they sell out quick . I fly this thing every morning at 7am and 3 packs wasnt enough , now I have 11 . this plane is pretty darn good I think I'm getting another one used this week , I was going to get a mustang ,thunderbolt or corsair but for this season I'm going to stick with this and save the new plane for next year
Doug 14 is offline
Old 08-17-2017, 07:10 AM
  #1327
F22trainer
Originally Posted by guapoman2000 View Post
My buddy Gerry was nice to take some super high resolution pictures while my T-28D Airforce Trojan was commanded to fly in Knife Edge formation all around the field.
That looks super! First one I've seen in USAF colors.
- I am sitting n my living room and looking at the photo of my dad in formation flight #2 position. Maybe I will try that T-28 before I tackle the T-29!
F22trainer is offline
Old 08-20-2017, 05:34 PM
  #1328
Doug 14
had a pretty good crash into a tree the other day , damage only to the wing , repaired with hot glue and small bamboo skewers, didn't add a lot of weight and every looks straight but today it was banking hard to the left when stick was dead center , trimmed all the way right with alieron and got it to fly straight, but not sure what's causing such a bad pull ?
before this all trims where dead center and I flew straight , only other I changed was I put in a ar800 rx , it is possible the rx has issues ? no visible reason for the drastic pull
Doug 14 is offline
Old 08-20-2017, 05:48 PM
  #1329
Could be, but more than likely it's something mechanical or an electrical connection that did not get sorted out after the CRASH.........Spend a little more time checking all electrical connections, all physical linkage adjustments, wing and fuse balance/taper/surface controls/hinges.
It's not unusual (after a CRASH) to find several little issues not related to the ESC or RX performance, causing control issues or the need to re-set surface control settings (manually or electronically)........
Old 08-20-2017, 05:59 PM
  #1330
Doug 14
I just adjusted the clevis on both aileron and put the ar600 back in im going to pull the cowl and look for motor mount damage , I did notice it pull a few times even after it was trimmed all the way right . might be a danger servo , everything seems to check out , the alierons were off a little
not sure if it was enough to make it bank that hard but I guess I will have to test the changes and work through the p.o.e ( process of elimination) my remote is an older dx7s it could be the problem too but I flew my new p47 right after and it flew straight .
Doug 14 is offline
Old 08-20-2017, 06:19 PM
  #1331
Doug 14
everything looked good so hopefully it was just a small adjustment .
this prop came with my p47 , it bolted on good , should I use it or asking for trouble?
not sure of size or pitch but on the bench it seems to have a lot more pull .
running a 40amp eflite esc and 1250kv motor on 4s 45c
File Type: jpg
Doug 14 is offline
Old 08-20-2017, 08:20 PM
  #1332
Personally, I'm not a big fan of 4-blade props, particularly on a Trojan. They look nice and sized properly, will give decent performance. However, found on the Trojan, two blade's (sized adequate for motor and ESC), generally will out perform quad's.....even for "3D"/Acro flight.....and provide longer flight times.
Just an observation, before slapping that quad on the T-28, give the plane a few flight run-throughs after repairs......no need to add another bunch of "if's" to a plane that has been CRASHED, until one is satisfied with the original performance after repairs......then start experimenting with caution......otherwise, you'll never completely sort out any issues that crop up.....and end up with more glue and sticks than foam.....and the plane will never fly as it did OEM.......
Old 08-23-2017, 03:18 AM
  #1333
Doug 14
I tried it the other day but still pulls , enough alieron trim and it flys ok but I think I need a new wing
I picked up a 3 blade pz 1015 today, going to try it tomorrow if weather permits
Doug 14 is offline
Old 08-23-2017, 08:03 PM
  #1334
I'm thinking the the trade off for a multi blade prop is you'll typically get more thrust at the sacrifice of speed. Can't have both
Old 08-23-2017, 08:09 PM
  #1335
Doug 14
I tried it this morning , I didn't like it as much as the 9.5×7.5 . I even slapped on the 4 blade and it was horrible, sucked so much power I thought I put a drained pack back in by mistake , so it'll never be used , or for display over the winter lol
Doug 14 is offline
Old 08-24-2017, 04:52 AM
  #1336
F22trainer
I'm with Pizzano on this - engine bearings/ bent shat could sapping strenngth, but also, get it on a stand and level both longitudinal and lateral axis. Measure wing stations at various points and you might find a twist is causing control issues. 1/8 of an inch twist at or near a wing tip can get ugly even though it may appear ok by eye. Might even be able to just purchase new wing, if necessary. Twisted horiz / vert stab may also not be noticed unless you start measuring from level.
