2 words: Parkzone VAPOR!
#177
Seems like an age since the last time I flew anything.
The weather has just been rubbish...
Yesterday, managed to get the Vapor out for half an hour.
There were a few challenging thermals knocking around, which would lift it a few feet suddenly - but, had fun.
Question for the 110mah battery users.
I have the MCX heli, which uses the above battery as standard, so my spare batteries really need to be used in both aircraft.
I am thinking of adding a couple of strips of plastic, so there is a similar cage sort of holder as on the MCX.
Because if I add velcro, then the batteries wont fit the MCX.
What have you guys done?
#178
Here ya go! Just use two small strips of "Light Hook Velcro" and put them on the bottom of the battery. That way you can use the batterys in both the Vapor,and mCX heli. I got the velcro from an multiplex plane kit,but the wife informed me,that you can get all diffrent kinds of velcro from a fabrick shop (female thing). You don't want the thick (industral strenght type).Ron
Make sense?
I can't imagine this would add enough weight to matter to the heli.
#179
Yeah,Kev! That would work too! There are alot of ways to make it work,you can "cut the straps" on the mCX battery holder,and make that work as well. Being lazy by nature
,I just use the two small strips,and it works well
! Ron
#180
#181
Oh, Ron, did you get to fly indoors yet?
#182
Yup!
I flew 3 day last week. The only problem we have is, it's closed on week ends.
But we can fly Monday thru Friday from 8:30am to 3:30pm. I was wrong about the rafters/trusses. It has a arched ceiling (no trusses)
I'll try to get some pics. next week. It sure gives you allot of room to fly verticle manuvers. Ron
#183
Yup!
#184
Yeah,I just wish we could fly evenings. It would get a better crowd! But can't look a gift horse in the mouth!:o It must be 70 degrees here today,
but real windy
! Maybe this evening I'll get a little backyard flying in. Ron
#185
I always use the medium to thick CA for repairs. It does not run all over the place and into places I don't want.
There's also a reinforced/flexible CA; it's clear. Mercury (LHS) & Loctite (Hardware Store) have it. Zap CA I think has it too but is black (like Loctite Black Max) and designed for rubber wheels on RC Cars. This stuff does not shatter under impact like normal CA does.
A lot of the CA companies are starting to do what Mercury did and put a pin in the lid to keep the bottle from clogging.
I really like plastic epoxy - Loctite Plastic Repair. Duro used to make some too but I think Loctite bought them. This does not shatter like regular epoxy. It's a creamy color, not clear.
#186
Throughout my rocketry experience I used a lot of Bob Smith 2 part-5-30 minute epoxy and put a lot of stress on it especially the fin to motortube/bodytube attachment points. I never once had any shattering problem other than the occasional crash and then maybe a joint would crack. Is this a problem that is experienced by RC pilots? Other than a crash, I cannot envision any shattering problem with epoxy on RC airplanes unless there are adhesion or mixing proportion problems. I have made some extensive repairs to my Super Cub with epoxy and have had no shattering or adhesion problems. I use epoxy because I can control it from running into areas it will cause problems but I haven't used any of the gel or thick bodied CA to get a comparision. I can see where thin CA would be difficult.
swimmer
swimmer
#187
I've had regular clear epoxy break off of my glue job but not the plastic epoxy. I think it is a urethane epoxy and it is TOUGH stuff.
Where I've had trouble is when adding a tail wheel to a tail dragger like the mini Ultra Stick. I mount the tail wheel to the back side of the servo horn. The music wire & plastic I epoxy it to have a lot of stress and regular epoxy fails after a short time. Since using plastic epoxy I have yet to have a failure and I've been flying it for two seasons now.
I thought since we're talking about repairing carbon fiber which flexes a lot that plastic epoxy would be perfect for this application.
But use whatever works for you.
mini Ultra Stick Tail Wheel
#188
I finally pick up a Vapor RTF from Hodges Hobbies yesterday. This thing is a blast!! When I got home it was dead calm outside; so, that is where I maidened it. Out of the box my Horz Stab look like it was attached crooked, but it work correctly. So I flew it anyway and there were no problems. It flew very well as was very easy to manage. Later I flew it in the house. I just got a new house with a 19x 25 space that is our living room and kitchen. While it was being built I imagined fling a Vapor or mCX in it. There was plenty of room for flying the Vapor. Today I practiced landing on the kitchen counter/bar.
If you don't have a Vapor... GET ONE!
#191
Bigger batteries like the Blade mCX battery or the new ones on the market - the 130mAH.
If the batteries have sat around for a while they will not perform well for a couple of flights. This happens to my BIG LiPo's after a winter on the shelf; a few flights later and they're back to normal.
Try keeping them warm before using. Any battery will not do well if it gets cold enough.
#192
I bought my Vapor three weeks ago and have been flying our three indoor sites and having a blast. Sometimes we put 8 foot streamers on them and try to fly combat chasing the streamers and that is really fun. The streamers are only 1/2 inch wide and I am thinking of making them 1/4 inch wide.
I shot some video and you can see it at -
[media]http://ca.youtube.com/watch?v=Jfhuylszgs0[/media]
My other YouTube videos are at -
http://ca.youtube.com/profile?user=c...og&view=videos
Bob
[email protected]
Bob
[email protected]
#193
By the way, I think we will be flying indoors again soon. I will let you guys know when.
#194
I have my Vapor landing gear repaired with thread and CA, loving it though. Took it outside yesterday and really let it loose in some light wind. New 110 mah battery is definitely worth the upgrade and my local hobbyshop has them for only $8. My average flight time is longer than I care to record however probly 20+ minutes.
#198
You can get 130 mah batteries for 10 bucks here. limited time though -
http://www.wattflyer.com/forums/showthread.php?t=42546
#199
After flying the Vapor for about a month I really think it is almost perfect as is. The only issue I've had is the battery tray. The Velcro is weak and I really don't understand why the battery tray points down. So, the only mod that I have wanted to do is flip the battery tray. I really over though this and tried to debond the super glue so I could slide the tray off and put it back on so it pointed up. Like I said, I over thought it. All I really needed to do was twist it 180 degrees and call it done. Super easy mod and no more hanging batteries.
