Heli Terms for Beginners
Still in training
How about the meaning of the KV rating of brushless motors? It could either be its own item or added to the definition of Brushless Motor. It took me a bit of searching to find that it translates to RPM per volt applied. Being an EE by education (I'm a software engineer by trade), I immediately mistakenly translated it to kilovolt and wondered how you could generate 3000 kilovolts with a 11.1V battery and have enough current to drive a motor.
c'mere Monkey
Retreating Blade Stall
A dangerous situation resulting when in fast flight where the blade that is flying towards the helicopters tail looses enough airspeed to generate lift. This can result in loosing control of the helicopter.
See-Saw Head
A form of rotor head where the two rotor blades are "connected" through a feathering shaft (thick wire) so that when one pitches up the other pitches down. This makes for a more stable helicopter an a simpler design, but does not hand le as well as a flapping head type.
Dissymmetry of Lift
Describes how the advancing side of the rotor disk is moving faster and thus produces more lift than the retreating side. This causes the helicopter to bank in forward flight and is dampened by flapping blades.
Feathering Shaft
A rod which helps support the rotor blades and give them more ridged strength. A flapping head has two feathering shafts (one for each blade) and a sea-saw head has one feathering shaft (running the span of the head)
Flapping
A type of rotor head where the two rotor blades are not connected directly through the feathering shaft (a thick wire), each blade can move somewhat independently of the other resulting in smoother control of the helicopter and the to some degree the feel of a .60 size heli.
a shot in the dark here. if you can . could you contact me, re the latest issue(14). I wish to speak of the Vector angles mentioned on Page 107 Blade Articulation Maneuvering
More info on why the stall would be Relevant.
I wouldn't confuse people on Feathering. it is Teetering. or flapping . If you liken it to an Airplane. It would be similar to Dihedral.
you may want to Include the point of Cyclic action to Cause Symmetry (Relatively or Controlled) Flapping blades and Delta offset are a means of dampening un-commanded disk actions.
I get confused when I read this. Are you trying to describe the Feathering Axis of the Blade (PITCH) or the Teetering action ??
Again you mention Feathering on this one. Are you referring to the Teetering action. or an Action of Blade flap on an axis inline with the chord line. if the later. then they are independent.
Feathering Shaft
** The feathering shaft is what's being described. It is exactly as the description says, a one piece ridgied rod that connects the 2 blades together. This is not a description of "feathering". Again, I did not write these definitions as the previous post explains.
Flapping
**Flapping
Again, this refers to the feathering shaft and NOT feathering. There is a difference between the two. Later in the the description it states flapping style heads have somewhat independent blades. This has nothing to do with teetering action or the see-saw. Read the post above as these definitions were not created by me.
Flapping
See-Saw Head
Actually, it wouldn't be similar to dihedral. If the rotor blades were allowed to travel creating a concave rotor disk where the blades pitched up equally from the center to the tip then it would be similar to dihedral. Again, this was not a description for feathering OR the feathering shaft. It was for the see-saw and it simply included the feathering shaft to demonstrate how the see-saw head works.
See-Saw Head
Feathering is just for Pitch change.
teter or flap.
teeter has one hinge central to the Shaft axis. and Flaping has one hinge per blade.
when the blade is at the retreating side, it is also at a Higher angle of attact (Because the comand from the swash is to get it High at the rear) and due to the AoA being to high. the blade stalls. <usualy at the tip> the area of the blade that is receiving a reverse flow is not stalled. it is just in reverse flow.
check out this one
you may want to ignore the red bit. it is hard for Pilots to understand and is commonly debated. but pictures are available. just cant find one at the moment. OK Found one.
mostly. you will get warning signs of it about to happen.
But if you push into it. and it happens.
1st thing you must do is reduce collective
2ns thing is land and have a stiff drink and think about why it happened. IE why did you go there. (It is usually only going to happen if you exceed design limitations. IE VNE or VNE @ given Weight and Alt combination.)
Could you explain what the different size designations mean. I understand that a T-rex 450 is smaller than a 600, but what do those numbers mean? What about a Raptor 50? What does that mean?
Thanks for clearing up a lot of terms.
Jackson Hawk
Jackson Hawk
Jackson,
Unfortunately, there isn't really accurate info that comes with numbers. Originally, the numbers related to engine size but with the electric helis moving in, those numbers have gone away. A 450 doesn't really tell you much except that it is smaller than a 600.
Here is the info from http://www.rcheliwiki.com/Helicopter_sizes that Asperamanca was talking about but as I stated before, the sizes don't correspond to anything in particular anymore.
Sub-micro (<100g, <20cm rotor diameter)
Extremely small helicopters, often coaxial. Low total energy makes them suitable for flying indoors.
Micro (<500g, <50cm rotor diameter)
Small helicopters such as 350-sized electric helicopters.
Miniature (<1kg, <80cm rotor diameter)
400 - 450 sized electric helicopters, can be flow inside in large open spaces with care.
Small (<2kg, <100cm rotor diameter)
500 sized electric helicopters.
Normal (<4kg, <150cm rotor diameter)
30 and 50 sized nitro helicopters, 600-sized electric helicopters.
Large (<6kg, <200cm rotor diameter)
90 sized nitro helicopters