Sure s a great looking model - hate to see her decommissioned...
Old 08-24-2017, 12:56 PM
  #1337
Doug 14
I think it's the wing , I do notice after the crash the inner part of the wing is mishaped slightly, I didn't think it was enough to effect anything but it's gotta be, it's pretty calm this morning (7am) so itll be a good time to see just how straight it flys , yesterday was 16km winds and it was dancing
Doug 14 is offline
Old 08-26-2017, 04:20 AM
  #1338
Doug 14
it's flying good now, I must have been my prop adapter , I was using the one off my sukhoi 29mm, plus the motor was loose , got it flying really smooth this morning, cg set for 1st time and 0km winds made for my best flight yet , ailerion still trimmed all the way right but flew pretty straight, might pick up a new wing next week and try that, or just live with it . either way thanks again for all the feedback and responses it all helped
Doug 14 is offline
Old 08-26-2017, 08:22 PM
  #1339
F22trainer
Glad to hear that!
Old 08-27-2017, 05:28 AM
  #1340
Doug 14
yup , until I crashed it hard today lol, more glue and bamboo skewers, trying some knife edge and got mixed up , hard impact so I'm hoping it still flys ok
Doug 14 is offline
Old 09-17-2017, 01:58 AM
  #1341
Psychron
youtube.com/psychron
One of the neighbors is selling this same version of the plane with some spare batteries, a dx6i and some other stuff and is only asking about 75 bucks for the bundle. I'm absolutely certain it's a good deal, but I've already got the newer one with the flaps and retracts that flies on 3s batteries.. not the big one that takes a 6s. I stuff a 5100 drone battery in there and I get about 10 minutes in the air.. the 3s usually dies after about 6. so I've got very little time to enjoy myself up there with those. What's the flight time on a 2200mah 3s pack?
Psychron is offline
Old 09-17-2017, 02:49 AM
  #1342
Doug 14
I retired my Trojan last week, poor thing was so beat up it wasn't worth flying it anymore, with stock 30amp and stock motor I could squeeze 7min flying slower but 5 max flying 3/4- full , I switched to a 40amp and 1250kv and got less , mostly because I was flying faster . now I fly my pz p47's with 30amp and 1250kv and get 6min -8min depending on how hard I push it, I didn't bother with the 40amp esc because it just meant shorter flights . I've learned I like flying longer rather then faster .
Doug 14 is offline
Old 09-17-2017, 04:49 AM
  #1343
Psychron
Aww, that's too bad. She's a nice bird to be sure. And I'm with you, I'm more about longer than faster. That was the motivation for the 5100 8c drone batteries. that's 40+ amps of continuous current draw capability. It doubled my flight time to be sure, but I mean, it's still tough to swallow when I can put my mini apprentice S in the air for 10-12 minutes at full throttle and at half throttle where I have her balanced to fly level she'll go for much longer. I still bring her in when the timer expires but.. man. Still, that's a very capable machine even with 3s my newer model T28 with the retracts and flaps at 1.3M span manages to pull vertical. I love the plane, I just wish it would run longer. Part of me wonders if that could be achieved with a 10 or 12" slow fly prop. I'd run the numbers through e-calc but the numbers I get from there don't seem to match reality.
Psychron is offline
Old 09-22-2017, 03:04 PM
  #1344
Psychron
I saw a post earlier regarding speed vs thrust when you go from a 2 blade to 3 blade. I have the larger 1.3mm with retracts and flaps. She's pretty heavy and doesn't really move too fast (I assume because of the triple bladed prop) but she does pull vertical. It's a blast to watch her climb.
on the opposite side of the point that more blades is less speed, I had the umx brushed P51 and with the included 4 blade prop that thing was like a rocket until I crashed it into a football upright and well.. after that she never flew right again. Very disappointing.
One of these days I may build the Flitetest P51 because it's a fast build and easy to do. I don't like building too much.. it's fun but not when it takes three months.
Psychron is offline
Old 03-19-2018, 02:38 AM
  #1345
JoeTheFlyer
The UK's Red Baron
JoeTheFlyer's Avatar
Nice to see the thread still going after 10 years, haha. I still fly RC planes guys, just not the Trojan anymore lol
JoeTheFlyer is offline
Page generated in 0.13459 seconds with 12 queries
