F-22 Raptor thrust vectoring scratch built twin ducted fan jet
I just threw this together a few days ago. Pretty fast with good vertical performance. Only uses two servos. Each servo is connected to an aileron and elevon.
FREE PDF plans for this jet will be available in the near future from
www.mikeysrc.com
[media]http://www.youtube.com/watch?v=WDNLNAYjFVE[/media]
The jet uses;
Twin GWS 64mm EDF units
2 4400kv brushless motors from hobbycity
2 9 gram TowerPro servos from hobbycity
2 40 amp ESC speed controllers from hobbycity
Ideal battery is 2 1300mAh 20 11.1V batteries. BUT 1250mAh - 1800mAh also worked.
Flight times range between 5-7 minuets depending on how much of a speed freak you are =)
"Mikey"
www.mikeysrc.com
The jet uses;
"Mikey"
Hey R/C plane videos are not easy to make. It's a small fast moving subject very difficult to follow. I saw you did alotta editing on your video. Where you junked most all the footage but the fly bys. That takes some editing skill too.
